  • 7065阅读
  • 34回复
给喜欢DIY的朋友贴片管子的代码转换表 [复制链接]
离线bg5in
只看楼主 倒序阅读 0楼 发表于: 2010-09-30
直插封装的型号     贴片的型号
9011             1t
9012             2t
9013             j3
9014             j6
9015             m6
9016             y6
9018             j8
s8050             j3y
s8550             2ty
8050             y1
8550             y2
2sa1015           ba
2sc1815           hf
2sc945             cr
mmbt3904           1am
mmbt3906           2a
mmbt2222           1p
mmbt5401           2l
mmbt5551           g1
mmbta42           1d
mmbta92           2d
bc807-16           5a
bc807-25           5b
bc807-40           5c
bc817-16           6a
bc817-25           6b
bc817-40           6c
bc846a             1a
bc846b             1b
bc847a             1e
bc847b             1f
bc847c             1g
bc848a             1j
bc848b             1k
bc848c             1l
bc856a             3a
bc856b             3b
bc857a             3e
bc857b             3f
bc858a             3j
bc858b             3k
bc858c             3l
2sa733             cs
un2111             v1
un2112             v2
un2113             v3
un2211             v4
un2212             v5
un2213             v6
2sc3356           r23
2sc3838           ad
离线bg5in
只看该作者 1楼 发表于: 2010-09-30
续一:
code device manufacturer base package leaded equivalent/data
0 2sc3603 nec cx sot173 npn rf ft 7ghz
5 sstpad5 sil j - pad-5 5pa leakage diode
p01 pdta143et phi n sot23 pnp dtr 4k7+4k7
t01 pdta143et phi n sot23 pnp dtr 4k7+4k7
1 gali-1 mc az sot89 dc-8ghz mmic amp 12db gain
10 sstpad10 sil j - pad-10 10pa leakage diode
11 so2369r sgs r sot23r 2n2369
2 bst82 phi m - n-ch mosfet 80v 175ma
2 mrf5711l mot x sot143 npn rf mrf571
2 dtcc114t roh n - 50v 100ma npn sw + 10k base res
2 gali-2 mc az sot89 dc-8ghz mmic amp 16db gain
p02 pdtc143et phi n sot23 npn 4k7+4k7 bias res
t02 pdtc143et phi n sot23 npn 4k7+4k7 bias res
3 gali-3 mc az sot89 dc-3ghz mmic amp 22db gain
3 dtc143te roh n emt3 npn dtr r1 4k7 50v 100ma
3 dtc143tua roh n sc70 npn dtr r1 4k7 50v 100ma
3 dtc143tka roh n sc59 npn dtr r1 4k7 50v 100ma
4 dtc114tca roh n sot23 npn dtr r1 10k 50v 100ma
4 dtc114te roh n emt3 npn dtr r1 10k 50v 100ma
4 dtc114tua roh n sc70 npn dtr r1 10k 50v 100ma
4 dtc114tka roh n sc59 npn dtr r1 10k 50v 100ma
4 mrf5211l mot x sot143 pnp rf mrf521
4 gali-4 mc az sot89 dc-4ghz mmic amp 17.5 dbm
-4 pmss3904 phi n sot323 2n3904
t04 pmbs3904 phi n sot23 2n3904
5 gali-4 mc az sot89 dc-4ghz mmic amp 18 dbm o/p
5 dtc124te roh n emt3 npn dtr r1 22k 50v 100ma
5 dtc124tua roh n sc70 npn dtr r1 22k 50v 100ma
5 dtc124tka roh n sc59 npn dtr r1 22k 50v 100ma
05f tsdf1205r tfk wq - ft12ghz npn 4v 5ma
6 gali-6 mc az sot89 dc-4ghz mmic amp 115 dbm o/p
6 dtc144te roh n emt3 npn dtr r1 47k 50v 100ma
6 dtc144tua roh n sc70 npn dtr r1 47k 50v 100ma
6 dtc144tka roh n sc59 npn dtr r1 47k 50v 100ma
-6 pmss3906 phi n sot323 2n3906
t06 pmbs3906 phi n sot23 2n3906
20 sstpad20 sil j - pad-20 20pa leakage diode
50 sstpad50 sil j - pad-50 50pa leakage diode
81 so2369ar sgs r sot23r 2n2369a
9 dtc115tua roh n sc70 npn dtr r2 100k 50v 100ma
9 dtc115tka roh n sc59 npn dtr r2 100k 50v 100ma
0a mun5111dw1 mot do sot363 dual pnp dtr 10k+10k
0a dtc125tua roh n sc70 npn dtr r2 100k 50v 100ma
0a dtc125tka roh n sc59 npn dtr r2 100k 50v 100ma
0b mun5112dw1 mot do sot363 dual pnp dtr 22k+22k
0c mun5113dw1 mot do sot363 dual pnp dtr 47k+47k
0d mun5114dw1 mot do sot363 dual pnp dtr 10k+47k
0e mun5115dw1 mot do sot363 dual pnp dtr r1 10k
