  • 6143阅读
  • 8回复
上组漂亮的车载HF天线 [复制链接]
离线woto
只看楼主 倒序阅读 0楼 发表于: 2009-08-14
先欣赏一下,,,还没有货的
离线woto
只看该作者 1楼 发表于: 2009-08-14
效果比yaesu的atas-120强许多...usd$xxx
离线BA5AP
只看该作者 2楼 发表于: 2009-08-14
梁老板提供一下数据吧。
离线bd2fw
只看该作者 3楼 发表于: 2009-08-14
打劫
离线bd7oi
只看该作者 4楼 发表于: 2009-08-15
hi-q 值得搞条玩玩
离线woto
只看该作者 5楼 发表于: 2009-08-24
梁老板提供一下数据吧。
看看这个
providing a frequency coverage of 2 to 30mhz, the barrett 910 features rapid tuning (typically <1.5s) and low power consumption. high radiation efficiency and accurate tuning are assured by maximising antenna current (not minimising the vswr) on every tune. the barrett 910 antenna incorporates a wideband amplifier that is activated in receive mode to enable channel scanning. due to its rugged rf design the barrett 910 antenna can also be used with high duty cycle applications such as the barrett 923 or 2020 fax and data system.
the active tuning elements of the antenna are housed in a grey weatherproof, impact resistant reinforced poly-carbonate moulding that incorporates a heavy duty anti-vibration mount at its base, even with its rugged construction, the barrett 910 weighs only 2.8kg.
the barrett 910 is supplied with an integral 2 metre whip and spring. the main antenna body has a 1.5 metre stub control cable, with a 4.5 metre extension cable to connect it with the transceiver. this composite cable incorporates coaxial, power supply and control cables. additional 4.5 metre or 10 metre extension cables are available if required.
specifications
frequency range: 2 to 30mhz continuous
rapid tuning: 1.5s (typical)
power rating: 125 watt pep - voice and data
input impedance: 50 ohm
vswr: better than 2.1
current drain: 600ma (typically)
body length: 610mm
whip & coil length: 1740mm
integral whip and spring length: 2000mm
maximum diameter: 120mm
body weight: 2.6kg
integral whip and spring weight: 0.50kg
mounting: 0.5" bsw stud, length 45mm
离线BG7PHA
只看该作者 6楼 发表于: 2010-05-19
这个是自动的么?
离线赵宇宁
只看该作者 7楼 发表于: 2010-05-19
肯定是自动的,里面有电机的
离线bg6art
只看该作者 8楼 发表于: 2010-05-20
高q的电动螺丝刀
