  • 6505阅读
  • 0回复
玩卫星通信的利器-U/V BAND YAGI 天线 [复制链接]
离线woto
只看楼主 倒序阅读 0楼 发表于: 2010-01-05
美国hy-gain出品(现为美国mfj旗下品牌)
the db-218sat is a complete 2 meter/440 mhz oscar antenna system. it contains the crossboom assembly with necessary phasing lines, relays, and hardware. it includes left and right circuitry switching to reduce fading. true rf switching elements are rated at 200 watts and improved vswr for higher efficiency. feed points are encapsulated and weather protected for longer life. made of fiberglass, the crossboom maintains the integrity of the circularity pattern.
下载附件看详细资料吧...
美国参考价: us $599.95
附件: DB-218SAT.pdf (0 K) 下载次数:35