0f mun5116dw1 mot do sot363 dual pnp dtr r1 4k7
0g mun5130dw1 mot do sot363 dual pnp dtr 1k0+1k0
0h mun5131dw1 mot do sot363 dual pnp dtr 2k2+2k2
0j mun5132dw1 mot do sot363 dual pnp dtr 4k7+4k7
0k mun5133dw1 mot do sot363 dual pnp dtr 4k7+47k
0l mun5134dw1 mot do sot363 dual pnp dtr 22k+47k
0m mun5135dw1 mot do sot363 dual pnp dtr 2k2+47k
1 2sc3587 nec cx - npn rf ft10ghz
1 ba277 phi i sod523 vhf tuner band switch diode
1 (red) bb669 sie i sod323 56-2.7 pf varicap
10 mrf9411l mot x sot143 npn rf 8ghz mrf941
10a pzm10nb2a phi a sot346 dual ca 10v 0.3w zener
10v pzm10nb phi c sot346 10v 0.3w zener
10y bzv49-c10 phi o sot89 10v 1w zener
11 mrf9511l mot x sot143 npn rf 8ghz mrf951
11 mun5311dw1 mot dp sot363 npn/pnp dtr 10k+10k
11 pdta114eu phi n sot416 pnp dtr
p11 pdta114tt phi n sot23 pnp dtr
t11 pdta114tt phi n sot23 pnp dtr
11a pzm11nb2a phi a sot346 dual ca 11v 0.3w zener
11a mmbd1501a nat c sot23 si diode 200v 100ma
11v pzm11nb phi c sot346 11v 0.3w zener
11y bzv49-c11 phi o sot89 11v 1w zener
12 mun5312dw1 mot dp sot363 npn/pnp dtr 22k+22k
12 dta123eua rho n sc70 pnp dtr 2k2+2k2 50v 100ma
12 dta123eka rho n sc59 pnp dtr 2k2+2k2 res 50v 100ma
p12 pdtc114tt phi n sot23 npn dtr
t12 pdtc114tt phi n sot23 npn dtr
12a mmbd1502a nat k sot23 si diode 200v 100ma
12a pzm12nb2a phi a sot346 dual ca 12v 0.3w zener
12e zc2812e zet d sot23 dual series rf schottky15v 20ma
12v pzm12nb phi c sot346 12v 0.3w zener
12y bzv49-c12 phi o sot89 12v 1w zener
13 dta143eua rho n sc70 pnp dtr 4k7+4k7 50v 100ma
13 dta143eka rho n sc59 pnp dtr 4k7+4k7 50v 100ma
13 dta143eca rho n sot23 pnp dtr 4k7+4k7 50v 100ma
13t bc846bpn phi n sot363 bc546b
13s bas125 sie c sot23 schottky sw 24v 100ma
13s bas125w sie c sot323 schottky sw 24v 100ma
13 ma4cs103a m/a c sot23 schottky rf 20v 100ma
13 mun5313dw1 mot dp sot363 npn/pnp dtr 47k+47k
13a mmbd1503a nat d sot23 dual si diode 200v 100ma
13a pzm13nb2a phi a sot346 dual ca 13v 0.3w zener
13e zc2813e zet a sot23 dual ca rf schottky15v 20ma
13v pzm13nb phi c sot346 13v 0.3w zener
13y bzv49-c13 phi o sot89 13v 1w zener
14s bas125-04 sie d sot23 dual series schottky 25v 100ma
14s bas125-04w sie d sot323 dual series schottky 25v 100ma
14 bat114-099r sie dq - quad schottky crossover ring
14 dta114eua roh n sc70 pnp dtr 10k + 10k
14 dta114eka roh n sc59 pnp dtr 10k + 10k
14 mun5314dw1 mot dp sot363 npn/pnp dtr 10k r1
14 dta114eca roh n sot23 pnp dtr 10k + 10k
14a mmbd1504a nat b - dual cc si diode 200v 100ma
15s bas125-05 sie b sot23 dual cc schottky 25v 100ma
15s bas125-05w sie b sot323 dual cc schottky 25v 100ma
15 dta124eua roh n sc70 pnp dtr 30v 50ma 22k+22k
15 dta124eka roh n sc59 pnp dtr 30v 50ma 22k+22k
15 dta124eca roh n sot23 pnp dtr 30v 50ma 22k+22k
15 mun5315dw1 mot dp sot363 npn/pnp dtr 10k r1
15 mmbt3960 mot n - 2n3960
15a mmbd1505a nat a - dual ca si diode 200v 100ma
15a pzm15nb2a phi a sot346 dual ca 15v 0.3w zener
15v pzm15nb phi c sot346 15v 0.3w zener
15y bzv49-c15 phi o sot89 15v 1w zener
p16 pdtc114et phi n sot23 npn dtr
t16 pdtc114eu phi n sot323 npn dtr
16s bas125-06 sie a sot23 dual ca schottky 25v 100ma
16s bas125-06w sie a sot323 dual ca schottky 25v 100ma
16 mun5316dw1 mot dp sot363 npn/pnp dtr 4k7 r1
16 dta144eua roh n sc70 pnp dtr 30v 50ma 47k+47k
16 dta144eka roh n sc59 pnp dtr 30v 50ma 47k+47k
16v pzm16nb phi c sot346 16v 0.3w zener
16y bzv49-c16 phi o sot89 16v 1w zener
17s bas125-07 sie s sot143 dual schottky 25v 100ma
17s bas125-07w sie s sot343 dual schottky 25v 100ma
