  • 5338阅读
  • 15回复
请教FT-900 扩频 [复制链接]
离线BG4VPA
只看楼主 倒序阅读 0楼 发表于: 2010-09-25
目前在业余段工作,希望能扩成全段的,请指点,谢谢。
离线zdx303
只看该作者 1楼 发表于: 2010-09-25
经典的老鸡
离线soom
只看该作者 2楼 发表于: 2010-09-25
看起来蛮漂亮的,
离线BG8SF
只看该作者 3楼 发表于: 2010-09-25
不在业余段工作,想去哪儿发射?
离线Daniel Lee
只看该作者 4楼 发表于: 2010-09-26
日規的無法擴頻,只有換cpu一途.
离线BG4VPA
只看该作者 5楼 发表于: 2010-10-20
想在30m 以下能连续发射的。
离线BG4VPA
只看该作者 6楼 发表于: 2010-10-20
资料终于找到了,可俺e问很差,哪位能帮个翻译下,谢谢
yaesu u.s.a.
amateur products division
technical support
model: ft-900
date: 24 august 1994
original freq. range: 160-10m (ham)
new freq. range: 1.8-29.99mhx tx
important notice regarding disclosure restrictions
this information is autorized for distribution only to individuals who are members of the u.s. military affiliate radio system, civil air patrol, or other government services specifically permitted by the fcc to use non-type accepted equipment such as that
1,remove the two screws from the top cover, and the two screws from the top rear area of the rear panel, so as to allow the top cover/heat sink to be slid slightly toward the rear. the objective is to be able to see into the cntl-2,locate test points tp3001 and tp3002 on the cntl unit. they are located near the top edge of the board, in the center from left to right. with the transceiver still turned off, connect a jumper (alligator clip is ok) between these 2 test points.
3,hold in the following 4 buttons: [proc], [att], [ipo], and [nb]. while holding them in, turn the transceiver on. release the buttons.
4,the display will indicate off. turn the vfo dial slowly until the display reads on.
5,press the [proc] button to write the new instructions to eeprom.
6,remove the jumper across the test points.
7,replace the case screws. mod is now complete.rea of the rear panel, so as to allow the top cover/heat sink to be slid slightly toward the re
ft-900 remote improvement
name is larry kn4im@n4cii.#chs.sc.usa.na in charleston, sc. if you are the proud owner of a new yaesu ft-900 remoteable mobile and have had teh pleasure of installing the ysk-1l remote cable assy, i am sure you would also like to strangle the idiot that decided you needed two tiny screws to attach the cable to the front of the radio main unit. these tiny, fine threaded, soft brass, typically japanese screws will soon be de-threaded, or broken, or lost! there has got to be a better way.
i just got off the phone with yaesu's experts in cerritos and the parts department. no, there are no parts available, yet, for the ft-900 so i don't have any part number or price to give you to order it. just tell yaesu parts dept that you want the plastic back they have on order for kn4im in south carolina, he'll know what you want.
what i did was to remove the back of my 900's remote head and see if i could install this silly connector to the backshell of the remote head. voila! they even gave me the holes to put screws through. the remote cable end that mates to the radio mounts very nicely to the inside of this plastic shell so that the shell is between the connector and the radio. you can use small screws/nuts with the nuts pointing out to give you the clearance you need. this will allow you to quickly dismount the 900 from the trunk leaving your extra shell (after they deliver it) permanently in the trunk...no screws to break or loose...no tiny phillips to find...just to go portable or fixed. the empty shell will fit the mounting pins and click right into the 900's front panel lock because it's made for it.
i sure hope yaesu retrofits all the previously sold remote kits with a neat looking blank panel in which to mount my radio end of the remote cable instead of having to resort to this method. maybe they will already have the radio end moulded into this blank panel for faster installation and will send me a new cable.....sure they will...73,
larry kn4im 14.105 pkt
离线BG1EAO
只看该作者 7楼 发表于: 2010-10-20
吓死我了,少看了一个0!
离线BG4VPA
只看该作者 8楼 发表于: 2010-10-20
hehe,您说ft-9000啊,没钱买啊
离线bl7ia
只看该作者 9楼 发表于: 2010-10-21
找到 cntl-2 在机後部份,把 tp3001 , tp3002 接上
按以上四个按扭同时,开机
显示 off ,调 vfo 至 on
按 proc 会抄进 eeorom ( 没说几时完成 )
拿走tp3001 tp3002 的接线
死机不要找我呀
离线BG4VPA
只看该作者 10楼 发表于: 2010-10-21
呵呵,谢谢,准备今天就整死他(ft-900)
离线十二少
只看该作者 11楼 发表于: 2010-10-21
勇者無敵,也可以說老子有錢,還有包老師在等你呼叫。
离线BG4VPA
只看该作者 12楼 发表于: 2010-10-24
没有敢请老包 ,自己搞定了,按照说明,找到位置短路那2个测试的点,然后按住那4个键开机即进入调整模式,把菜单2 原来是off 改成on ,然后按下proc 键,就可以了,然后关机,把短路的线拿下,开机就是全段发射了。这样测试天线驻波就好了,知道天线在那个点的谐振好,好调整天线。
离线bh1syn
只看该作者 13楼 发表于: 2016-01-15
回 BG4VPA 的帖子
BG4VPA:没有敢请老包 ,自己搞定了,按照说明,找到位置短路那2个测试的点,然后按住那4个键开机即进入调整模式,把菜单2 原来是off 改成on ,然后按下proc 键,就可以了,然后关机,把短路的线拿下 .. (2010-10-24 12:18)
谢谢楼主 学习了
离线bh2sft
只看该作者 14楼 发表于: 2019-03-08
和七区的HAM换了一台,待几天就到货,不知道大家用的咋样,我是看着样子顺眼才换的,还没找到中文的说明书,大家有什么心得,欢迎灌水。另外,我看里面还需要换纽扣电池,期待不会像ICOM R71那样,没电就没戏的问题。
离线浪漫人生
只看该作者 15楼 发表于: 2019-03-10
ft 900 有出的吗  想收一台
喜欢 电子管 无线电 电脑 军机 研究新产品新技术
喜欢结交同行中的朋友.相互学习共同进步.
黑龙江省鸡西市 电话 13945869035 QQ:1187297
本人新建业余无线电HAM超级群 群号 49944929.人嗷嗷多啊,欢迎加入。
