  • 4445阅读
  • 6回复
FT-450AT-内置天调-调整范围扩展 [复制链接]
离线wd3010
只看楼主 倒序阅读 0楼 发表于: 2010-06-29
extending the range of the atu to tune higher impedance antenna's like the g5rv.
to extend the tuning range of the atu to tune higher impedance antenna's like the g5rv enter the hidden menu by:
turn off the radio using the on/off button.
press and hold the att/po, nb, and agc buttons and at the same time turn the radio on by pressing the on/off button.
rotate the dsp/sel to find hf1swr change the value from 85 to 150 by rotating the main dial knob.
rotate the dsp/sel to find hf2swr change the value from 85 to 150 by rotating the main dial knob.
rotate the dsp/sel to find hf3swr change the value from 85 to 150 by rotating the main dial knob.
press and hold the f button for 1 second to store the new settings.
turn on the radio. the atu will now tune to a g5rv or similar high impedance antenna.
个人试验了一下
确实可以把原先不能调节的调下来了
不知道真假
高手出来拍砖了
离线wd3010
只看该作者 1楼 发表于: 2010-06-29
感觉它只是在数字上做了欺骗
离线BA1IO
只看该作者 2楼 发表于: 2010-06-29
最好还是看看驻波表!可能就是把允许的驻波值变大了!
离线wd3010
只看该作者 3楼 发表于: 2010-06-29
楼上说的很对啊我也是这么认为的
相当于把驻波压缩了,显示降低了,其实驻波没有变
离线BA1IO
只看该作者 4楼 发表于: 2010-06-30
离线BG7IPB
只看该作者 5楼 发表于: 2010-07-04
关注使用效果
离线BD6MA
只看该作者 6楼 发表于: 2012-10-14
回 BA1IO 的帖子
BA1IO:http://www.radiocronache.com/2010/03/ftdx-5000mp-us-ftdx-5000-vs-ic-7700-dmu-2000-v5-11-yaesu-ical-soon-it/ (2010-06-30 01:40)
谁能详细的解释一下~