p17 pdtc124et phi n sot23 npn dtr
t17 pdtc124eu phi n sot323 npn dtr
18 bfp181t tfk x - npn rf ft 7.8ghz 10v 20ma
18 pdtc143zk phi n sot346 npn dtr 4k7+47k
p18 pdtc143zt phi n sot23 npn dtr 4k7+47k
t18 pdtc143zt phi n sot23 npn dtr 4k7+47k
18v pzm18nb phi c sot346 18v 0.3w zener
18y bzv49-c18 phi o sot89 18v 1w zener
19 pdta143zk phi n sot346 pnp dtr 4k7+47k
19 dta115eua rho n sc70 pnp dtr 100k+100k 50v 100ma
19 dta115eka rho n sc59 pnp dtr 100k+100k 50v 100ma
p19 pdta143zt phi n sot23 pnp dtr 4k7+47k
t19 pdta143zt phi n sot23 pnp dtr 4k7+47k
100 sstpad100 sil j sot23 pad-100 100pa leakage diode
101 pzm10nb1 phi c sot346 10v 0.3w zener
102 pzm10nb2 phi c sot346 10v 0.3w zener
103 pzm10nb3 phi c sot346 10v 0.3w zener
111 pzm11nb1 phi c sot346 11v 0.3w zener
111 dta113zua roh n sc70 pnp dtr 1k+10k 50v 100ma
112 pzm11nb2 phi c sot346 11v 0.3w zener
113 pzm11nb3 phi c sot346 11v 0.3w zener
113 dta143zua roh n sc70 pnp dtr 4k7+47k 50v 100ma
121 pzm12nb1 phi c sot346 12v 0.3w zener
121 dtc113zua roh n sc70 npn dtr 1k+10k 50v 100ma
122 pzm12nb2 phi c sot346 12v 0.3w zener
123 pzm12nb3 phi c sot346 12v 0.3w zener
123 dtc143zua roh n sc70 npn dtr 4k7+47k 50v 100ma
131 pzm13nb1 phi c sot346 13v 0.3w zener
132 pzm13nb2 phi c sot346 13v 0.3w zener
132 dta123jua roh n sc70 pnp dtr 2k2+47k 50v 100ma
133 pzm13nb3 phi c sot346 13v 0.3w zener
142 dta123jua roh n sc70 npn dtr 2k2+47k 50v 100ma
151 pzm15nb1 phi c sot346 15v 0.3w zener
152 pzm15nb2 phi c sot346 15v 0.3w zener
153 pzm15nb3 phi c sot346 15v 0.3w zener
156 dta144vua roh n sc70 pnp dtr 47k+10k 50v 100ma
161 pzm16nb1 phi c sot346 16v 0.3w zener
162 pzm16nb2 phi c sot346 16v 0.3w zener
163 pzm16nb3 phi c sot346 16v 0.3w zener
166 dtc144vua roh n sc70 npn dtr 47k+10k 50v 100ma
179 fmmt5179 zet n - 2n5179
181 pzm18nb1 phi c sot346 18v 0.3w zener
182 pzm18nb2 phi c sot346 18v 0.3w zener
183 pzm18nb3 phi c sot346 18v 0.3w zener
1a bc846a phi n sot23 bc546a
1a bc846at phi n sot416 bc546a
1ap bc846a phi n sot23 bc546a
1at bc846a phi n sot23 bc546a
1at bc846aw phi n sot323 bc546a
1a- bc846aw phi n sot323 bc546a
1a fmmt3904 zet n sot23 2n3904
1a mmbt3904 mot n sot23 2n3904
1a irlml2402 ir f sot23 n-ch mosfet 20v 0.9a
p1a pmmt3904 phi n sot23 2n3904
p1a pxt3904 phi n sot89 2n3904
t1a pmmt3904 phi n sot23 2n3904
t1a pmst3904 phi n sot323 2n3904
-1a pmst3904 phi n sot323 2n3904
1am mmbt3904l mot n sot23 2n3904
1b bc846b phi n sot23 bc546b
1b bc846bt phi n sot416 bc546b
1bp bc846b phi n sot23 bc546b
1bt bc846b phi n sot23 bc546b
1bt bc846bw phi n sot323 bc546b
1b- bc846bw phi n sot323 bc546b
1b fmmt2222 zet n sot23 2n2222
1b mmbt2222 mot n sot23 2n2222
1b irlml2803 ir f sot23 n-ch mosfet 30v 0.9a
p1b pmbt2222 phi n sot23 2n2222
t1b pmbt2222 phi n sot23 2n2222
t1b pmst2222 phi n sot233 2n2222
-1b pmst2222 phi n sot323 2n2222
1bs bc817upn sie n sc74 -
1cp bap50-05 phi b sot23 dual cc gp rf pin diode
1c fmmt-a20 zet n sot23 mpsa20
1c mmbta20l mot n sot23 mps3904
1c irlml6302 ir f sot23 p-ch mosfet 20v 0.6a
1cs bc847s sie - sot363 bc457
1dp bc846 phi n sot23 bc456
1dt bc846 phi n sot23 bc456
1dt bc846w phi n sot323 bc456
1d- bc846w phi n sot323 bc456
1d mmbta42 mot n sot23 mpsa42 300v npn
1d irlml5103 ir f sot23 p-ch mosfet 30v 0.6a
p1d pmbta42 phi n sot23 mpsa42 300v npn
p1d pxta42 phi n sot89 mpsa42 300v npn
t1d pmbta42 phi n sot23 mpsa42 300v npn
t1d pmsta42 phi n sot323 mpsa42 300v npn
1ds bc846u sie n sc74 bc456
1ds bc846u sie - sot363 bc456
1dn 2sc4083 roh n - npn 11v 3.2ghz tv tuners
