  • 6051阅读
  • 14回复
Logger32 V3.27于2010-9-4发布 [复制链接]
离线BD4EP
只看楼主 倒序阅读 0楼 发表于: 2010-09-07
虽然稍微晚了两天,不过应该还算是及时吧!logger32的v3.27发布啦!
这次的改动不大,主要是一些bug的修正,及小功能的修改。并未修改菜单项,所以v3.26的汉化包仍可照常使用,不必替换。:)
升级版下载链接(从v3.26到v3.27):http://www.logger32.net/files/lgr32upgrade327.zip
完整版下载链接:http://www.logger32.net/files/lgr32full327.zip
v3.27版本更新信息如下(等有点时间时再翻译给大家,抱歉):
release change notes for ver 3.27.0 as of....... 24 aug 2010
1) major rewrite of the logbook window vertical scrollbar to overcome a number
of reported bugs.
2) cleared a minor bug that showed up when using the qso search option.
3) cleared a bug in the logbook entry window that showed up if radio type was
set to "none"
4) callsigns such as 1b1ab would not show calculated distance and bearing data
because they were "not acceptable for dxcc". a distance and bearing will now
show if a gridsquare reference is entered for these callsigns. a minor editing
bug was also discovered and corrected during the implimentation of these changes
5) introduced a date factor into the dxcc-cw awards table so as to exclude qsos
before 1st jan. 1975. operational note: when displaying dxcc_cw award stats, a w means there's a qso in the logbook (regardless of when), a c means a qso is confirmed on/after jan 1, 1975.
6) added a permanent "comments" pane to the manual "add qso" facility.
7) support added for the perseus receiver (untested). radio modes supported -
lsb, usb, am, cw, rtty, fm, sam and drm. as the perseus emulates the icom message
format, use the icom address setting to set the perseus address.
8) changes made to all logger32 serial ports (radio, so2r radio, rotor, alpha
amplifier, tnc cluster, dvk, cw machine and data terminal). code added to resolve
unexpected removal of usb cables (or powering off of devices) on usb -> serial
ports causing logger32 to hang.
9) added the long-path distance to a new tool tip when the mouse is over the
heading/distance pane.
10) change made to accommodate 425dx activity window where the bulletin number
is 1000 or greater.
11) it was reported that with the audio alerts closed the iota announcements
could still trigger dependent on other user options selected. bug cleared.
12) changes made to the software support for the rc2800px rotor.
13) changed the font color for the output window in the conversion option to
black (it was dark grey)
14) a new "comment" tab has been added to the cluster blocking filters. comment
filtering is not case sensitive. wild cards apply (*text for comments ending with
the text, text* for comments begining with text, and *text* for comments contain
text). filter text may not contain a comma.
15) small change made so as to allow the use of pgup/pgdn to change the cw
machine keying speed when the focus is on the log input window. works for all
configs provided that winkey analogue speed control is turned off
16) the ctl_b function from the log input window now no longer automatically
clears the window.
summary of country database changes:
1) changed:
country prefix from kh5\p to kh5 and country name to "palmyra & jarvis islands"
country name:
oh0 - to "aland islands"
vk9\c - to "cocos - keeling islands"
zl7 - to "chatham islands"
lat/lon:
for 4o: lat=42.47 lon=-19.28
for ri1mv: lat=60.65
adif id:
for 4w\y north yemen (deleted entity) adif 154
for 7o\s south yemen (deleted entity) adif 243
ceoi to ce0i in alternative pref for ce0\z
itu zone for r4w offset from 29 to 30
timezone for 4x to "israel standard time"
timezone for 5a to "south africa standard time"
timezone for e4 to "israel standard time"
timezone for jy to "jordan standard time"
timezone for vp6 to "pacific standard time"
timezone for vp6\d to "pacific standard time"
timezone for yk to "jordan standard time"
2) added:
alternative prefixes:
ee9 to ea9
hy to f
l to lu
og0 to oh0
zt, zu to zs
unique callsigns:
<4u0g> = hb
<ay1zd> = kc4\a
<3y8xsa> = kc4\a
<dx0dx> = 1s
<n5e> = kh5
<to2bnl> = fw
<3h100tw> = bv
<3t100tw> = bv
<3t0tw> = bv
<r22mws> = r
<r90k> = r
<r2mwo> = ua2
<ir0lvc> = is0
<to2z> = fr
<to7zg> = fj
<tx5tes> = fo\p
<vp8ssi> = vp8\sa
3) deleted:
r1an from kc4\a
unique callsign:
<bp0riw> from bv
<cy0tp> from cy0
<kh8si> from kh8\s
<kh9/n2wb> from kh9
<n2oo/kh9> from kh9
<n6mz/kh9> from kh9
<6o0z> from t5
<6o1fg> from t5
<6o1z> from t5
<ua7a> from ua9
<xuf2b> from xu
<ce0icd> from ce0\z
4) deferred:
pj4 and pj7 remain unchanged until arrl announces the exact changes in the current and deleted entities lists that will result from the upcoming 2010.10.10 changes to political structure in the netherlands antilles. at that time, we will make a new countries / prefixes database available for download from the logger32 web site.
a big, big "thanks!" to constantin, ua1ake for his substantial contributions to this update.
bud, w2ru
keeper of the database
2010.09.04
离线ba6iv
只看该作者 1楼 发表于: 2010-09-07
又出新的啦!
