  • 3279阅读
  • 9回复
psk63 contest。亚运管制。没得玩。有兴趣的朋友可以试下 [复制链接]
离线BD7IS
只看楼主 倒序阅读 0楼 发表于: 2010-11-14
dear fellow psk contester,
european psk club has the honour to invite radio amateurs from all over the world to participate in the 5th epc psk63 qso party 2010. the objective of the competition is to establish as many contacts as possible between radio amateurs around the world by using the bpsk63 mode. everybody can work everybody for qso and multiplier credit. the contest will be held from 00:00 utc to 24:00 utc on sunday, 21st november, 2010. the rules and other information can be found at our website. this is strictly bpsk63 contest, no other modes are allowed. the maximum output power is 100 watts. recommended frequencies are: 160 meters (1.838 – 1.840 mhz), 80 meters (3.582 – 3.590 mhz), 40 meters (7.040 – 7.050 mhz), 20 meters (14.072 – 14.080 mhz), 15 meters (21.072 – 21.080 mhz), and 10 meters (28.072 – 28.080 mhz). please note that since this year epc members should send signal report plus 5-digit epc membership number (example – 599 epc00001). please make sure that you don't separate «epc» from the «number», and you don't use any characters between. please make sure that your epc number consists of 5 digits! other stations should send signal report plus qso number, starting 001 (example – 599 001). you should send your log via e-mail: ut7fp@srars.org
all the very best and see you all in the 5th epc psk63 qso party 2010!
using mixw in this contest. the new set of files for the mixw data mode software makes your particiapation in the epc psk63 qso party most enjoyable. you can download this set of files at statseuepc.zip.
after the deadline all logs will be published as ubn reports..
contest log checker software
www.contestlogchecker.com
离线BG4LJW
只看该作者 1楼 发表于: 2010-11-15
有中文的么???
离线xfhmh
只看该作者 2楼 发表于: 2010-11-15
我这段时间用的是bpsk31,感觉传播差的时候比话音好用多了.
离线husy
只看该作者 3楼 发表于: 2010-11-15
鹏鹏,在广州的固定台是可以玩的,基于你的特殊情况,多一事还不如少一事,隐下手吧。
离线BD7OXR
只看该作者 4楼 发表于: 2010-11-15
正确,这几天我在家里通联没有问题 但还守听好些
离线BD7IS
只看该作者 5楼 发表于: 2010-11-16
好惨啊。
离线BD5QCE
只看该作者 6楼 发表于: 2010-11-16
好惨啊。 [表情]
什么样的特殊情况了?
离线BD7IS
只看该作者 7楼 发表于: 2010-11-16
什么样的特殊情况了?
低调 低调。
离线肥M
只看该作者 8楼 发表于: 2010-11-16
离线kentwu
只看该作者 9楼 发表于: 2010-11-17
没天线更苦,连听都不行.哈哈
