  • 3249阅读
  • 4回复
请教FT-212H怎么扩到136-174MHZ [复制链接]
离线bg4xyb
只看楼主 倒序阅读 0楼 发表于: 2009-10-29
请教ft-212h怎么扩到136-174mhz.不知道里面的接点怎么连接,有谁知道的请告诉我.谢谢!
离线bg4xyb
只看该作者 1楼 发表于: 2009-10-30
没有人会吗??那是死机了,到明天再搞不好就用144-146了
离线调频无限
只看该作者 2楼 发表于: 2009-10-30
ft 212rh extended freq. coverage mod.
remove the bottom and top covers and remove the front panel cover. you
must then remove the front board by carefully unpluging it (try not to
touch the lcd display). on the back of this board which is the control
unit locate jumpers 1 through 12 and unsolder any that are soldered. all
jumpers must be open (1-12 only). reinstall the control unit and just
turn on the radio for a few seconds. now turn it off again and remove
the control unit again and solder jumpers 3, 4, 5, 11 only.
put everything back together and apply power. the display will read 000.
push the mhz button and rotate the main dial until 132.000 reads on the
display, then press d/mr once. now press again the mhz button and rotate
to 180.000 and press the d/mr again.
the radio is now programmed to operate from 132 to 180 mhz. mine has tx
and rx through the entire spectrum with excellent sensitivity from 136
to 178. dont forget that transmitting outside the amateur band is not
allowed so please consult your local athorities for a special permit.
离线bg4xyb
只看该作者 3楼 发表于: 2009-10-30
[quote=调频无限]ft 212rh extended freq. coverage mod.
allowed so please consult your local athorities for a special permit.[/quote]
按照您的方法换了,只显示200mhz,并且不存频率,还有个l在闪,晕了我,再请教.谢谢
离线BH7MGF
只看该作者 4楼 发表于: 2010-03-24
接通电时显示l 200时,转动调频旋钮,把频率调到136.000后按d/mr确认一下,之后l变成u后,把频率调到174.000后再按d/mr确认一下!ok.