1dr msd1328r mot n sot346 npn gp 25v 500ma
1e bc847a phi n sot23 bc547a
1e bc847at phi n sot416 bc547a
1ep bc847a phi n sot23 bc547a
1et bc847a phi n sot23 bc547a
1et bc847a phi n sot323 bc547a
1e- bc847a phi n sot323 bc547a
1er bc847ar phi r sot23r bc547a
1e fmmt-a43 zet n - mpsa43
1e mmbta43 mot n sot23 mpsa43 200v npn
t1e pmbta43 mot n sot23 mpsa43 200v npn
t1e pmsta43 mot n sot323 mpsa43 200v npn
1es bc847a sie n sot23 bc457
1es bc847aw sie n sot323 bc457
1en 2sc4084 roh n - npn 20v 2.0ghz tv tuners
1f bc847b phi n sot23 bc547b
1f bc847bt phi n sot416 bc547b
1fs bc847b sie n sot23 bc547b
1fs bc847bt sie n sc75 bc547b
1fs bc847bw sie n sot323 bc547b
1fp bc847b phi n sot23 bc547b
1ft bc847b phi n sot23 bc547b
1ft bc847bw phi n sot323 bc547b
1f- bc847bw phi n sot323 bc547b
1fr bc847br phi r sot23r bc547b
1f mmbt5550 mot n sot23 2n5550 140v npn
p1f pmbt5550 phi n sot23 2n5550 140v npn
t1f pmbt5550 phi n sot23 2n5550 140v npn
t1f pmst5550 phi n sot323 2n5550 140v npn
1fz fmbt5550 zet n sot23 2n5550 140v npn
1g bc847c phi n sot23 bc547c
1g bc847ct phi n sot416 bc547c
1gp bc847c phi n sot23 bc547c
1gt bc847cw phi n sot323 bc547c
1g- bc847cw phi n sot323 bc547c
1gs bc847c sie n sot23 bc547c
1gs bc847cw sie n sot323 bc547c
1gr bc847cr phi r sot23r bc547c
1gt soa06 sgs n sot23 mpsa06
1g fmmt-a06 zet n sot23 mpsa06
1g mmbta06 mot n sot23 mpsa06
p1g pmmta06 phi n sot23 mpsa06
t1g pmmta06 phi n sot23 mpsa06
t1g pmmta06 phi n sot323 mpsa06
1gm mmbta06 mot n sot23 mpsa06
1hp bc847 phi n sot23 bc547
1ht bc847 phi n sot23 bc547
离线bg5in
只看该作者 2楼 发表于: 2010-09-30
续二:
ch enh tmosfet 1.75a
3gr bc857cr phi r sot23r bc557cr
3hp bc857c phi n sot23 bc557
3ht bc857c phi n sot23 bc557
1ht bc847w phi n sot323 bc547
1h- bc847w phi n sot323 bc547
1h fmmt-a05 zet n - mpsa05
1h mmbta05 mot n sot23 mpsa05
t1h mmbta05 phi n sot323 mpsa05
1ht soa05 sgs n sot23 mpsa05
1j bc848a phi n sot23 bc548a
1js bc848a sie n sot23 bc548a
1js bc848aw sie n sot323 bc548a
1j fmmt2369 zet n sot23 2n2369
1j mmbt2369 mot n sot23 mps2369
1js bcv61a sie vq sot143 npn current mirror hfe 180
1jp bcv61a phi vq sot143 npn current mirror hfe 180
p1j pmbt2369 phi n sot23 2n2369
t1j pmbt2369 phi n sot23 2n2369
t1j pmbt2369 phi n sot323 2n2369
1ja mmbt2369a mot n sot23 mps2369a
1jr bc848ar phi r sot23r bc548a
1jz bc848a zet n sot23 bc548a
1k bc848b itt n sot23 bc548b
1kp bc848b phi n sot23 bc548b
1ks bc848b sie n sot23 bc548b
1ks bc848bw sie n sot323 bc548b
1k mmbt6428 mot n sot23 mpsa18 50v
p1k pmbt6428 phi n sot23 mpsa18 50v
t1k pmbt6428 phi n sot23 mpsa18 50v
t1k pmbt6428 phi n sot323 mpsa18 50v
1k fmmt4400 zet n sot23 2n4400
1ks bcv61b sie vq sot143b npn current mirror hfe 290
1kp bcv61b phi vq sot143b npn current mirror hfe 290
1kr bc848br phi r sot23r bc548b
1km mmbt6428l mot n sot23 mpsa18 50v
1kz fmmt4400 zet n sot23 2n4400
1l bc848c itt n sot23 bc548c
1lp bc848c phi n sot23 bc548c
1ls bc848c sie n sot23 bc548c
1ls bc848cw sie n sot323 bc548c
1l mmbt6429 mot n - mpsa18 45v
1l fmmt4401 zet n - 2n4401
1l bcv61c sie vq sot143b npn current mirror hfe 520
1lp bcv61c phi vq sot143b npn current mirror hfe 520
p1l pmbt6429 phi n sot23 mpsa18 45v
t1l pmbt6429 phi n sot23 mpsa18 45v
t1l pmbt6429 phi n sot323 mpsa18 45v
1lr bc848cr phi r sot23r bc548c
1mp bc848 phi n sot23 bc548
1m mmbta13 mot n sot23 mpsa13 darlington
1mp bcv61 phi vq sot143b npn current mirror
1m fmmt-a13 zet n sot23 mpsa13
p1m pxta13 phi n sot89 mpsa13 darlington
p1m pmbta13 phi n sot23 mpsa13 darlington
