  • 2860阅读
  • 4回复
2010年IOTA比赛分数出结果了 [复制链接]
离线BD2RJ
只看楼主 倒序阅读 0楼 发表于: 2010-10-12
bd2rj/2 as151 changxing   edit   iota fix sou cw 12h lp 416 15 30060
错得挺多
time band mode yourserial call serial rcvd iotaref reason for loss of credit multiplier lost
1223 20 cw 21 ra3st 10   noqso [notinlog] not in ra3st s log
1519 20 cw 177 rv9cp 34   noqso [bad serial] serial given by rv9cp was 134
1520 20 cw 178 dl1kza 433   bad copy [bad iota] iota of dl1kza was eu057
1537 20 cw 191 ut2px 88   noqso [notinlog] not in ut2px s log
1548 20 cw 197 ra0fu 149   bad copy [bad iota] iota of ra0fu was as018
1658 20 cw 236 sy9m 76   bad copy bad copy of exchange: should be 766 eu015
1717 20 cw 253 oy1ct 483   bad copy [bad iota] iota of oy1ct was eu018
1723 20 cw 259 w5bm 444   bad copy this is a busted call
1730 20 cw 266 yo9sp 107   bad copy [badcopy] should be yo9hp
1746 20 cw 279 g0pse/1 99   bad copy [badcopy] should be g0pse
1803 20 cw 292 rg4f 243   noqso [notinlog] not in rg4f s log
1827 20 cw 308 ga4vhf 169   bad copy [badcopy] should be pa4vhf
1857 20 cw 333 es3jd 405   bad copy this is a busted call
1858 20 cw 334 ok4m 61   bad copy [badcopy] should be ok3m
1905 20 cw 341 og5a 831   bad copy [bad iota] iota of og5a was eu140
1907 20 cw 342 oe6smd 2   bad copy [badcopy] should be oe6imd
2148 20 cw 363 vk4xui 41   bad copy [badcopy] should be vk4bui
2149 20 cw 364 vk4an 77   bad copy [bad iota] iota of vk4an was oc137
0046 15 cw 397 ja7ble 616 as007 bad copy this is a busted call
0202 15 cw 432 ua9lao 44   noqso [bad serial] serial given by ua9lao was 440
0221 15 cw 436 ja7dle 64 as007 noqso [not in log]
summary of score using the following formula:
((non-iota qsos+ qsos with same iota)x3 + qsos with other iota x15) x mults)= final score
score before adjudication from 437 valid qsos is:
( (372+0) x 3 + 65 x 15) x 15 = 31365 points
score after adjudication from 416 valid qsos:
[final score] is: ( (353+0) x 3 + 63 x 15) x 15 = 30060 points (-4.16%)
另外看了一下,
b4r/5 as138 pingtan [aka: haitan]   add   iota dxpn ms mix 24h hp 1020 84 550368
b7p/7 as131 hailing   edit   iota dxpn ms mix 24h hp 646 63 280098
http://iotacontest.com/contest/iota/2010/finalscore.php?searchcall=b7p%2f7
离线BD2RJ
只看该作者 1楼 发表于: 2010-10-12
这个不明白,那位老大给解释一下?
离线BA7NQ
只看该作者 2楼 发表于: 2010-10-12
b7p的海鲜团给b4r pk掉了!
离线肥M
只看该作者 3楼 发表于: 2010-10-12
哈哈哈,无心恋战了,太多mm了。
离线BD7OZG
只看该作者 4楼 发表于: 2010-10-12
成绩已经公布
下期继续努力
