  • 3726阅读
  • 9回复
现在14.070上的PSK是什么比赛 怎么回复? [复制链接]
离线bg3qjf
只看楼主 倒序阅读 0楼 发表于: 2010-10-02
刚听到14.070上很多人 估计是比赛 回复是一堆   407jo9g   这回复串是什么意思?
离线BD4XI
只看该作者 1楼 发表于: 2010-10-02
我这边听不到
离线bg3qjf
只看该作者 2楼 发表于: 2010-10-02
sp3slo   这个电台发的 我看是发一个 回一个   psk-63模式   不知道这个代表什么
只看该作者 3楼 发表于: 2010-10-03
离线bg3qjf
只看该作者 4楼 发表于: 2010-10-03
ba7ck,请具体解释一下,sorry,my english is poor.
只看该作者 5楼 发表于: 2010-10-03
你知道多少,我就知道多少 扫地民工围观蝌蚪。。。
离线BG6IF
只看该作者 6楼 发表于: 2010-10-03
the 5th epc psk63 qso party 2010
the european psk club has the honour to invite radio amateurs from all over the world to participate in the 5th epc psk63 qso party 2010. the objective of the competition is to establish as many contacts as possible between radio amateurs around the world by using the bpsk63 mode. everybody can work everybody for qso and multiplier credit. the contest will be held from 00:00 utc to 24:00 utc on sunday, 21st november, 2010. the rules and other information can be found at our website. this is strictly bpsk63 contest, no other modes are allowed. the maximum output power is 100 watts. recommended frequencies are: 160 meters (1.838 – 1.840 mhz), 80 meters (3.582 – 3.590 mhz), 40 meters (7.040 – 7.050 mhz), 20 meters (14.072 – 14.080 mhz), 15 meters (21.072 – 21.080 mhz), and 10 meters (28.072 – 28.080 mhz). please note that since this year epc members should send signal report plus 5-digit epc membership number (example – 599 epc00001). please make sure that you don't separate «epc» from the «number», and you don't use any characters between. please make sure that your epc number consists of 5 digits! other stations should send signal report plus qso number, starting 001 (example – 599 001). all the very best and see you all in the 5th epc psk63 qso party 2010!
欧洲psk俱乐部的第五届psk63竞赛.
离线BD4HZ
只看该作者 7楼 发表于: 2010-10-03
是欧洲epc俱乐部的比赛,主要是用psk63模式信号报告599001或者599加epc会员编号,比如我的应该是59911440。附件是我的epc会员证
离线bg3qjf
只看该作者 8楼 发表于: 2010-10-04
感谢8楼 我查到的是 非会员好像是 nr+网格4位
离线BG6IF
只看该作者 9楼 发表于: 2010-10-08