t1m pmbta13 phi n sot23 mpsa13 darlington
1n fmmt-a14 zet n sot23 mpsa14
1n mmbta14 mot n sot23 mpsa14 darlington
1n5 ztx11n15df zet n sot23 npn 15v 3a low saturation v
p1n pmbta14 mot n sot23 mpsa14 darlington
p1n pxta14 mot n sot89 mpsa14 darlington
t1n pmbta14 mot n sot23 mpsa14 darlington
1p fmmt2222a zet n - 2n2222a
1p mmbt2222a mot n sot23 2n2222a
1p bc847pn sie di - pnp/npn separate pair gp af
p1p pmbt2222a phi n sot23 2n2222a
p1p pxt2222a phi n sot89 2n2222a
t1p pmbt2222a phi n sot23 2n2222a
t1p pmst2222a phi n sot323 2n2222a
1q mmbt5088 mot n sot23 mpsa18 vce 30v
p1q pmbt5088 phi n sot23 mpsa18 vce 30v
t1q pmbt5088 phi n sot23 mpsa18 vce 30v
t1q pmst5088 phi n sot323 mpsa18 vce 30v
1r mmbt5089 mot n sot23 mpsa18 vce 25v
t1r pmst5089 phi n sot323 mpsa18 vce 25v
1s mmbt2369a nat n sot23 2n2369a 500mhz sw npn
1s msc3130 mot h sot346 npn rf ft 1.4ghz 10v
1t mmbt3960a mot n - 2n3960a
1u mmbt2484l mot n sot23 mpsa18
1v mmbt6427 mot h sot23 2n6426/7 darlington npn
1vp bf820 phi n sot23 npn 300v 50ma bf420
1vt bf820 phi n sot23 npn 300v 50ma bf420
1vt bf820w phi n sot323 npn 300v 50ma bf420
1v- bf820w phi n sot323 npn 300v 50ma bf420
1w fmmt3903 zet n sot23 2n3903
1wp bf821 phi n sot23 pnp 300v 50ma bf421
1wt bf821 phi n sot23 pnp 300v 50ma bf421
1w t bf822w phi n sot323 pnp 300v 50ma bf421
1w - bf822w phi n sot323 pnp 300v 50ma bf421
1x mmbt930l mot n sot23 mps3904
1xp bf822 phi n sot23 npn 250v 50ma bf422
1xt bf822 phi n sot23 npn 250v 50ma bf422
1y mmbt3903 mot n sot23 2n3903
1yp bf823 phi n sot23 pnp 250v 50ma bf423
1yt bf823 phi n sot23 pnp 250v 50ma bf423
1z bas70-06 zet a sot23 dual rf ca schottky diode
1z mmbt6517 mot n sot23 2n6517 npn vce 350v
2 bat62-02w sie i scd80 bat16 schottky diode
2 (blue) bar64-03w sie i sod323 pin diode
2 2sc3604 nec cx - npn rf ft8ghz 12db@2ghz
2 (white) bb439 sie i sod323 29-5 pf varicap
20 mrf5811 mot x sot143 npn rf ft 5ghz 0.2a
-20 pdtc114wu phi n sot323 npn dtr
20f tsdf1220 tfk x sot143 ft 12ghz npn 6v 20ma
20v pzm20nb phi c sot346 20v 300mw zener
20y bzv49-c20 phi o sot89 20v 1w zener
21 gali-21 mc az sot89 dc-8ghz mmic amp 14 db gain
22 mmbt4209 nat n sot23 pnp sw 850mhz 2n4209
22 dtc123eua rho n sc70 npn dtr 2k2+2k2 50v 100ma
22 dtc123eka rho n sc59 npn dtr 2k2+2k2 50v 100ma
22v pzm22nb phi c sot346 22v 300mw zener
22y bzv49-c22 phi o sot89 22v 1w zener
23 mmbt3646 nat n sot23 npn sw 350mhz 2n3646
23 dtc143eua roh n sc70 pnp dtr 50v 100ma 4k7+ 4k7
23 dtc143eka roh n sc59 pnp dtr 50v 100ma 4k7+ 4k7
-23 pdta114tu phi n sot323 pnp dtr r1 10k
t23 pdta114tu phi n sot323 pnp dtr r1 10k
24 mmbd2101 nat c sot23 si diode 100v 200ma
24 dtc114eca roh n sot23 npn dtr 50v 100ma 10k + 10k
24 dtc114eua roh n sc70 npn dtr 50v 100ma 10k + 10k
24 dtc114eka roh n sc59 npn dtr 50v 100ma 10k + 10k
24 2sc5006 nec n - npn rf ft 4.5ghz @3v 7ma
-24 pdtc114tu phi n sot323 npn dtr r1 10k
t24 pdtc114tu phi n sot323 npn dtr r1 10k
24v pzm24nb phi c sot346 24v 300mw zener
24y bzv49-c24 phi o sot89 24v 1w zener
25 mmbd2102 nat k sot23 si diode 100v 200ma
25 dtc124eca roh n sot23 npn dtr 50v 100ma 22k + 22k
25 dtc124eka roh n sc59 npn dtr 50v 100ma 22k + 22k
25 dtc124eua roh n sc70 npn dtr 50v 100ma 22k + 22k
26 mmbd2103 nat d sot23 dual mmbd1201
26 dtc144eka roh n sc59 npn dtr 50v 30ma 47k + 47k
26 dtc144eua roh n sc70 npn dtr 50v 30ma 47k + 47k
27 mmbd2104 nat b sot23 dual cc mmbd1201
27v pzm27nb phi c sot346 27v 300mw zener
27y bzv49-c27 phi o sot89 27v 1w zener
