  • 4330阅读
  • 5回复
新机欣赏:AR-5001D [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2010-09-02
type: hf/vhf/uhf receiver/scanner
frequency range: 0.04-3150 mhz
(cellular blocked in the us)
mode: am/am-sync/fm/wfm/ssb/cw (apco p-25 option)
receiver system: direct conversion superheterodyne (40 khz-25 mhz)
dual conversion superheterodyne (25-200 mhz)
1st if: 295 mhz
2nd if: 45 mhz
triple conversion superheterodyne (200-420 mhz)
1st if: 1704.5 mhz
2nd if: 294.5 mhz
3rd if: 45 mhz
dual conversion superheterodyne (420-3150 mhz)
1st if: 295 mhz
2nd if: 45 mhz
sensitivity: am (10 db s/n, 6 khz bpf)
0.04-0.1 mhz: 8 uv
0.1-25 mhz: 4 uv
25-1000 mhz: 2 uv
1000-2400 mhz: 2.5 uv
2400-3000 mhz: 3.5 uv
3000-3150 mhz: 5 uv
fm (12 db sinad, 15 khz bpf)
25-2400 mhz: 0.7 uv
2400-3000 mhz: 1 uv
3000-3150 mhz: 1.5 uv
wfm (12 db sinad, 200 khz bpf)
25-2400 mhz: 1.8 uv
2400-3000 mhz: 3.2 uv
3000-3150 mhz: 5 uv
ssb (10 db s/n, 3 khz bpf)
0.04-0.1 mhz: 2 uv
0.1-25 mhz: 1.2 uv
25-2400 mhz: 0.3 uv
2400-3000 mhz: 0.5 uv
3000-3150 mhz: 1 uv
selectivity: available bandwidths: 200 hz / 500 hz / 3 khz / 6 khz / 15 khz / 30 khz / 100 khz / 200 khz / 300 khz
am (bw=6 khz)
5.5 khz (-3 db), 6.9 khz (-80 db)
fm (bw=15 khz)
14.2 khz (-3 db), 15.6 khz (-80 db)
wfm (bw=200 hz)
200 khz (-3 db), 250 khz (-80 db)
ssb (bw=3 khz)
2.7 khz (-3 db), 3.1 khz (-80 db)
cw (bw=500 hz)
380 hz (-3 db), 500 hz (-80 db)
image rejection: n/a
voltage: 10.7-16 vdc
current drain: max 2 a
impedance: 50 ohms, 2*n-type sockets
dimensions (w*h*d): 220*97*304 mm
weight: 5 kg
manufactured: japan, 2010-20xx
other: 2000 alpha memories in 40 banks. ctcss/dcs/dtmf. auto-notch, nr and nb.
usb and rs-232c ports. sd-card slot for digital recording and/or memory backup.
45 mhz if output. spectrum scope. i/q output option.
ip3: +20 dbm @14.1 mhz, +12 dbm @50 mhz, +7 dbm @620 mhz
离线bd3af
只看该作者 1楼 发表于: 2010-09-02
接收机,看看图   .
离线bd3af
只看该作者 2楼 发表于: 2010-09-02
weight: 5 kg
个头不大,但分量不轻
离线BD4NU
只看该作者 3楼 发表于: 2010-09-02
补个图 :p
离线zsh
只看该作者 4楼 发表于: 2010-09-03
ar-5001d≠ar-5000+升级!!!!!
离线bg2raq
只看该作者 5楼 发表于: 2010-09-03
aor的外形设计的怎么这么山寨?
