  • 3526阅读
  • 19回复
今天是2010 CQ World-Wide WPX竞赛最后一天提交日志! [复制链接]
离线haoyue
只看楼主 倒序阅读 0楼 发表于: 2010-04-25
3月27-28日的2010 cq world-wide wpx竞赛已经过去。
竞赛规则要求对ssb部分比赛结束后28天内提交日志,即不迟于2010年4月25日提交日志。
离线haoyue
只看该作者 1楼 发表于: 2010-04-25
刚提交报告:
机器人自动回复:
thank you for your participation in the contest and for submitting
your log to ssb@cqwpx.com. while the contest robot was able to
process your log, it has discovered some potential problems. please
correct the problems identified below and resubmit your log. we want
to make sure that we have your information right!
if you believe you have received this message in error or if you are
having problems creating the required log file, please contact me at
questions@cqwpx.com and i will try to help.
73.
randy, k5zd
contest director
机器人已经发现了日志一些潜在的问题。
请高手帮助是何问题?
离线BG4AHF
只看该作者 2楼 发表于: 2010-04-25
没看见你的log 无法回答
离线haoyue
只看该作者 3楼 发表于: 2010-04-25
log已分页短信发你。
谢谢你的帮助!
离线BG4XNG
只看该作者 4楼 发表于: 2010-04-25
明早8点前一定要上传,不然害人害己,更大的问题会影响中国蛤蟆的形象。
离线allenyan
只看该作者 5楼 发表于: 2010-04-25
b1z multi-op one all high assisted
b4tb single-op one 40m high assisted
ba1sn single-op one all low non-assisted
ba4io single-op one 15m low non-assisted rookie
ba4scp single-op one all low non-assisted
ba4sd checklog checklog low assisted
ba5dx single-op one 10m low non-assisted
ba5ham single-op one all low non-assisted
ba6iv single-op one 15m low assisted
ba7ck single-op one 20m high non-assisted
ba7in single-op one 15m low assisted
ba7io single-op one 10m low assisted
ba7my single-op one all high assisted
bd1hw single-op one all high non-assisted
bd1isi single-op one 40m low non-assisted
bd1tcc single-op one all low non-assisted tb-wires
bd2sh/7 single-op one all low non-assisted
bd3eo/1 single-op one 20m high non-assisted
bd3okk single-op one all low non-assisted
bd3pch single-op one 20m low non-assisted
bd4dvk checklog   assisted
bd4exl single-op one 15m low non-assisted rookie
bd4jwu single-op one all low non-assisted rookie
bd4jzy single-op one all low non-assisted tb-wires
bd4kya single-op one all low non-assisted
bd4rdr single-op one 40m qrp non-assisted
bd4tr single-op one all low non-assisted
bd4wzh single-op one 20m low non-assisted
bd4xx single-op one all high non-assisted
bd5baj single-op one all low non-assisted
bd5cfy single-op one all low non-assisted
bd5cgo single-op one all low non-assisted
bd5hst single-op one all low non-assisted
bd7ixg single-op one 15m high assisted
bd7kqt single-op one 15m low non-assisted
bd7ldm single-op one 15m low non-assisted
bd7mfb single-op one 15m low assisted
bd7rdc single-op one all low non-assisted
bg1qex single-op one all low non-assisted
bg1tpd single-op one 20m low assisted
bg4ahd single-op one all low assisted tb-wires
bg4kla single-op one all low non-assisted
bg4krb single-op one all low non-assisted
bg4ljw single-op one all low non-assisted
bg4lkz single-op one all low non-assisted tb-wires
bg4mcg single-op one all low non-assisted
bg4mr single-op one all low non-assisted
bg5cic single-op one all low non-assisted
