  • 3396阅读
  • 9回复
这天线太有意思了,有会克隆的吗? [复制链接]
离线beetle
只看楼主 倒序阅读 0楼 发表于: 2009-10-22
the mp antenna super-m ultra mobile antenna provides very high performance. the receive range is 25 to 6000 mhz. it may be used for transceive applications at these frequencies: 120 to 6000 mhz. power capacity is 200 watts below 512 mhz and 100 watts above 512 mhz. the unique design is dual polarized to provide a big signal at the horizon and out of the valley with reduced flutter and picket-fencing. this antenna may turn a few heads on the highway, but its strange appearance, with unique design, provides impressive gain and low vswr throughout its entire operating range.
this antenna requires an nmo mount and coax cable (neither provided).
打开地址自己看吧:
http://www.universal-radio.com/catalog/hamantm/1304.html
离线beetle
只看该作者 1楼 发表于: 2009-10-22
离线beetle
只看该作者 2楼 发表于: 2009-10-22
离线beetle
只看该作者 3楼 发表于: 2009-10-22
离线beetle
只看该作者 4楼 发表于: 2009-10-22
离线beetle
只看该作者 5楼 发表于: 2009-10-22
designed for two-way government/commercial radio communications, the super-m 400™ mobile antenna seamlessly covers the frequency range from 400mhz to 500mhz. showcasing multi- polarized technology with mp antenna design and production standards, the super-m 400™ mobile antenna is the ideal antenna for any government or commercial vehicle.
scanner 400mhz-500mhz
two-way radio 400mhz-500mhz
离线beetle
只看该作者 6楼 发表于: 2009-10-22
离线BG3SJU
只看该作者 7楼 发表于: 2009-10-22
来个uv段天线看看
只看该作者 8楼 发表于: 2009-10-22
类似盘锥天线
离线beetle
只看该作者 9楼 发表于: 2009-10-22
[表情]   [表情]
来个uv段天线看看
m-pol™ = multi-polarized ,多极天线。。。。赶紧弄吧!老卫,我是159,p-12的啥时候能发呢?