离线BD1LQA
只看该作者 2楼 发表于: 2010-09-07
旧的使的还不熟练呢,又出新了。要抓紧学习了 。
离线BG1TXU
只看该作者 3楼 发表于: 2010-09-07
下载升完了。。。。
离线BD4EP
只看该作者 4楼 发表于: 2010-09-07
更新说明译文如下(因本人水平有限,对可以读懂原文的ham请以原文为准,如有哪一项翻译得有问题,也请大侠们拍砖):
版本更新说明:ver 3.27.0 于....... 2010年8月24日
1) 日志窗口垂直滚动条主代码重写,以解决一系列错误报告中发现的问题。
2) 清除了qso搜索选项中出现的一个小问题。
3) 清除了日志输入窗口在电台设置选项为“none”时发现的一个错误。
4) 在输入如“1b1ab”这样的呼号时,将不再显示距离及方位角的计算结果,因为这些呼号“不被dxcc所认可”。在这种情况下,如果输入了这些呼号的网格坐标(gridsquare),才会显示距离和方位叫的计算结果。在修改这些功能时,也发现并修正了一个程序中的小问题。
5) 在dxcc-cw奖项表中,引入了日期判断功能,这样可以将1975年1月1日以前的qso记录。操作提示:当显示dxcc_cw奖项状态时,显示一个“w”表示在日志中存在一条qso记录(无论发生在何时),显示为一个“c”时表示有一条被确认的qso记录发生于1975年1月1日之后。
6) 为手动“添加qso”功能增加了一个“comments”(备注)输入字段。
7) 新增了对perseus(帕尔休斯)接收机的支持(未经测试)。所支持的电台工作模式有:lsb,usb,am,cw,rtty,fm,sam 和 drm。当 perseus 模拟 icom 消息格式时,请使用 icom 的地址设置来设置 perseus 的地址。
8) 对所有logger32串口程序进行了修改(电台,so2r电台,旋转器,alpha
amplifier<功放>,tnc集群,dvk,cw 虚拟机和data terminal<数据终端>)。为解决usb电缆被意外地从usb转串口适配器上断开时会死机的问题通过新增代码以解决问题。
9) 在鼠标移动至方向/距离显示区域时,增加了工具提示功能以显示 long-path 长距离/方位角信息。
10) 对425dx 活动窗口程序进行了修改,以处理当数字编号为1000或更大时的正确显示。
11) 有用户报告:当声音警告功能被关闭时,只要用户选项将iota声明设置为开启,该声音警告仍然会生效。问题已被修正。
12) 修改软件,增加了对rc2800px旋转器的支持。
13) 将输出窗口转换选项的文字颜色变为黑色(之前为深灰色)。
14) 在集群阻止过滤器设置窗口中,新增了一个“comment”(备注)页。备注过滤对字母大小写不敏感。过滤器同时支持通配符(*text 为字符串终止符,text* 为字符串开始符,*text* 表示备注中包含“text”)。过滤器文本不可以包含半角逗号。
15) 新增了在cw虚拟机中,当焦点在日志输入窗口时,仍可以使用pgup/pgdn键来改变码速的功能。当winkey模拟速度控制功能被关闭时,该功能在所有配置下均适用。
16) 在日志输入窗口中,使用ctl_b 功能时,该版本将不再自动清除窗口的内容。
国家数据库更新汇总:
1) 修改:
国家前缀从 kh5\p 到 kh5 更名为 "palmyra & jarvis islands"
国家名:
oh0 - 改为 "aland islands"
vk9\c - 改为 "cocos - keeling islands"
zl7 - 改为 "chatham islands"
纬度/经度:
ri1mv: lat=60.65
adif编号:
4w\y north yemen (实体删除) adif 154
7o\s south yemen (实体删除) adif 243
ceoi ~ ce0i 为作为前缀 ce0\z 的后备编码
itu 分区改变: r4w 位置从 29 改至 30
时区设置:4x 改为 "israel standard time"
时区设置:5a 改为 "south africa standard time"
时区设置:e4 改为 "israel standard time"
时区设置:jy 改为 "jordan standard time"
时区设置:vp6 改为 "pacific standard time"
时区设置:vp6\d 改为 "pacific standard time"
时区设置:yk 改为 "jordan standard time"
