  • 2506阅读
  • 3回复
换个口味,BA1KY告诉我的信息。 [复制链接]
离线BD7IWW
只看楼主 倒序阅读 0楼 发表于: 2010-12-22
提起高档电台就是日本的两家icom和yaesu。
icom是ic-7700/7800
yaesu是ft-5000/9000
这里介绍adat公司制造的软件定义的短波电台adt-200a
售价与上面两家差不多,为$5895美元。
发个操作手册给大家,更多相关信息上google搜搜。
离线BD7IWW
只看该作者 1楼 发表于: 2010-12-22
pdf文件上传失败
大家根据型号搜搜吧。
离线bg7hy
只看该作者 2楼 发表于: 2010-12-22
本坛前不久见过一贴
离线BA4WI
只看该作者 3楼 发表于: 2010-12-22
the highlights of the adt-200areceiver
•4 receivers with independent frequency selection
•automatic fine tuning for am and cw via push button
•audio recorder capable of recording up to 60 minutes
•several noise blankers eliminate even extreme impulses
•linear s-meter with an unbelievable range of -148dbm up to +17dbm and a typical error of ±1db
transmitter
•adaptive predistortion allows pa efficiency up to 70% and results in a very clean modulation
•low distortion voice enhancer replaces the legacy speech compressor
•clean output spectrum with an intermodulation ratio of >45dbc
•calibrated vswr- and power meter working from 100mw
planned further developments
•spectrum analysis, displayed on a pc
•audio recorder with a capacity of 1 hour
•web server module for remote access
•morse decoder
•digital operating modes
•smart antenna: directional rx antanna, also for the low bands (up to 160m)
•network analyzer for exact measurement of antenna impedances up to 30mhz
•trx-module for 2m and 70cm
http://www.adat.ch/index_e.html
