  • 3759阅读
  • 11回复
上海新HAM BH4AFI前来报到。 [复制链接]
离线BH4AFI
只看楼主 倒序阅读 0楼 发表于: 2010-07-18
小弟在3周前通过了4级考试申请到了呼号。
呼号bh4afi
qth 上海普陀区
设备 vr6r 钻石 srh771天线。
准备明年3月升3级。
谢谢各位指导。
有个小问题,目前正在研究echolink,但是要求我认证,我的操作证已经扫描并按照说明发过去了,咋还是没回音呢?
离线BH1IEO
只看该作者 1楼 发表于: 2010-07-18
哈哈哈,操作证不行,必须要用执照,您不要再上传了,免得给您记录到黑名单内。
once validated, a station must not share or "lend" its password to another station, particularly to an individual who is not licensed. in addition, any user who tries to present forged documents for validation, or documents obtained without permission, will be permanently barred.
提交的许可证明:(大概意思,不太准确)
如果您想进行验证,您发送的文件必须是业余无线电执照复印件(或数码照片) ,在显示有效的呼号下,您才可以要求验证。该副本必须明确地显示电台执照的有效日期,并在您的国家合法适用。如果您在一个国家里经营许可证和站牌是分开居住的文件,你必须提供站许可证。您必须发送一个未改变图片该文件,而不是它的内容文本。非正式文件,如的的qsl卡,获奖证书,并callbook页不能被接受验证。我们也不能接受任何从一个公共网站下载。如果您最近获得许可,但尚未收到您的文档,请等待,直到它到达。
您上传的执照副本被发送到echolink审定小组,由拍照或扫描并上传,或发送的传真。某些其它验证选项可能也将公布。请到http://www.echolink.org/validation/
开始。
如果您选择的扫描和上传选项,您上传的文件,必须对这些文件类型之一:为的jpg,gif , tif格式格式。
提示:注册时上传您的有效执照,必须是打印的并在有效期内。任何在证件上做手脚的行为一旦发现,将永远禁止注册使用!
离线BH1IEO
只看该作者 2楼 发表于: 2010-07-18
各国执照的基本标准:
http://www.echolink.org/validation_docs.htm
以下是echolink相关制度:
the following guidelines are followed for all stations requesting access to the echolinkreg; system. these guidelines have been established to help ensure legal, courteous enjoyment of the system by every station. every effort is made to apply these policies universally and fairly.
although echolink is offered free of charge, please keep in mind that it is a privately-operated system. all echolink users are guests on the system, and are being permitted the use of it in exchange for following these guidelines.
1.access is granted only to licensed amateur radio operators holding a cept class 2 license, or equivalent. each new user must provide proof of license before access is granted, using any of several available validation methods. please see authentication and validation documents for more information.
2.no "swl" (listen-only) access is permitted. echolink is a two-way system by design, and there is no mechanism to validate listen-only stations.
3.sysop validations (i.e. -l/-r suffixes) are granted only to licensees whose class of license permits operation of an internet voice gateway. however, it is the licensee's responsibility to ensure that any additional permits or authorizations are obtained if required by the governing authorities.
4.stations operating in sysop mode may interconnect echolink only with equipment operating on amateur frequencies. echolink does not permit use of the system with other services such as gmrs, frs, or mars. for security reasons, it is also not permitted to interconnect echolink with other voip systems that support direct access from a computer.
5.stations which use the system are expected to abide by common courtesy and generally-accepted operating practices. access privileges will be withdrawn for stations which operate with malicious intent, blatant disregard for international amateur radio regulations, or impersonation of another station.
6.when based upon complaints from several other users, repeated incidents of rude, threatening, or vulgar remarks from a particular station will not be tolerated, and is considered grounds for withdrawal of access privileges. this policy applies to any transmissions from a station, including those received over an rf link. rude or threatening remarks directed at members of the volunteer support team will also not be tolerated.
7.once validated, a station must not share or "lend" its password to another station, particularly to an individual who is not licensed. in addition, any user who tries to present forged documents for validation, or documents obtained without permission, will be permanently barred.
8.please use only your permanent, fixed-station callsign to log in. avoid using portable designators (e.g., k1rfd/2 or py2/k1rfd), or temporary, special-event, or commemorative callsigns; these callsigns will not be validated. this helps keep the callsign database to a manageable size.
9.if you hold multiple callsigns, please request validation of only one callsign for echolink. as a rule, we will not validate more than one basic callsign per user in single-user mode. this holds true even if you travel from one country to another and hold callsigns in each country -- please use only one callsign with echolink, even while traveling.
10.the "addressing servers" are designed to be accessed by echolink software only. for the sake of system security and stability, any other access requires the permission of the server administrator. as a matter of security, in no event should the ip addresses (or internet hostnames) of logged-in stations be displayed to anyone who is not a validated, logged-in user.
11.although every effort will be made to apply these policies universally and fairly, the echolink support staff reserves the right to withdraw a station's access privileges at any time, without notice. echolink is a privately owned and operated system that has no connection with, and is not governed by, any radio licensing authority.
please note that the echolink software allows additional security policies to be adopted by individual stations. for example, a station not wishing to be joined to a conference can disallow such access. these decisions are made by each individual station and are not under the control of the developers of echolink, or the servers with which it operates.
离线BH4AFI
只看该作者 3楼 发表于: 2010-07-18
提交的许可证明:(大概意思,不太准确)
开始。
bh1ieo,你好,
怪不得,它发了个邮件给了我。
我只有一个白色的4级操作证,执照是什么东西?我还有个会员证,可以会员证没有呼号啊?
操作证的英文是。
amateur radio operator's license of china.这不就是执照么?
执照是啥样的?
离线BH4AFI
只看该作者 4楼 发表于: 2010-07-18
这个是执照?
谢谢
离线BH1IEO
只看该作者 5楼 发表于: 2010-07-18
大哥呀,上面写的是申请表!!执照是个棕色的本本。
离线BH4AFI
只看该作者 6楼 发表于: 2010-07-18
我没有棕色的本本啊,回头我把我发给它的图片上传上来,不在现在用的电脑里。谢谢啦。
离线BH1IEO
只看该作者 7楼 发表于: 2010-07-18
您现在只有会员证和操作证,电台执照还没有拿到。注册就需要电台执照,操作证和会员证不用上传,所以您暂时无法注册。
给您上个移动台的样本吧。
离线BH4AFI
只看该作者 8楼 发表于: 2010-07-18
原来是这样,我需要怎样才能拿到执照呢?
离线BH1IEO
只看该作者 9楼 发表于: 2010-07-18
原来是这样,我需要怎样才能拿到执照呢?
需要把设备检验后等待执照下发。
离线BH4AFI
只看该作者 10楼 发表于: 2010-07-19
hoho,tnx,那我就等待下发执照了。到时申请好了,还要望前辈多帮助啊。
离线eaglecpj
只看该作者 11楼 发表于: 2011-02-19