2) 新增:
后备前缀:
ee9 -> ea9
hy -> f
l -> lu
og0 -> oh0
zt, zu -> zs
特殊呼号:
<4u0g> = hb
<ay1zd> = kc4\a
<3y8xsa> = kc4\a
<dx0dx> = 1s
<n5e> = kh5
<to2bnl> = fw
<3h100tw> = bv
<3t100tw> = bv
<3t0tw> = bv
<r22mws> = r
<r90k> = r
<r2mwo> = ua2
<ir0lvc> = is0
<to2z> = fr
<to7zg> = fj
<tx5tes> = fo\p
<vp8ssi> = vp8\sa
3) 删除:
后备前缀:
r1an 删除于 kc4\a
特殊呼号:
<bp0riw> 删除于 bv
<cy0tp> 删除于 cy0
<kh8si> 删除于 kh8\s
<kh9/n2wb> 删除于 kh9
<n2oo/kh9> 删除于 kh9
<n6mz/kh9> 删除于 kh9
<6o0z> 删除于 t5
<6o1fg> 删除于 t5
<6o1z> 删除于 t5
<ua7a> 删除于 ua9
<xuf2b> 删除于 xu
<ce0icd> 删除于 ce0\z
4) 推迟改变:
pj4 和 pj7 仍保持不变,直到arrl 在2010年10月10日正式宣布针对荷兰的安的列斯群岛的政权结构编号,对现有和已删除清单进行变更。到那时,我们将在logger32的网站上准备一个新国家/前缀数据库以供下载。
在此,对constantin,ua1ake坚持对此数据库更新作出的贡献表示严重的感谢!
bud, w2ru
数据库维护者
2010.09.04
离线BA5CJ
只看该作者 5楼 发表于: 2010-09-07
求v3.26的汉化包,在哪里可以下载。
离线BA7LO
只看该作者 6楼 发表于: 2010-09-08
谢谢楼主!
离线BG1TXU
只看该作者 7楼 发表于: 2010-09-08
求v3.26的汉化包,在哪里可以下载。
by326.zip中文汉化包下载:http://www.logger32.net/files/by326.zip
离线BD4EP
只看该作者 8楼 发表于: 2010-09-08
多谢bg1txu。:)
这个汉化包v3.26-v3.27都可以用。如果有谁发现翻译得有误,请直接告诉我,我会及时修正的。呵呵
离线BA5CJ
只看该作者 9楼 发表于: 2010-09-08
谢谢!
离线BG9TX
只看该作者 10楼 发表于: 2010-09-08
感谢~~~~~~~~~~~~~
离线深圳上尉
只看该作者 11楼 发表于: 2010-09-11
bd4ep您好,我在用logger32 时发现国内分区他好象没做好,输入1区就显示beijing 但其他区就全按方向来表示了,我把协会那表加了一下省市拼音,能否和他沟通一下,让他把中国的分区放到里面,那样会更完善些,
您看一下还有没有要补充的,关于黄岩岛,我没有太懂,他显示scarborough reef,是否也要和他沟通一下,
附那分区表(带拼音),
附件: 中国业余电台分区中英文表.rar (0 K) 下载次数:64
离线BD4EP
只看该作者 12楼 发表于: 2010-09-11
[quote=深圳上尉]bd4ep您好,我在用logger32 时发现国内分区他好象没做好,输入1区就显示beijing 但其他区就全按方向来表示了,我把协会那表加了一下省市拼音,能否和他沟通一下,让他把中国的分区放到里面,那样会更完善些,
附那分区表(带拼音),[/quote]
多谢提供信息。这张分区表我这里有。
我曾经看过关于中国电台分区的情况,logger32里可以通过行政区划的方式来输入各个地区的呼号库,但是具体的操作不是那么容易,还需要有比较详细的各省的经纬度等信息,其中应该还要包括cq分区和itu分区等信息。这些要做进去,没有官方的数字,放到数据库里也不是很妥当哦。
离线深圳上尉
只看该作者 13楼 发表于: 2010-09-11
不是,我是说,当输入bg7i**或bg7p**的呼号时能显示guangdong,更好些,现在他显示东南(当然是英文,
离线BD4EP
只看该作者 14楼 发表于: 2010-09-12
[quote=深圳上尉]不是,我是说,当输入bg7i**或bg7p**的呼号时能显示guangdong,更好些,现在他显示东南(当然是英文,[/quote]
说实话,这部分功能我还真是没有好好研究过。我先看看帮助文档再说。。。
