  • 6938阅读
  • 27回复
746换代7410! [复制链接]
离线BA1IO
只看楼主 倒序阅读 0楼 发表于: 2011-01-05
the icom ic-7410 provides professional performance in the 160 to 6 meter amateur bands. this specialized hf rig employs the same high grade dsp unit and double conversion super-heterodyne system developed from the latest technology used in the ic-7600, ic-7700 and ic-7800 series. it features a 15khz roofing filter. in addition, when used with the optional fl-430 and fl-431 filters, narrow mode signals are protected from adjacent inband signals. the 3khz first if filter is especially effective in the cw and ssb modes. it utilizes icom's proven if-dsp technology. like the ic-746pro, it features a sharp black and white lcd. in fact, the ic-7410 liquid crystal display is actually 10mm wider than the ic-746pro display. it features a superior general coverage receiver covering 30 khz to 60 mhz with +30dbm 3rd order intercept point receive performance and ?.5 p.p.m. stability. there is a built-in bandscope function, and baudot rtty capability. other refinements include: ?.999 khz rit, bpf, quick split function, band edge beep and cw keyer (6-48 wpm). a large chassis heatsink is employed. there is a built-in tuner. power is 100 watts. there are both ci-v and usb ports on the rear panel. this radio requires 13.8 vdc at 23 amps.
接收跟7800媲美?
离线BA1AK
只看该作者 1楼 发表于: 2011-01-05
和9100外形很雷同啊。
在线BA7CK
只看该作者 2楼 发表于: 2011-01-05
换个型号好继续高价。
离线ba7ib
只看该作者 3楼 发表于: 2011-01-06
换个型号好继续高价。
明显拆台子.... 不过是说了实话.....
离线bl7ia
只看该作者 4楼 发表于: 2011-01-06
可能又出 ic-7000pro
用 ic-7800 7600 的 dsp 技术加 roofing filter
又卖贵些了,,
估计7410会比 ts-590贵吧
离线BA1IO
只看该作者 5楼 发表于: 2011-01-06
可能又出 ic-7000pro
又卖贵些了,,
估计7410会比 ts-590贵吧
756pro停产,7600顶上
746pro停产,7410顶上
加5000接着出!都是生意人儿!
只看该作者 6楼 发表于: 2011-01-06
只能说是7400停产,7410结合910特性而生产的替换机型,两个接收都有dsp处理通路。
而9100是746p整合910的升级产品。
原本7400和746p基本就是一样的东西,7410和9100应该也是这样的关系,供应不同市场。
离线ROBOT
只看该作者 7楼 发表于: 2011-01-06
aqr那746和746p有什么区别。
只看该作者 8楼 发表于: 2011-01-06
不太了解他们差异了,但是那时756,756p,p2,p3之前的差异可谓巨大,前者都还是没有dsp处理的很传统的短波机(只是多了个大屏而已)。想必746和746p也有如此大的差异?
离线ROBOT
只看该作者 9楼 发表于: 2011-01-06
aqr你的那台ts-590好机器呀,什么价位,什么时候通联下。
只看该作者 10楼 发表于: 2011-01-07
590到手半天不到就借enk去玩了,年底26到1月3号间事情比较多,缺时间碰机器干脆先让喜欢机器的人去玩。反正590有预告出来到正是发售间都比较关注,觉得是一个有想法有趣的机器,虽然日本商品用料真是很一般谈不上有太好的期望,但有了兴趣也有冲动,并且机器看来找不到特别大的缺陷就趁势冲动购一台来。当天到货下午逃会议,玩固件升级,大约试了下操作还行的,enk已经等在我单位楼下了。至于价位和我以前预期的范围差不多以前预期15000以下可以尝试。以后要玩机器去by4dx基地好了。
不说590了,这个楼是110预告7410的。
离线BA1IO
只看该作者 11楼 发表于: 2011-01-07
[quote=老干部]只能说是7400停产,7410结合910特性而生产的替换机型,两个接收都有dsp处理通路。
原本7400和746p基本就是一样的东西,7410和9100应该也是这样的关系,供应不同市场。[/quote]
对对!还有7400的事儿呢!他要叫ic7401我可能考虑!车牌号跟我一样!
离线bd7cv
只看该作者 12楼 发表于: 2011-01-07
对中国供应ic-74110
离线BD4WM
只看该作者 13楼 发表于: 2011-06-28
离线BA7JG
只看该作者 14楼 发表于: 2011-06-28
ic-7410的性能在ic-756pro3之上的!
只看该作者 15楼 发表于: 2011-06-28
买啦9100还没有摸过。给朋友拿去玩啦
只看该作者 16楼 发表于: 2011-06-28
我估计9100的hf核心表现和7410应该差不多?
只看该作者 17楼 发表于: 2011-06-28
我看9100和7410用同一个外壳
只看该作者 18楼 发表于: 2011-06-28
连铸铝镁合金的框架都是差不多的模子,框架后面插头位多少而已
只看该作者 19楼 发表于: 2011-06-28
没错。。。。。
