  • 3246阅读
  • 5回复
今天收到的ARRL发的DX信息(2010.01.22) [复制链接]
离线BG4WCE
只看楼主 倒序阅读 0楼 发表于: 2010-01-22
tunisia, 3v. members of two tunisian clubs are qrv with special
callsign ts8rw until february 14 in celebration of rover week. qsl
via operators' instructions.
tanzania, 5h. igor, ua3djy is qrv as 5i3a until march 1. activity
is on all bands. qsl via rk3aol.
uganda, 5x. nick, g3rwf is qrv as 5x1nh until march 21. activity
is on all bands, except 160 meters, using cw, ssb, rtty and psk.
qsl to home call.
senegal, 6w. tom, gm4fdm and ronald, pa3ewp will be qrv as
6w/homecalls from le calao from january 26 to february 9. activity
is mainly on the low bands using rtty. qsl via operators'
instructions.
juan fernandez island, ce0. toshi, ja8bmk is qrv as xr0za from
robinson crusoe island, iota sa-005. activity is on 160 to 10
meters with an emphasis on the lower bands, using cw, ssb and
digital modes. qsl direct to home call.
germany, da. special event stations dr2010l, dr2010o and dr2010n
are qrv throughout this year in celebration of essen and the ruhr
area, capital of culture 2010.
scotland, gm. operators mm0dfv and gm0wrr will be qrv as mm0dgr/m
from the braehead moss national nature reserve on january 23.
activity will be on 80 to 10 meters using cw, ssb, rtty and psk.
qsl via mm0dfv.
solomon islands, h4. bernhard, dl2gac is qrv as h44ms from
guadalcanal, iota oc-047, until april 19. this includes activating
temotu province in february. activity is on 80 and 40 meters using
mainly ssb. qsl to home call.
thailand, hs. eddy, on4afu is qrv as hs0zjf/8 from koh samui, iota
as-101, until january 30. qsl to home call.
dominica, j7. gaynell, kk4www is qrv as j79www until february 4
while on work assignment. she is active in her spare time. qsl via
n4usa.
minami torishima, jd1. masa, jd1bmm is qrv from marcus island, iota
oc-073, until the end of february. qsl via bureau.
mongolia, jt. sank, jt1as is qrv as jt70as throughout the year in
celebration of his 70th birthday. activity is on the hf bands using
rtty and psk. qsl to home call.
fernando de noronha, py0f. fred, py2xb will be qrv as py2xb/py0f
from january 23 to february 3. he will be active as pq0f in the
upcoming cq ww 160-meter contest. activity is on all bands using
cw, ssb, rtty and psk. qsl both calls via pt7wa.
mount athos, sv/a. monk apollo is usually qrv using rtty on 160,
80, 40 and 30 meters around 1700 to 2100z. qsl direct.
east kiribati, t32. don, g3bj is qrv as t32bj from christmas
island, iota oc-024, until january 26. activity is on the low bands
using mainly cw. qsl to home call.
belize, v3. gerd, dj4kw and gisela, dk9gg are qrv as v31yn and
v31gw, respectively, until february 28. activity is on 160 to 10
meters using cw, ssb and rtty. this includes activity in several
contests held during this time. qsl to home calls.
falkland islands. michael, g7vjr and martin, g3zay are qrv as
vp8dmn from east falkland, iota sa-002, until january 29. qsl via
g7vjr.
india, vu. norbert, dj9rb is qrv as vu2rbq until february 2. this
includes an entry in the upcoming cq ww 160-meter contest. qsl to
home call.
vanuatu, yj. nikola, 9a6dx, hrvoje, 9a6xx and marko, 9a8mm are qrv
as yj0dx, yj0xx and yj0mm, respectively, from efate island, iota
oc-035, until january 28. activity is on 160 to 10 meters using cw,
ssb and rtty. qsl all calls via 9a8mm.
离线BD4HZ
只看该作者 1楼 发表于: 2010-01-22
没看懂,麻烦简单的解释一下。哈哈哈哈
离线BA1RB
只看该作者 2楼 发表于: 2010-01-22
刚才通到了yj0mm,很响亮,up1.3,2遍过去就ok了。
离线BA7NO
只看该作者 3楼 发表于: 2010-01-23
哪个波段?
离线BA1RB
只看该作者 4楼 发表于: 2010-01-23
哪个波段?
40m, 7005
离线BA7NO
只看该作者 5楼 发表于: 2010-01-24
40m, 7005
40m有了,80m干了2小时拿不下....... 睡觉去..zz..zz..zz.z.
