  • 3083阅读
  • 6回复
有什么区别? [复制链接]
离线bg6mt
只看楼主 倒序阅读 0楼 发表于: 2011-01-03
请问ft—817和ft—817nd有什么区别?
哪位知道,请告知!谢谢了!
离线BG7IBQ
只看该作者 1楼 发表于: 2011-01-03
现在出的都是nd的,就是这样的区别
离线BA1IO
只看该作者 2楼 发表于: 2011-01-03
the yaesu ft-817nd is a new deluxe version of the hugely popular ft-817. the ft-817nd includes 60 meter coverage plus the new high capacity fnb-85 battery. the radio is a fully self-contained, battery-powered, low power amateur mf/hf/vhf/uhf transceiver for portable/camping/mountain top use. providing coverage of of the 160-10 meter amateur bands including 60 meters, plus the 6 meter, 2 meter and 70 cm bands, the ft-817d includes operation on the ssb, cw, am, fm and digital modes. this radio is designed for use either from an external dc source or internal batteries and provides up to 5 watts of power output when on external dc power. when using the battery pack or 8 aa cells (not supplied), the radio automatically switches to 2.5 watts. the multi-function lcd screen includes selectable blue or amber backlighting which may be disabled for battery conservation. this radio comes with: mh-31a8j hand mic, fnb-85 ni-mh 1400 mah battery, fba-28 battery case (for 8 x aa cells not supplied), nc-72b charger, yha-63 whip antenna for 50/144/430 mhz, e-dc-6 dc cable and shoulder strap. installation note: only one optional filter may be installed in the ft-817nd.
离线bg6mt
只看该作者 3楼 发表于: 2011-01-06
非常感谢提供的资料!
具体的性能和电路上有什么区别呢?
离线net2000
只看该作者 4楼 发表于: 2011-01-06
非常感谢提供的资料!
具体的性能和电路上有什么区别呢?
从上面的英文看,就是加了50兆、带一块电池,至于电路除了50兆外,其它应是一样的。当然即使是后期的nd版本,也许也有几个电路改动版本。
离线BD5QCE
只看该作者 5楼 发表于: 2011-01-06
以前的老版本就有50兆了,nd似乎多了一个什么频率不记得,反正我用不上,电路有什么改动不知道。
离线BH7OJ
只看该作者 6楼 发表于: 2011-01-06
换了末级功放管吧?
