  • 2252阅读
  • 3回复
W5DXP's No-Tuner, All-HF-Band, Horizontal, Center-Fed Antenna [复制链接]
离线bd3ct
只看楼主 倒序阅读 0楼 发表于: 2010-03-08
w5dxp's no-tuner, all-hf-band, horizontal, center-fed antenna
看图说话吧,图上写得很清楚了,找了半天没有找到哪里有450欧姆的馈线卖。
离线bd3ct
只看该作者 1楼 发表于: 2010-03-08
the no-tuner, all-hf-band, horizontal, center-fed antenna is our old friend, the 80 meter halfwave dipole dressed up a bit. by varying the length of the 450 ohm ladder-line feeding the antenna, we can achieve an swr of less than 2:1 on all frequencies on all hf bands with the exception of the lowest part of 80m. on 75m, we are feeding the antenna with a half-wavelength of ladder-line. on 40m, we are feeding it with 3/4 wavelength of ladder-line.
no antenna pruning required. my transmission line really does tune my antenna system.
special thanks to walt maxwell, w2du and jim bromley, k7jeb.
离线chengrc
只看该作者 2楼 发表于: 2010-03-08
3ct祝大哥好!!顺便荒一为中文!!!让有些不懂外文的朋友看的懂呀!!!!哈!!!!
离线bd3ct
只看该作者 3楼 发表于: 2010-03-09
建议到谷歌翻译去试试!
