  • 3783阅读
  • 13回复
矢网或标网 [复制链接]
离线mylcq
只看楼主 倒序阅读 0楼 发表于: 2010-02-16
大家新年,有没有朋友能转让一个矢网或标网.
我的综测仪坏了,初八要干活,希望哪位朋友能转让一个矢网或标网,我将不胜感激.
离线mylcq
只看该作者 1楼 发表于: 2010-02-20
看看这两种天线
离线mylcq
只看该作者 2楼 发表于: 2010-03-23
没人回哦,..........................
离线BA4WI
只看该作者 3楼 发表于: 2010-03-23
回你~~~~~~~~~
离线net2000
只看该作者 4楼 发表于: 2010-03-23
个人有这种仪器的极少吧,而且都当宝贝一样供着,谁转让你?
离线bg6art
只看该作者 5楼 发表于: 2010-03-23
价格不菲啊。。。。
离线BA5RW
只看该作者 6楼 发表于: 2010-03-23
需要的频率最低上限是多少
离线vlover
只看该作者 7楼 发表于: 2010-04-03
有wiltron 的560a,和马可尼的6500,到40 g 的;详情电话联系
离线vlover
只看该作者 8楼 发表于: 2010-04-08
wiltron 560a :
frequency range: 1 mhz to 34 ghz, depending on the swr autotester and detectors used (sold separately)
channels: three (a, b, r) with push-button selection of a, b, r, a-r, and b-r. two channels are displayed simultaneously
dynamic measurement range and sensitivity: a and b with detectors (sold separately): 66 db (+16 dbm to -50 dbm); a and b with swr autotester (sold separately): 66 db (+16 dbm to 50 dbm); r with detector (sold separately): 46 db (+16 dbm to -30 dbm)
offset control: positioning of a and b traces is independently and continuously adjustable over >±65 db range. when trace is on reference line, power is displayed in dbm on 3 digit led readout with 0.1 resolution. offset is displayed in db relative to a 0 db reference level
resolution: independent control for a and b in steps of 0.2, 0.5, 2.5, 10 db per division
store trace: stores displayed trace(s) in 1024 point memory
average: averages data in memory with input test data and displays the result
subtraction: subtracts data in memory from input test data and displays the result
recall: displays stored data
uncalibrated sweep indicator: lights when external sweep generator sweep rate is too fast for memory
real time display mode: horizontal sweep is synchronized with ramp from external sweep generator
refresh: steady, non flickering display is provided regardless of sweep generator sweep rate. vertical resolution is 512 points for single or dual traces
refresh hold: updating of display data is stopped, display is frozen
x-y plot (real time): provides pen lift, vertical, and horizontal signals for x-y plot, coincident with external sweep generator ramp
x-y plot (refresh): display is froze
离线vlover
只看该作者 9楼 发表于: 2010-04-08
marconi 6500 scalar network analyzer:
the 6500 is a microprocessor controlled, scalar network analyzer.
frequency range: depends on detectors and source
dynamic range: +16 db to -55 db
离线mylcq
只看该作者 10楼 发表于: 2010-04-09
价格是多少?还需要一个hf短波阻抗测试仪,用于调螺旋宽带天线,目前只能调到9-25MHZ
离线关则勇
只看该作者 11楼 发表于: 2010-04-09
这台怎样........
离线mylcq
只看该作者 12楼 发表于: 2010-04-09
不错不错,多少钱?
离线关则勇
只看该作者 13楼 发表于: 2010-04-10
要几万呀.................
