  • 3960阅读
  • 3回复
HA1AH Contest Software [复制链接]
离线ba2ia
只看楼主 倒序阅读 0楼 发表于: 2010-01-20
ha1ah contest software
note that ha1ah contest software is a frozen project. i neither develop the software, nor support it, any more.
the ha1ah contest software is a graphical logging program for radio amateurs. it is a java program and can run on windows 95, 98, nt4, 2000, xp and linux.
to run the software you need to install the java runtime environment 1.4 or higher. you can download the current jre from here: http://java.sun.com/j2se/1.5.0/download.jsp
the current version of the software supports the following contests:
cq ww dx
ha dx
arrl dx for k/ve stations
arrl dx for non-k/ve stations
russian dx for russian stations
russian dx for non-russian stations
main features:
network over lan or/and serial ports
use of packet radio and internet telnet clusters
very good automatic multiplier recognition of cluster spots
use of master.dta file for searching callsign partials
use of own database for recognition us states and canadian provinces
real-time summary and multiplier counting
fullscreen mode
sending cw signals to radio, ptt support
automatic callsign extension
merge of multiple data files
log files in cabrillo and human readable formats
user customized colors and font sizes
export/import of adif files
record operator's voice and send it to the radio
change and administrate operator
the current version is v0.8.4 released december 14, 2005.
this is a screenshot with font size 25 under screen resolution 1600x1200. the size of the main window is 800x600.
this is a screenshot of fullscreen mode under screen resolution 1920x1440 with font size 30.
fullscreen mode under screen resolution 1600x1200 with font size 25.
screenshot with default (12) font size.
if you have any questions or suggestions please contact me here: ha1ah@freestart.hu
the software has two editions:
base edition: it includes the base functions to store contest qsos and to create log files.
professional edition: it includes such further features like network, sending cw signals, telnet and packet dx-cluster access, export and import of adif files, record and play of voice.
both base and professional edition are freeware, you can use it without any charge.
to get information about the program read the documentation with screenshots.
if you want to save the documentation click on the link above by the right mouse button and select the 'save link as' or 'save target _as...' menu item.
to see the changes to previous versions look at the changes.txt.
download the install package of the program.
if you want to update the cty.dat file for recognizing dxcc countries you can download it from here. (if this file appears in your browser click on the link with your right mouse button and select save file.)
place it under the specialdata directory of your program installation.
if you want to use master.dta file created by k5zd for searching for callsign partials you can download it from here. save the file and place it under the specialdata directory of your program installation.
if you want to use the state_database.bin file generated from the official callsign database of fcc and rac to recognize us states and canadian provinces in advance download it from here.
unzip the downloaded file into the specialdatadirectory of your program installation.
tibor finta
ha1ah
离线ba6qr
只看该作者 1楼 发表于: 2010-01-20
谁吃了螃蟹?
离线kentwu
只看该作者 2楼 发表于: 2010-01-20
这个没用过,谢谢介绍。哈哈。
离线ba2ia
只看该作者 3楼 发表于: 2010-01-21
这是一款 比赛日志 自动受理与分析系统~~~~国内目前没比赛。,这东西 暂时一点用没有。抓来玩玩罢了
