  • 6588阅读
  • 17回复
手机上也能玩cw! [复制链接]
离线jnwysh
只看楼主 倒序阅读 0楼 发表于: 2009-10-29
发现一个软件
pocketdigi - ham radio digital modes for the pocketpc
http://www.n0hr.com/pocketdigi/pocketdigi_intro.htm
但是不知如何使用?
离线jnwysh
只看该作者 1楼 发表于: 2009-10-29
ppcmorse tutorial
learn morse code on your pocketpc pda!
the ppcmorse forum is now online at http://www.n0hr.com/phpbb.
1) download and install ppcmorse. be sure to use the default installation directory.
2) launch ppcmorse from the start menu or from the program files directory.
3) ppcmorse main screen
4) configure buffer parameters from the settings menu.
choose settings -> buffer/parameters. once this screen appears, select the frequency (pitch), message, dit length, spacing and weight.
select the ok button once the parameters have been set.
settings explanation...
this question leads to a discussion of ppc platform compatibility. the issue is simply that reliable/stable morse apps can be easily written for the desktop pc because the programmers can use fairly deterministic timers within the pc. on a pda, there is no "real-time" timer to count on as always being there, and stable. one "tick" on a particular pda, with a particular cpu, and particular implementation of ce may be one duration on one pda, and another on another. this is why i let the user configure the dit length, spacing and weight.
if you find some settings that sound approximately "ok", try this (with a stop watch):
in the buffer, have it send the word paris repeatedly. tell it to send it 20 times (with spaces between: "paris paris paris...").
time the duration it takes to play those 20 "paris" words.
the calculation would be:
x wpm = 20 divided by the time (in minutes) required to play
so, you might try some settings that play 20 "paris's" in
1.021 minutes giving you: 20/1.021=19.6 wpm
"paris", by the way, is sort of a standard for this sort of thing.
for someone learning the code, i'd highly recommend the koch method:
http://www.ees.nmt.edu/sara/sara/finley.morse.html
http://www.hfradio.org/koch_1.html
in a nutshell, you start by learning a very small set of letters - but played at the speed you eventually want to get to (not any slower). for example, the letters "k", "m" and "a" played at 20 wpm (character speed). once you've hit some level of mastery of those (say 90%), add a letter and keep practicing until you're at 90%.
i did not learn cw this way (20 years ago), but wish i had. i can now copy @25 wpm in my head with little trouble, but think i would've got there faster by initially learning with this method. others agree. i've designed ppcmorse to be "koch-friendly".
so, to answer your question, i'd recommend setting the pda to sound like it's playing the characters at a relatively fast pace (you might even pipe the audio back into a program like cwget http://www.dxsoft.com/micwget.htm to measure it in software), then adjust the spacing such that you are hearing bursts of a few characters that you know and build from there.
for example, on my ipaq, i'd start out a cw newbie with something like this:
  wpmfactor = 44,
  spacingfactor = 100
  weightfactor = 100
  settings->practice
  toggle everything off
  select "alpha", select it again.
  select "numbers", select it again.
  select "special", select it again.
  choose your starting characters, "k", "m"
notice that your practice characters will be displayed as well as the character group (word) that was just sent. check your copy as it comes in. to a newbie this will seem fast at first. the analogy is a spanish language student watching spanish tv must think that things are going too fast - but he doesn't have the option of asking them to slow down. however, he can learn quickly by watching/listening to spanish tv shows for children because the vocabulary is small - and build from there.
by the same token, start with a limited "vocabulary"/set of characters, and build from there at your 'destination' speed. studies have shown (and i'd believe it) that trying to slow things down too much results in your brain automatically shifting to "dit and dah counting mode" - rather than
learning to hear the patterns/rhythms.
5) playing the buffer
choose play->buffer to play the text in the buffer.
6) practice mode - available to ppcmorse-pro users
select the characters that you would like to practice. groups of characters can be "toggled" by choosing either "alpha", "numbers" or "special". the number of groups to be sent is configured with the "groups" field.
press the "set" button when you have finished.
7) playing practice mode
once the practice parameters have been set, you can play a practice session. note that groups vary (randomly) in length of 3 to 7 characters each.