28 bfp280t tfk w - npn rf ft 7ghz 8v 10ma
28 mmbd2105 nat a sot23 dual ca mmbd1201
-28 pdta114wu phi n sot323 pnp dtr
29 mmbd1401 nat c sot23 si diode 200v 100ma
29 dtc115ee roh n emt3 npn dtr 100k +100k 50v 20ma
29 dtc115eua roh n sc70 npn dtr 100k +100k 50v 20ma
29 dtc115eka roh n sc59 npn dtr 100k +100k 50v 20ma
200 sstpad200 sil j - pad-200 200pa leakage diode
201 pzm20nb1 phi c sot346 20v 300mw zener
202 pzm20nb2 phi c sot346 20v 300mw zener
203 pzm20nb3 phi c sot346 20v 300mw zener
221 pzm22nb1 phi c sot346 22v 300mw zener
222 pzm22nb2 phi c sot346 22v 300mw zener
223 pzm22nb3 phi c sot346 22v 300mw zener
241 pzm24nb phi c sot346 24v 300mw zener
242 pzm24nb phi c sot346 24v 300mw zener
243 pzm20nb phi c sot346 24v 300mw zener
271 pzm2.7nb1 phi c sot346 2.7v 300mw zener
272 pzm2.7nb2 phi c sot346 2.7v 300mw zener
2a mmbt3906l mot n sot23 2n3906
2a mmbt3906w mot n sot323 2n3906
2a fmmt3906 zet n sot23 2n3906
t2a pmbt3906 phi n sot23 2n3906
t2a pmst3906 phi n sot323 2n3906
p2a pmbt3906 phi n sot23 2n3906
p2a pxt3906 phi o sot89 2n3906
2a4 pzm2.4nb2a phi a sot346 dual 2.4v cc zener
2a7 pzm2.7nb2a phi a sot346 dual 2.7v cc zener
2b bc849b itt n sot23 bc549b
2bs bc849b sie n sot23 bc549b
2bs bc849bw sie n sot323 bc549b
2bp bc849b phi n sot23 bc549b
2bt bc849bw phi n sot323 bc549b
2b- bc849bw phi n sot323 bc549b
2b fmmt2907 zet n sot23 2n2907
2b mmbt2907 mot n sot23 mps2907
p2b pmbt2907 phi n sot23 2n2907
t2b pmbt2907 phi n sot23 2n2907
2br bc849br phi r sot23r bc549b
2bz fmmt2907 zet n sot23 2n2907
2c bc849c itt n sot23 bc549c
2cs bc849c sie n sot23 bc549c
2cs bc849cw sie n sot323 bc549c
2cp bc849c phi n sot23 bc549c
2ct bc849c phi n sot23 bc549c
2ct bc849cw phi n sot323 bc549c
2c- bc849cw phi n sot323 bc549c
2c mmbta70 mot n sot23 mpsa70
2cr bc849cr phi r sot23r bc549c
2cz fmmta70 zet n sot23 mpsa70
2d mmbta92 mot n sot23 mpsa92 pnp vce 300v
p2d pmbta92 phi n sot23 mpsa92 pnp vce 300v
p2d pxta92 phi o sot89 mpsa92 pnp vce 300v
t2d pmbta92 phi n sot23 mpsa92 pnp vce 300v
t2d pmsta92 phi n sot323 mpsa92 pnp vce 300v
2e mmbta93 mot n sot23 mpsa93 pnp vce 200v
2e fmmt-a93 zet n sot23 mpsa93
t2e pmbta93 phi n sot23 mpsa93 pnp vce 200v
t2e pmsta93 phi n sot323 mpsa93 pnp vce 200v
2f bc850b itt n sot23 bc550b
2fs bc850b sie n sot23 bc550b
2fs bc850bw sie n sot323 bc550b
2fp bc850b phi n sot23 bc550b
2ft bc850b phi n sot23 bc550b
2ft bc850bw phi n sot323 bc550b
2f- bc850bw phi n sot323 bc550b
2f fmmt2907a zet n sot23 2n2907a
2f mmbt2907a mot n sot23 mps2907a
2f mmbt2907aw mot n sot323 mps2907a
p2f pmbt2907a phi n sot23 2n2907a
p2f pxt2907a phi o sot89 2n2907a
t2f pmbt2907a phi n sot23 2n2907a
t2f pmbt2907a phi n sot323 2n2907a
2fr bc850br phi r sot23r bc550b
2g bc850c itt n sot23 bc550c
2gs bc850c sie n sot23 bc550c
2gp bc850c phi n sot23 bc550c
2gt bc850c phi n sot323 bc550c
2gt bc850cw phi n sot323 bc550c
2g- bc850cw phi n sot323 bc550c
2g fmmt-a56 zet n sot23 mpsa56
2g mmbta56 mot n sot23 mpsa56
p2g pmbta56 phi n sot23 mpsa56
t2g pmbta56 phi n sot23 mpsa56
t2g pmsta56 phi n sot323 mpsa56
2gm mmbta56 mot n sot23 mpsa56
2gr bc850cr phi r sot23r bc550c
2gt soa56 sgs n sot23 mpsa56
2h fmmt-a55 zet n sot23 mpsa55
2ht soa55 sgs n sot23 mpsa55
2h mmbta55 mot n sot23 mpsa55
t2h pmbta55 phi n sot23 mpsa55
t2h pmsta55 phi n sot323 mpsa55
2j mmbt3640 mot n sot23 mps3640 pnp sw
2k fmmt4402 zet n sot23 2n4402
2k mmbt8598 mot n - 2n4125 pnp 60v
2l mmbt5401 mot n sot23 2n5401 pnp 150v
2l fmmt4403 zet n sot23 2n4403
p2l pmbt5401 phi n sot23 2n5401 pnp 150v
