  • 5074阅读
  • 6回复
不是说有Linux版的么?找不着啊 [复制链接]
离线BG4HKQ
只看楼主 倒序阅读 0楼 发表于: 2010-03-24
我想弄个小盒子,跟电台接起来,放在bg4hgu家里,他那个天线高,好用。
可找不着linux版在哪。
离线woodhead
只看该作者 1楼 发表于: 2010-03-24
为什么非要找linux版
离线BG4HKQ
只看该作者 2楼 发表于: 2010-03-25
为什么非要找linux版
因为我的小盒子是linux的。
如果是linux的话我管理起来也方便些。
只看该作者 3楼 发表于: 2010-03-26
官方说没有只有用wine 才行.
is echolink available for any platform other than windows?
echolink is designed specifically to run under microsoft windows. currently, there are no plans to offer versions of echolink for other platforms (except as noted below).
however, if you are running a macintosh with os x, you can use the program echomac by n9yty, which is compatible with echolink. (support for echomac is not available through the echolink web site.)
many users have also had success running echolink under linux using the wine compatibility layer. for example, echolink is known to work with fedora core 5 and above, with a few limitations. however, linux is not an officially supported platform for echolink.
http://www.echolink.org/faq.htm
离线BH1DIY
只看该作者 4楼 发表于: 2010-04-07
因为我的小盒子是linux的。
什么样的linux小盒子
说来听听
看我能不能给你出个方案
离线ba7ib
只看该作者 5楼 发表于: 2010-04-08
linux的小盒子,有兴趣...
离线BG4HKQ
只看该作者 6楼 发表于: 2010-04-08
弄一个via主板,上面用cf卡直接跑个linux起来,然后跑echolink.
via有很多epia的小主板,低能耗\体积小,很方便,主频也还可以,基本跑单应用是足够了.