bg5dlv single-op one all low non-assisted
bg5dml single-op one all low non-assisted
bg5dmn single-op one all low non-assisted
bg5dmo single-op one all low non-assisted
bg5dod single-op one all low non-assisted
bg5ffk single-op one 10m low non-assisted
bg5hym single-op one all low non-assisted
bg6ahu single-op one all low non-assisted
bg6icl single-op one all low non-assisted
bg6iys single-op one all low non-assisted
bg6jeq single-op one 15m low non-assisted
bg6jic single-op one 20m low non-assisted
bg6jjx single-op one 15m low non-assisted
bg6jnb single-op one 20m low non-assisted
bg6kad single-op one all low non-assisted
bg6qhv single-op one all low non-assisted
bg6qjg single-op one all low non-assisted
bg7anx single-op one 15m low non-assisted rookie
bg7bah single-op one 15m high assisted
bg7ieu single-op one 15m low non-assisted
bg8ggt single-op one all low non-assisted rookie
bh1bcv single-op one 20m high non-assisted
bh1bsh single-op one 40m high assisted
bh1dip single-op one 40m high assisted
bh1hsx single-op one 15m low non-assisted rookie
bh1iia single-op one all low non-assisted rookie
bh1iij single-op one 15m low non-assisted
bh1lej single-op one all low non-assisted rookie
bh4rci single-op one all low non-assisted rookie
bh4rdb single-op one all low non-assisted rookie
bh4rdu single-op one all low non-assisted rookie
bh4rkh/qrp single-op one all qrp non-assisted rookie
bh4scf single-op one all low non-assisted rookie
bh4sfe single-op one all low assisted rookie
bh7lmd single-op one 15m low non-assisted rookie
bh7mly single-op one all low non-assisted
bu2au single-op one all low assisted tb-wires
bv0l multi-op unlimited all high assisted
bv4vq single-op one all low non-assisted
bx5aa single-op one 15m high non-assisted
by4dx multi-op one all low assisted
by4ham multi-op one all low assisted
by4qa multi-op one all high assisted rookie
by8dx multi-op one all high assisted
这是目前提交的log,最后一天,大家抓紧啊。
只看该作者 6楼 发表于: 2010-04-25
请问有han帮我上传n1mm的log吗,我不会转换,只有adi格式
离线bg5cic
只看该作者 7楼 发表于: 2010-04-25
用.log导出
离线bg5cic
只看该作者 8楼 发表于: 2010-04-25
导出方法file-----export-----exprt cabrillo file
导出后应是你呼号.log
导出后你查看一下日志文件有无错误
再发送到email到ssb@cqwpx.com
离线BG4XNG
只看该作者 9楼 发表于: 2010-04-25
[quote=bh7mlz火龙果]请问有han帮我上传n1mm的log吗,我不会转换,只有adi格式 [/quote]
快啊!
离线bg5cic
只看该作者 10楼 发表于: 2010-04-25
按照我上面的方法导出就可以了
离线bg5cic
只看该作者 11楼 发表于: 2010-04-25
或加我qq19664971,我帮你远程
只看该作者 12楼 发表于: 2010-04-26
已经上传咯,在此非常感谢bg5cic,bd4gn的帮忙。
只看该作者 13楼 发表于: 2010-04-26
bg7ibs single-op one 10m low non-assisted
bh7mlz single-op one all low non-assisted
by5cd multi-op one all high assisted
离线bg8bkj
只看该作者 14楼 发表于: 2010-04-26
mop,似乎只有all high assisted吧?
离线bd4sfe
只看该作者 15楼 发表于: 2010-04-26
每次比赛结束,过几天我就提交,知道为啥快么?嘻嘻,qso 数量有限哈哈
离线BA7LO
只看该作者 16楼 发表于: 2010-04-26
路过顶一顶!
离线haoyue
只看该作者 17楼 发表于: 2010-04-28
怎么我们8区除by8dx集体台外就一个bg8ggt成功上传了通联日志?
这里要感谢江苏常州bh4qak老张在周末2次长途电话给予的热心帮助!
离线BD4HZ
只看该作者 18楼 发表于: 2010-04-29
哈哈哈,我是比赛完了就传了,没有超过1小时的,还是热的呢
离线haoyue
只看该作者 19楼 发表于: 2010-04-30
还要感谢bd4hf给予的热心帮助!