t2l pmbt5401 phi n sot23 2n5401 pnp 150v
t2l pmst5401 phi n sot323 2n5401 pnp 150v
2m fmmt5087 zet n sot23 2n5087
2m mmbt404 mot n sot23 pnp-chopper 24v 150ma
2n mmbt404a mot n sot23 pnp-chopper 35v 150ma
2n0 zxt11n20df zet n sot23 npn 20v 2.5a low sat switch
2p fmmt2222r zet r sot23r 2n2222
2p mmbt5086 mot n sot23 2n5086
2q mmbt5087 mot n sot23 2n5087
2r hsms-8102 hp z sot23 10-14ghz schottky mixer pair
2t so4403 sgs n sot23 2n4403
2t mmbt4403 mot n sot23 2n4403
p2t pmbt4403 phi n sot23 2n4403
p2t pxt4403 phi o sot89 2n4403
t2t pmbt4403 phi n sot23 2n4403
t2t pmst4403 phi n sot323 2n4403
2t ht2 zet n sot23 pnp 80v 100ma
2u mmbta63 mot n sot23 mpsa63 darlington
t2u pmbta63 phi n sot23 mpsa63 darlington
2v mmbta64 mot n sot23 mpsa64 darlington
p2v pxta64 phi o sot89 mpsa64 darlington
t2v pmbta64 phi h sot23 mpsa64 darlington
2v4 pzm2.4nb phi c sot346 2.4v 300mw zener
2v7 pzm2.7nb phi c sot346 2.7v 300mw zener
2w fmmt3905 zet n sot23 2n3905
2w mmbt8599 mot n - 2n4125 vce 80v pnp
2x so4401 sgs n sot23 2n4401
2x mmbt4401 mot n sot23 2n4401
p2x pmbt4401 phi n sot23 2n4401
p2x pxt4401 phi o sot89 2n4401
t2x pmbt4401 phi n sot23 2n4401
t2x pmst4401 phi n sot323 2n4401
2y4 bzv49-c2v4 phi o sot89 2.4v 1w zener
2y7 bzv49-c2v7 phi o sot89 2.7v 1w zener
2z mmbt6520 mot n sot23 2n6520 pnp vce 350v
2z bas70-04 zet d sot23 dual series rf schottky 70v 15ma
2z5 bas70-05 zet b sot23 dual cc rf schottky 70v 15ma
离线bg5in
只看该作者 3楼 发表于: 2010-09-30
3 bat60a sie i sod323 10v 3a sw schottky
3 bat62-02w sie i scd80 -
30 mun5330dw1 mot dp sot363 npn/pnp dtr 1k0+1k0
30v pzm30nb1 phi c sot346 30v 300mw zener
30y bzv49-c30 phi o sot89 30v 1w zener
301 fdv301n fch m sot23 n-ch 'digital' fet 25v 0.22a
302 fdv302p fch m sot23 p-ch 'digital' fet 25v 0.13a
303 fdv303n fch m sot23 n-ch 'digital' fet 25v 0.68a
304 fdv304p fch m sot23 p-ch 'digital' fet 25v 0.46a
31 mun5331dw1 mot dp sot363 npn/pnp dtr 2k2+2k2
31 mmbd1402 nat k sot23 si diode 200v 100ma
p31 pdta143xt phi n sot23 pnp dtr 4k7+10k
t31 pdta143xt phi n sot23 pnp dtr4k7+10k
32 mun5332dw1 mot dp sot363 npn/pnp dtr 4k7+4k7
32 mmbd1403 nat d sot23 dual si diode 200v 100ma
32 bat32 sie cs - 18ghz zero-bias schottky
p32 pdtc143xt phi n sot23 pnp dtr 4k7+10k
t32 pdtc143xt phi n sot23 pnp dtr 4k7+10ks
33 mun5333dw1 mot dp sot363 npn/pnp dtr 4k7+47k
33 dta143xe roh n emt3 pnp dtr 4k7+10k 50v 100ma
33 dta143xua roh n sc70 pnp sw 4k7+10k bias res 50v 100ma
33 dta143xka roh n sc59 pnp sw 4k7+10k bias res 50v 100ma
33 mmbd1404 nat b sot23 dual cc si diode 200v 100ma
33 gali-33 mc az sot89 dc-4ghz mmic amp 19db gain
33v pzm33nb1 phi c sot346 33 300mw zener
33y bzv49-c33 phi o sot89 33v 1w zener
34 mun5334dw1 mot dp sot363 npn/pnp dtr 22k+47k
34 mmbd1405 nat a sot23 dual ca si diode 200v 100ma
331 nds331n fch m sot23 n-ch mosfet 1.3a 20v
331 pzm3.3nb1 phi c sot346 3.3v 300mw zener
332 pzm3.3nb2 phi c sot346 3.3v 300mw zener
332 nds332n fch m sot23 p-ch mosfet 0.4a, 1a pk, 20v
335 nds335n fch m sot23 n-ch mosfet 70 ma, 1.7a pk, 20v
336 nds336n fch m sot23 p-ch mosfet 0.27a, 1.2a pk, 20v
337 nds337n fch m sot23 n-ch mosfet 50 ma, 2.5a pk 20v
338 nds338n fch m sot23 p-ch mosfet 0.13a, 1.6apk 20v
34 2sc5007 nec n - npn rf ft 7ghz @3v 7ma
340 fdv340p fch m sot23 p-ch mosfet 20v 70 ma
35 mun5335dw1 mot dp sot363 npn/pnp dtr 2k2+47k
35 dta124xe roh n emt3 pnp dtr 22k+47k 50v 50ma
35 dta124xua roh n sc70 pnp dtr 22k+47k 50v 50ma
35 dta124xka roh n sc59 pnp dtr 22k+47k 50v 50ma
