  • 3800阅读
  • 8回复
Hi, BD6CR [复制链接]
离线BD6RA
只看楼主 倒序阅读 0楼 发表于: 2003-02-13
how are you doing?
离线BD6CR
只看该作者 1楼 发表于: 2003-02-13
Re: Hi, BD6CR
just back from home. thank you very much for your posts. they make our board hot in such cold days.
最初由 bd6ra 发布
hoe are you doing?
离线BD6RA
只看该作者 2楼 发表于: 2003-02-13
Re: Re: Hi, BD6CR
最初由 bd6cr 发布
not so hot as those days when you were in hefei. anyway, i'm trying. does your vxo work ok when 100p is used for c301 and c302? when i got back in shiyan, i constructed my vxo with the new pcb. it worked ok for a few days. with the main tune 30p,the coverage of 16000-16090 and 12390-12435 was achieved, but later the performance was no good. so i use 27p instead, the main tune 200p. it's been working very well. the coverage is the same! hi, hi.something wrong with my 100p capacitors? i don't know. anyway, use 27p.
离线BD6CR
只看该作者 3楼 发表于: 2003-02-13
Re: Re: Re: Hi, BD6CR
my vxo worked perfectly when using 100p for both c301 and c302. i don't think big frequency coverage is good. if no frequency display is provided, tuning would be difficult. your 100p is good. when will you go back to shanghai?
最初由 bd6ra 发布
离线BD6RA
只看该作者 4楼 发表于: 2003-02-13
Re: Re: Re: Re: Hi, BD6CR
it simply worked poorly even when the coverage was narrow. strange. it had worked perfectly. maybe the cause of the quality of the 100p i used. i'm leaving for shanghai on 18 or 19, depending on the ticket.
离线BD6CR
只看该作者 5楼 发表于: 2003-02-13
Re: Re: Re: Re: Re: Hi, BD6CR
ok, i have something to talk with you via email. please check your email.
最初由 bd6ra 发布
离线BD6RA
只看该作者 6楼 发表于: 2003-02-13
Re: Re: Re: Re: Re: Re: Hi, BD6CR
最初由 bd6cr 发布
now or later? i checked a few minutes ago. nothing.
离线BD6CR
只看该作者 7楼 发表于: 2003-02-13
Re: Re: Re: Re: Re: Re: Re: Hi, BD6CR
i will email you tonight or tomorrow. please wait.
最初由 bd6ra 发布
离线BD3RJ
只看该作者 8楼 发表于: 2003-02-13
英语天地?
