  • 4284阅读
  • 19回复
给YAESU公司的一个技术支持请求…… [复制链接]
离线BD4EP
只看楼主 倒序阅读 0楼 发表于: 2010-09-29
dear yaesu tech support,
this is joseph jiang, bd4ep. some friends and i have bought several ft-450 hf transceivers in the past 2 years. but recently we have found same problem on our ft-450 stations:
1. reset/clone/firmware version check functions are not working. no matter how we try it by following the instructions mentioned in the operation manual, it just not working.
2. the cat port suddenly stopped working. some of ft-450's cat ports were able to communicate with the computer application (pcc-450) without any problem, but recently it was not working any more. some stations can use the pcc-450 to change the vfo frequency(tuning by turn the wheel on pcc-450), but the frequency shows on the pc screen does not change together (ft-450's frequency were changing, feel so weird). we have checked our pc com port again and again, and we are sure that the com port is working fine.
we suspect the problems are with ft-450 firmware, but the upgrade software can't be used since the cat port is not working, and for ft-450 with the 0194 firmware also can't be reprogrammed since the firmware version in ft-450 is already the latest one (some ft-450 cat port is still alive...)
we need some official support from yaesu, as it seems that the problem is not only with specific device, it's a common issue for ft-450 owners.
looking forward to hear feed back from you.
73 de joseph, bd4ep
离线BD6CR
只看该作者 1楼 发表于: 2010-09-29
看来问题挺严重的,不知道yaesu会不会说,你是在中国吗?我们不在中国销售产品。
离线BG4EBC
只看该作者 2楼 发表于: 2010-09-29
对不起,大概是水土不服了。
不知道4闺女的机器也出了一样的问题不?
离线BD4EP
只看该作者 3楼 发表于: 2010-09-29
哎,没有办法。联系了港中的工程师,好像也说不出所以然来。感觉是eprom的程序紊乱,但是没有啥证据。希望yaesu那边会有回复吧。
离线bg1qz
只看该作者 4楼 发表于: 2010-09-29
但愿八重洲不会说等中国zf把巡逻艇修理费付了后咱再商量修电台。
离线wd3010
只看该作者 5楼 发表于: 2010-09-29
给把核准代码办了才是第一的
离线赵宇宁
只看该作者 6楼 发表于: 2010-09-29
上一个帖子回复很多啊,看来450at 马上就要滞销了
离线BG9DW
只看该作者 7楼 发表于: 2010-09-29
当时我的ft-857d自激,给他们去邮件,回复的倒是挺快,但让我联系香港那边,最后懒得管自己搞了。
离线BD4EP
只看该作者 8楼 发表于: 2010-09-29
[quote=赵宇宁]上一个帖子回复很多啊,看来450at 马上就要滞销了[/quote]
滞销不至于的,其实总体性能还是不错的。一些小问题,如果能够克服就ok了。这些问题并不严重影响通联。
离线BD4DLN
只看该作者 9楼 发表于: 2010-09-29
至少这个问题没影响到我正常使用设备
离线bd2bo
只看该作者 10楼 发表于: 2010-09-29
抵制日货!砸了吧。
在线BA2Bi
只看该作者 11楼 发表于: 2010-09-29
抵制日货!砸了吧。
把你817给我再说
离线BD4EP
只看该作者 12楼 发表于: 2010-09-29
把你817给我再说 [表情]
哈哈,这话说得绝了!!!
真想知道现在有多少dxer没在用鬼子电台的。
离线BD5FFK
只看该作者 13楼 发表于: 2010-09-30
看到楼主的帖子,回去在自己的机子上试了一下,似乎没有这个问题。
不过既然多位ham发现这个问题了,也不确定我的机子以后不会出现这样的情况,等待yaesu的答复。到时也请楼主及时把回应的情况公布,关注中……
离线赵宇宁
只看该作者 14楼 发表于: 2010-09-30
但是影响新ham选机时的心情,哈哈哈
离线BG4EBC
只看该作者 15楼 发表于: 2010-09-30
我一直在用的都是国产diy的设备。。。。。
离线fidodido05
只看该作者 16楼 发表于: 2010-09-30
等待答复!!!!!!!!!
离线BD1BSH
只看该作者 17楼 发表于: 2010-10-02
同样等待答复。2种问题都发生在我身上。汗死。。。
离线BH3RVR
只看该作者 18楼 发表于: 2011-03-09
等待答复!!!!!!!!!
你这个骗子 俞锋 呼号:bg4btt   等不到答复就用你这个问题450at 骗我
大家看看他有多bt!
被骗经历: http://ham.hellocq.com/thread-138989-1-1.html
离线BH1AYY
只看该作者 19楼 发表于: 2011-03-09
问题不严重?跑这儿发英文贴,哥们,您是晒e文来了?还是?》我确实看不懂。
但是e文帖子发到这里毫无意义,八重洲不会看到的,个人理解!