351 nds351n fch m sot23 n-ch mosfet 1.1a 30v
352 nds352n fch m sot23 p-ch mosfet 0.5a 20v
355 nds355n fch m sot23 n-ch mosfet 0.1a, 1.6a pk 30v
356 nds356n fch m sot23 p-ch mosfet 0.3a, 1.1a pk 20v
357 nds357n fch m sot23 n-ch mosfet 2.5apk 30v
358 nds358n fch m sot23 p-ch mosfet 0.2a, 1.6a pk 30v
358 fdn358n fch m sot23 p-ch mosfet 0.2a 1.6a pk 30v
360 fdn360p fch m sot23 p-ch mosfet 80ma, 2a pk, 30v
361 pzm3.6nb1 phi c sot346 3.6v 300mw zener
362 pzm3.3nb2 phi c sot346 3.6v 300mw zener
36v pzm36nb1 phi c sot346 36v 300mw zener
36y bzv49-c36 phi o sot89 36v 1w zener
391 pzm3.9nb1 phi c sot346 3.9v 300mw zener
392 pzm3.9nb2 phi c sot346 3.9v 300mw zener
39v pzm39nb1 phi c sot346 39v 300mw zener
39y bzv49-c39 phi o sot89 39v 1w zener
3a bc856a itt n sot23 bc556a
3a bc856at phi n sot416 bc556a
3ap bc856a phi n sot23 bc556a
3at bc856a phi n sot23 bc556a
3as bc856a sie n sot23 bc556a
3at bc856aw phi n sot323 bc556a
3a- bc856aw phi n sot323 bc556a
3a mmbth24 mot n sot23 vhf mixer npn ft 600mhz
3a0 pzm3.0nb2a phi c sot346 dual 3.0v zener
3a3 pzm3.3nb2a phi c sot346 dual 3.3v zener
3a6 pzm3.6nb2a phi c sot346 dual 3.6v zener
3a9 pzm3.9nb2a phi c sot346 dual 3.9v zener
3ar bc856ar phi r sot23r bc556a
3b bc856b itt n sot23 bc556b
3b bc856bt phi n sot416 bc556b
3bp bc856b phi n sot23 bc556b
3bs bc856b sie n sot23 bc556b
3bt bc856b phi n sot23 bc556b
3bt bc856bw phi n sot323 bc556b
3b- bc856bw phi n sot323 bc556b
3b fmmt918 zet n sot23 2n918
3b mmbt918 mot n sot23 2n918
3br bc856br phi r sot23 bc556b
3c fmmta20r zet r sot23r mpsa20
3c bc857 sie do - pnp separate pair gp af
3d bc856 phi n sot23 bc556 hfe 75 min
3dp bc856 phi n sot23 bc556 hfe 75 min
3dt bc856 phi n sot23 bc556 hfe 75 min
3dt bc856w phi n sot323 bc556 hfe 75 min
3d- bc856w phi n sot323 bc556 hfe 75 min
3d mmbth81l mot n sot23 uhf pnp ft 600mhz
3d bc856s sie do - pnp separate pair gp af
3e bc857a phi n sot23 bc557a
3e bc857at phi n sot416 bc557a
3ep bc857a phi n sot23 bc557a
3et bc857a phi n sot23 bc557a
3et bc857a phi n sot323 bc557a
3e- bc857a phi n sot323 bc557a
3e mmbth10 mot n sot23 mpsh10 ft 650mhz
3e fmmt-a42 zet n sot23 mpsa42
3em mmbth10l mot n sot23 vhf amp 650mhz ft
3er bc857ar phi r sot23r bc557a
3ez fmmth10 zet n sot23 npn ft 650mhz
3f bc857b phi n sot23 bc557b
3f bc857bt phi n sot416 bc557b
3fp bc857b phi n sot23 bc557b
3fs bc857b sie n sot23 bc557b
3ft bc857b phi n sot23 bc557b
3ft bc857bw phi n sot323 bc557b
3ft bc857bs phi n sot363 bc557b
3f- bc857bw phi n sot323 bc557b
3fr bc857br phi r sot23r bc557b
3g bc857c phi n sot23 bc557c
3gp bc857c phi n sot23 bc557c
3gs bc857c sie n sot23 bc557c
3gt bc857c phi n sot23 bc557c
3gt bc857cw phi n sot323 bc557c
3g- bc857cw phi n sot323 bc557c
离线bg6ret
只看该作者 4楼 发表于: 2010-09-30
挺好的维修资料,到后面看不懂了,用空格隔开点,看的明白些
离线bd5ik
只看该作者 5楼 发表于: 2010-09-30
我晕你刷屏呀 莫非你也在研究虾米东东?
离线bg4kpt
只看该作者 6楼 发表于: 2010-10-01
宝贵资料,值得收藏。
离线HAMHAM
只看该作者 7楼 发表于: 2010-10-01
好资料!收藏备用!!谢谢!!!
离线bd4iy
只看该作者 8楼 发表于: 2010-10-01
好资料已收藏,谢谢!
离线BH3NEK
只看该作者 9楼 发表于: 2010-10-01
好东西,找好久了。
离线QIE
只看该作者 10楼 发表于: 2010-10-01
好资料!收藏备用!!谢谢!!!
离线BD7FP
只看该作者 11楼 发表于: 2010-10-01
贴片管子的代码转换表 !收藏备用!谢谢!
离线lymachine
只看该作者 12楼 发表于: 2010-10-01
收藏了,谢谢!
离线bd5iq
只看该作者 13楼 发表于: 2010-10-01
作个记名,感谢!
在线BD7JAC
只看该作者 14楼 发表于: 2010-10-01
好人好资料
离线bd2bo
只看该作者 15楼 发表于: 2010-10-01
俺尿泡尿。
在线radioman
只看该作者 16楼 发表于: 2010-10-01
记号。。好资料。。
离线bg3-2-9244
只看该作者 17楼 发表于: 2010-10-01
好资料啊,楼主伟大!!!
离线bi7nv
只看该作者 18楼 发表于: 2010-10-01
好资料,值得收藏
离线BD0FD
只看该作者 19楼 发表于: 2010-10-01
有用,谢谢lz。
要是能搞个表格就更好了,看起来不费劲