8) registration: ppcmorse-pro
once you have registered ppcmorse-pro, you may enter the code that was emailed to you using the registration screen:
离线jnwysh
只看该作者 2楼 发表于: 2009-10-29
ppcmorse frequently asked questions (faq)
q) the installation seemed to work. however, when i try to use the program, i do not hear any sound.
a) ppcmorse expects to find a set of sound files in a directory named /program files/ppcmorse
if the application cannot find these files, nothing will be heard. to correct this problem, create a directory named /program files/ppcmorse and move the files from the current ppcmorse installation directory to this new directory. note that problem often occurs with international users as different versions of the windows ce operating system may have a different directory name (such as "/programme/ppcmorse").
离线jnwysh
只看该作者 3楼 发表于: 2009-10-29
请高手指点一下使用方法
离线bg8jb
只看该作者 4楼 发表于: 2009-10-29
等哪位搞个出来,也装到手机上耍起。
离线jnwysh
只看该作者 5楼 发表于: 2009-10-29
ppcmorse downloads
download the pocketpc/windows ce morse code tutor software here!
pocketpc 2002, windows mobile 2003, and pocketpc phone pdas:
ppcmorse version 1.2.73 (for pocketpc pdas): ppcmorse_1_2_73.exe
this update includes a fix for sending the number 6 which would not properly send the morse code character on some pdas.
this version is for older pdas that use mips or sh3 processors. it will not function with the recent versions of pocketpc os:   ppcmorse version 1.0 (for wince 2.11 pdas): ppcmorse_ce211_1_0.exe
for any installation or technical questions, see the faq page or visit the forum.
previous version:
ppcmorse version 1.0 (for pocketpc pdas): ppcmorse_1_0.exe
international users - please read the faq before installing ppcmorse.
离线BG2ISM
只看该作者 6楼 发表于: 2009-10-29
我的手机是wm6的
先记号一下.明天到单位鼓捣
离线bg6art
只看该作者 7楼 发表于: 2009-10-30
cyclone
离线jnwysh
只看该作者 8楼 发表于: 2009-10-30
在电脑上用activesync链接ppc,运行电脑中的程序文件,在ppc上选择安装位置,完成安装。
经试用可将输入的字符以morse声音播出,能调节发音频率、点划长度、间隔,但调节不够方便。
要使用koch训练法,则需要注册,请高手帮忙!
网上可搜到几个crack链接,但不能进去,网址被屏蔽、过滤了?
离线BD6MM
只看该作者 9楼 发表于: 2009-10-30
好东西,我的手机系统是windows mobile6.5,用不了,但是帮顶了!
离线BG2ISM
只看该作者 10楼 发表于: 2009-10-30
后面贴的ppcmouse装好了,能运行,可以根据输入的内容发音频报
一楼的软件还没弄明白,x86版的能在pc上运行,总出错关闭;ppc的还正在下.
看网站介绍似乎有点意思.整明白了跟贴告诉大家
离线BG2ISM
只看该作者 11楼 发表于: 2009-10-30
谁能把1楼的软件,for arm版的下载了发到我手机139信箱?谢谢!
离线jnwysh
只看该作者 12楼 发表于: 2009-10-30
1楼的软件确实不太好下载,放在这里啦!高手先摸索使用方法!
附件: PocketDigi_1_0_11.rar (0 K) 下载次数:170
离线BG2ISM
只看该作者 13楼 发表于: 2009-10-30
多谢13楼
软件装上了,整不明白!!-_-
离线BD2ALB
只看该作者 14楼 发表于: 2009-10-30
pocketdigi可以操作psk31、mfsk16模式!我以前转过这个软件的。
离线bg6art
只看该作者 15楼 发表于: 2009-11-04
我已经把注册码贴在8楼了
离线jnwysh
只看该作者 16楼 发表于: 2009-11-06
我已经把注册码贴在8楼了
太感谢了!
离线bd8cb/8
只看该作者 17楼 发表于: 2009-12-19
谁上传一个win ce 2.11下能用的pocketdigi程序,我这里出不了国,谢谢啦。
