  • 5683阅读
  • 16回复
对讲机V段直接听宇航员FM(2010-03-25) [复制链接]
离线bd4rs
只看楼主 倒序阅读 0楼 发表于: 2010-03-24
明天周四(3.25)bjt 1518 开始 日本8j7iss的ariss通联。
v段对讲机调到145.800mhz,在覆盖范围之内可尝试收到距地面三百多公里的国际空间站宇航员fm模式下来的声音。
覆盖范围:东北、华北、华东部分地区。
本月9号也有一次日本ariss通联,轨道非常好可惜错过了。
消息来源:http://www.amsat.org/amsat/ariss/news/arissnews.rtf
shiogama daini junior high school, shiogama, japan, direct via 8j7iss
contact is a go for: thu 2010-03-25 0718 utc 75 deg
离线BG8SF
只看该作者 1楼 发表于: 2010-03-24
没有覆盖到云南啊!
离线小小强
只看该作者 2楼 发表于: 2010-03-24
弱弱的问一下,手台是用原装天线吗?还是用其它天线,我用kg-uvd1p原装的天线收不到希望一号的fm,我是个新手,请多多指教,谢谢!
离线bd4rs
只看该作者 3楼 发表于: 2010-03-24
一般来说,手台原装天线就可以收到iss的信号。国际空间站轨道高度不到400公里,fm通话时下行功率也大,可以收的很清晰。
希望一号轨道高度1200公里,功率也不大用手台原装天线直接收fm转发器通话很困难。我是没收到过。但我用ft60r原装天线收ho68的cw信标是可以的,虽然用fm模式接收的只是扑扑的声音,但确能收到。
明天的这次ariss通联无法覆盖到你那里,所以很可惜这次你无法去尝试了。
当然你还可以关注这里
http://www.issfanclub.com/status/?mode=packet
如果打开了packet模式,你仍有可能用手台直接收iss下来的数据信号。
离线BG2BHC
只看该作者 4楼 发表于: 2010-03-25
我这里角度很好,下午上课到15:45,翘课一小会听听~
离线bd4rs
只看该作者 5楼 发表于: 2010-03-25
我这里接收最大仰角只有3.6度,据空间站2000多公里,不知能否收到。
一小时后地面学生所提问题,听听看宇航员如何回答。
proposed questions for shiogama daini junior high school:
1. how does it feel, living in space?
2. how do you feel in zero gravity?
3. do you have the sense that "one day is 24 hours"?
4. for you, what is the best part of the life in the space station?
5. in the space, do you have anything hard?
6. can you choose what you want to eat?
7. when you have a pillow fight in space, can you hit the other person who you aim at?
8. when you are in the space station, if you become sick, what would you do?
9. in the space station, are the constellations the same shape as on earth?
10. when you watch a meteor shower in the space station, what kind of shape does the meteor shower have?
11. in space, does everyone's face swell in a circle?
12. in the space station, at what temperature does water boil?
13. do you think that humans can reclaim mars?
14. it is the second iss stay for you, is there something special you brought with you?
15. the project of the iss is pushed forward by international collaboration, but what is the most important for you?
1.  小林 拓矢 ( コバヤシ タクヤ ・ 14 )
宇宙で生活する感覚は,どんな感じがしますか?
2.  村山 あずさ ( ムラヤマ アズサ ・ 14 )
無重力は,どんな感じですか?
3.  加藤 悠聖 ( カトウ ヒサトシ ・ 14 )
1日は24時間である,という感覚はあるのですか?
4.  須藤 良太 ( ストウ リョウタ ・ 14 )
宇宙ステーションでの生活で,一番楽しいことは何ですか?
5.  丹野 美優貴 ( タンノ ミユキ ・ 13 )
宇宙での生活で,つらいことや苦しいことはありますか?
6.  杉山 一博 ( スギヤマ カズヒロ ・ 14 )
献立は自分で考えて,好きなものを選んで食べることができるのですか?
7. 石戸 まどか ( イシド マドカ ・ 14 )
宇宙で枕投げをしたら,狙った相手に当てることができますか?
8. 貴田 慎太郎 ( キダ シンタロウ ・ 13 )
もし,宇宙ステーションで病気になった時はどうするのですか?
9.  前木 涼 ( マエキ リョウ ・ 14 )
宇宙ステーションから,星座はどのような形で見えますか?
10.  中條 玲奈 ( ナカジョウ レイナ ・ 15 )
宇宙ステーションでは,流星群はどのような感じに見えますか?
11.  髙橋 晃世 ( タカハシ コウセイ ・ 13 )
宇宙に行くと,誰でも顔が丸くふくれるのですか?
12.  小原田 賢聖 ( コハラダ マサト ・ 14 )
宇宙ステーションの中で,水は何℃で沸騰しますか?
13.  清水 ひとみ ( シミズ ヒトミ ・ 14 )
火星を開拓することはできると思いますか?
14. 杉内 一彦 ( スギウチ カズヒコ ・ 14)
2回目の宇宙ステーション滞在ですが,地球から必ず持っていくものはありますか?
15. 中條 玲奈 ( ナカジョウ レイナ ・ 15 )
ISSの事業は国際協力で進められていますが,大切にしていることは何ですか?
离线bd4rs
只看该作者 6楼 发表于: 2010-03-25
没听到,仰角太低了。
那翘课的应当能听到了吧:)
离线BG2BHC
只看该作者 7楼 发表于: 2010-03-25
哈哈 决定不翘课了 弄了定时录音软件 可是后来才发现算错上课时间了 于是没翘课就听了现场直播 用by2hit新做的gp天线 从宇航员开始呼叫就稳定接收 信号最好到了59+ 可惜是日语 根本听不明白!
录音了 网络不稳定 现在传不上来
离线郑建平
只看该作者 8楼 发表于: 2010-03-25
我从外面回来看到orbitron显示iss已经到j国上空了,拿了一截馈线和手台,跑到二楼的阳台,把馈线芯线按在不锈钢的扶手上,断续的收到信号,是日语。语音可以达到4分。
离线BD6AHP
只看该作者 9楼 发表于: 2010-03-25
呵呵,刚刚看到贴子,抬手看表,过了。。。
离线BG5LU
只看该作者 10楼 发表于: 2010-03-25
用软件算了下,bjt 19:00左右到我这里,可惜早结束了
只看该作者 11楼 发表于: 2010-03-26
睡着了。。。
离线BG2BHC
只看该作者 12楼 发表于: 2010-03-26
录音来了~后面的是尝试收ao-51,但是不成功
附件: HRD 2010-03-25 154303.rar (0 K) 下载次数:192
离线BA7IAG
只看该作者 13楼 发表于: 2010-04-02
现在wx-1是不是改名hope-1(ho-68)??
离线bg2rld
只看该作者 14楼 发表于: 2010-04-02
去年试验用手台自带橡胶天线,只要头上没屋顶,可以稳定收听5分钟,车台加苗子能多2分钟,八木加转向器再多2分钟。希望1号信号太弱,用车台加苗子能听个2-3分钟吧。苗子770h。
离线BG2BIR
只看该作者 15楼 发表于: 2010-04-02
我去年用手台原装天线收iss很轻松,但是今年一直没收到信号,不知道咋回事
离线BH4RDB
只看该作者 16楼 发表于: 2010-04-08
学习了,关注中
