  • 2326阅读
  • 0回复
Icom ID-80 [复制链接]
离线bd7oi
只看楼主 倒序阅读 0楼 发表于: 2009-11-13
type: amateur vhf/uhf transceiver
frequency range: tx: 144-146 / 430-440 mhz (asia)
rx: 0.5-999 mhz
(5 / 6.25 / 8.33 / 9 / 10 / 12.5 / 15 / 20 / 25 / 30 / 50 / 100 / 125 / 200 khz steps)
mode: rx: am/fm/nfm and dv (gmsk: 4.8 kbps voice)
tx: fm/nfm and dv (gmsk: 4.8 kbps voice)
rf power output: hi: 5 / 5 w
lo: 500 / 500 mw
receiver system: n/a
sensitivity: n/a
selectivity: n/a
image rejection: n/a
voltage: 7.4 vdc (battery pack)
10-16 vdc (external)
current drain: rx: ? ma
tx: ? a
impedance: 50 ohms, sma
dimensions (w*h*d): ? mm
weight: ? gr
manufactured: japan, 2009-20xx
other: d-star concept. ctcss and dtcs
gps speaker-mike option (hm-189gps)
