  • 7807阅读
  • 25回复
全数字化收信机及收发信机 [复制链接]
离线vlover
只看楼主 倒序阅读 0楼 发表于: 2010-07-08
一楼及7楼备用
先打个样:
离线vlover
只看该作者 1楼 发表于: 2010-07-08
2楼及7楼备用
区别:
离线vlover
只看该作者 2楼 发表于: 2010-07-08
离线vlover
只看该作者 3楼 发表于: 2010-07-08
4b楼及7楼备用
离线vlover
只看该作者 4楼 发表于: 2010-07-08
4b楼及7楼备用
general specifications adt-200a
receiver
frequency range (without options)      10khz … 30mhz
1.8mhz … 30mhz      input rx-ant
inputs ant1, ant2
resolution of tuning knob      ± 1hz
frequency changement per resolution      500hz … 100khz      progressive from > 3 turns/s
preamplifier      0, +5, +10db
attenuator      0, 5, 10, 15, 20, 25db      automatic/manual operation
max. input power (ue an 50ohm)      -8dbm
+17dbm      att = 0db, preamp = 0db
att = 25db
sensitivity (mds) cw (f = 1.8 … 30mhz)
(b = 500hz)      <-137dbm (0.03&#181;v)
< -127dbm (0.1&#181;v)      s/n = 0db, preamp = 10db
s/n = 10db, preamp = 10db
sensitivity ssb (f = 1.8 … 30mhz)
(b = 2400hz)      < -120dbm (0.22&#181;v)
< -110dbm (0.7&#181;v)      s/n = 0db, preamp = 0db
s/n = 10db, preamp = 0db
sensitivity am (f = 0.1 … 30mhz)
preamp = 0db
preamp = 10db
< -105dbm (1.8&#181;v)
< -112dbm (0.57&#181;v)
b = 9khz, fmod = 1khz, m = 60%
s/n = 12db
noise figure      < 10db      preamp = 10db
intermodulation 3. order (ip3) 1)      > 28dbm      2 x -14dbm, delta f = 2khz, b = 500hz
im3-free dynamic range 1)      > 96db      preamp = 0db
intermodulation 2. order (ip2)      > 60dbm      2 x -14dbm, f1 = 6mhz, f2 = 9mhz
im2-free dynamic range/td>      > 93db      preamp = 0db
spurious-free reception      < -107dbm
blocking dynamic range (preamp = 0db)      > 112db      b = 2400hz, ?f = 2khz
selectivity:
cw filter
ssb filter
am filter
fm filter
50hz ... 1.2khz
300hz ... 3.5khz
3.0khz ... 10khz
6.0khz ... 25khz
in 10 steps
in 13 steps
in 10 steps
in 12 steps
s-meters tolerance      ± 1.5db
s-meter range      165db      -148dbm … +17dbm
sideband noise of nco      < -140dbm/hz      2khz spaced from fe
agc threshold      -40 … -116dbm      selectable in steps of 2db
agc time constants      1ms ... 100ms
10ms ... 5s
50ms ... 10s      attack
hold
decay
nf frequency response at ssb
b = 2400hz, equalizer: off      ± 1db      f_nf = 300hz ... 2700hz
nf equalizer (in steps of 3db)      ± 18db      f = 300hz, 800hz, 3khz
signal delay (antenna input to af output)      typ. 20ms      depends on filter bandwidth
1) the two tone measurement procedure is generally not applicable for ad converters , as the ip3 of an ad converter decreases proportionaly to the input signals. on the other hand, due to dithering, the im-free dynamic range is in practical operation substantialy higher than at the laboratory two tone measurement.
frequency reference
internal reference oscillator      tcxo, 10mhz
stability at 10…30°c ambient temperature      ± 0.1ppm      after 30min.
aging      max. 1ppm /year
electronic tuning range      ± 8ppm      by sw with external reference
external reference, type a      5mhz, 10mhz
signal amplitude of external reference      min. 200mv rms
trensmitter
frequency range      1.8 … 29.7mhz      all amateur bands
output power range (in 16 steps)      0.1w … 50w
max. 45w      pep 2-tone
continuous carrier, unmodulated
harmonics      < -60dbc
non-harmonic spurious emission      < -70dbc      outside of fc ± 200khz
intermodulation 3. … 9. order      < - 45dbc      2 tone, 50w pep
drain efficiency      max. 70%      at max. output power
af frequency range ssb      200hz … 3.0khz      configurable
rejection of unwanted sideband      > 90db
tx-equalizer (in steps of 3db)      ± 18db      f = 100hz, 550hz, 3khz
enhancement of medium voice power      0 … 8db
power leveling      +18 … -30db      automatically adjusted according to the selected power
inband im-distortions      < -50db
tolerance of power-meter      ± 5%      numerische u. balken-anzeige
power range of vswr meter      0.1 … 50w      min. anzeige: 1:1.03
general data
ac supply      90 … 253vac, 50…60hz
power consumption      20w (rx), 120w (tx)
dimensions (w x h x d)      260 x 103 x 260mm
weight      4.5kg
temperature range      +5°c … +45°c      fully functional
离线vlover
只看该作者 5楼 发表于: 2010-07-08
离线vlover
只看该作者 6楼 发表于: 2010-07-08
相关资料--稍候,分卷后上传
离线BD2VBB
只看该作者 7楼 发表于: 2010-07-08
8楼给您留着。
离线BG8CIH
只看该作者 8楼 发表于: 2010-07-08
sfdr......
离线bg7mss
只看该作者 9楼 发表于: 2010-07-08
看起来很nb。。
离线zly
只看该作者 10楼 发表于: 2010-07-08
离线vlover
只看该作者 11楼 发表于: 2010-07-08
离线BG7IBQ
只看该作者 12楼 发表于: 2010-07-08
好象是成品来的
离线bg8hl
只看该作者 13楼 发表于: 2010-07-08
3319,33 ~~~ 天拉~!~!
离线bg4qne
只看该作者 14楼 发表于: 2010-07-08
是成品还是套件?关注货源及价格
离线BD2VBB
只看该作者 15楼 发表于: 2010-07-08
居然有4路rx,牛!
离线net2000
只看该作者 16楼 发表于: 2010-07-09
收信机的发展方向,将来的收信机会越来越同质化,差别就在于软件了,由软件解调、改模式、滤波,最后输出。
离线BH3PJX
只看该作者 17楼 发表于: 2010-07-09
看上去很另类,好像一种检测设备。
离线BD6QBQ
只看该作者 18楼 发表于: 2010-07-12
新的发展方向?
离线vlover
只看该作者 19楼 发表于: 2010-10-27
实际使用感觉良好:agc动作快,信号接收平稳,频率转换速度极快;音质顺耳-不是像模拟机器那种北噪很强颗粒感那种,北噪很低,很细,是一种“流”化了的声音,不是高保真的那种,对细节可东渡有着明显的提升;和中频dsp不同:弱小信号和模拟机一样,有就是有,没有if-dsp那种量化门限的感觉。快衰落张台下和模拟机一样。对电离层频移有一定的纠正效果(主观的),对比接收机是罗德的全数字化接收机和e1800/3,罗德的是比较平淡的声音,直来直去。可以多频率同时接收,射频频谱存储,可以中频重建输出的形式回放。
