  • 3326阅读
  • 3回复
关于KEY CLICK,时序控制等... [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2009-12-02
我今天在看讨论组的信的时候看到了这个话题,想了一下还是放在dx版比较合适,dxer尤其是contester,更加应该注意自己的信号情况。
如何调整自己的机器,使之正确地工作是我们每个人都应该学会的。
抱歉是英文...
>i suspect that over-driving an external amplifier is a major cause of
> excessive clicks on the bands today. many hams think that cw doesn't
> require
> the final amplifier be linear and drive their rigs into saturation. but a
> "linear" amplifier needs to be linear for cw just as with any amplitude
> modulation (ssb, am, cw, etc.)
key clicks also occur when bias is suddenly applied to an amp where the
transceiver is already producing an rf envelope. i recently experienced
this when i purchased the spe 1k-fa solid-state amp.   the amp is advertised
as being "full qsk" compatible. however, it uses general purpose frame
relays at the rf input and output. as such, the firmware is programmed to
apply bias at a very long 15 msec after the amp's relay line is pulled low
by the transceiver. the problem isn't terribly bad with a transceiver like
the k3 as its rf envelope can be delayed in the k3 menu. however, rigs like
the icom 7700 and 7800 produce rf at ~ 9 msec. after key closure and there's
no menu to adjust it. on the scope, wysiwyg.
in the k3's default setting of 8 msec., my spe amp was hot switching as a
result of bias being applied at 15 msec when the k3 was already producing
its rf envelope at exactly 12 msec after key closure. and so, the rf
envelope was being truncated by 3 msec in full qsk mode. spe chose that
bias time to give the general-purpose frame relays an opportunity to settle
without contact bounce. sure, the amp's relays were not being hot-switched,
but the effect of key clicks is the same when the sudden onset of bias
causes the fet output transistors to instantly conduct, producing a sharp
vertical rise time of the rf envelope.
i then delayed the k3 to 16 msec and the hot-switch problem disappeared.
but in doing so, the keyed elements were also being shortened, albeit
without rf hot-switching. that fix requires use of pulse-stretching key
compensation using an external keyer. next, i tried using the k3's tx inh
handshake with the spe amp. more dit shortening problems. was the problem
with the k3 or the spe amp. i honestly don't know and don't care. i only
care that there's a viable solution is available. really, the only way to
cleanly fix these problems is at the source of the timing issue.
the solution: i ended up modifying a beat-up ameritron qsk-5, keeping the
logic interface between the qsk-5 and the spe amp100% optically-isolated.
http://72.52.250.47/images/qsk-5-interface.pdf
now, instead of the amp's firmware setting the bias activation time, the
qsk-5 tells the spe amp when to apply bias. qsk is pretty awesome with this
set-up and even the first leading 'dit' switches cleanly with no keyed
element shortening. long-term, the fix calls for using a gigavac gh-1
vacuum relay at the amp's output and an aromat rsd-12v rf reed relay at the
amp's input. spe has sent me the revised firmware that reduces bias time to
8 msec, but that requires an eeprom programmer and a spare chip that i need
to order. but with either solution, bias key clicks won't be a problem.
paul, w9ac
离线BA4TB
只看该作者 1楼 发表于: 2009-12-02
陈大官人又推销qsk啊
离线VR2KW
只看该作者 2楼 发表于: 2009-12-02
其实这个问题很普遍,很多功放不支持qsk,而且用家没有设置ptt to cw delay,经常的ja变成oa,ua变成aa。
另外,用winkey之类的keyer,能最大程度的解决cw乱码的问题。
离线BA4RF
只看该作者 3楼 发表于: 2009-12-03
qsk我根本不用,但觉得确实应该让每个人关注自己信号的好坏。
比赛中最怕通欧洲的时候出来一个小信号的jh2之类的,那你8成抄成oh2而且强度/时间都配合得上。
比赛中更怕的是自己的信号占据的带宽过大干扰到别人,这方面原因很多,有上面提到的上升下降沿过快,功放激励过大,甚至功放本身就不线性等问题。
记得比赛中nq找我们听b7p 21mhz的信号,最后发现激励过大,连cw信号都变调了。
