  • 6381阅读
  • 15回复
LDG Z-11Pro ULTRA手自一体天调 [复制链接]
离线BG2RHY
只看楼主 倒序阅读 0楼 发表于: 2009-07-23
includes installed & tested battery holder ,
1 ea. of ic-2 cable, y-acc cable,
coax cable, & power cable
(requires 6 aa batteries, user provided)
the z-11pro, everything you always wanted in a small, portable tuner designed from the ground up for shack and battery operation; and only w4rt offers the z-11pro ultra with installed battery holder! an optional battery holder can be purchased for the z-11pro (blemished units too), which can be easily installed by the user. only 5" x 7.7" x 1.5" and weighing only 1.5 pounds, it handles 0.1 to 125 watts, making it ideal for both qrp and standard 100 watt transceivers from 160 through 6 meters. the z-11pro has 8,000 memories in ldg's exclusive 3-d memory array, automatically storing tuning configurations for each frequency and band as you use them, for each of four antennas on the single rf port. frequency sensing circuitry lets the z-11pro know your operating band and frequency. whenever you transmit on or near a frequency you've used before, the z-11pro retunes from memory almost instantly (even in ssb!). memories are retained indefinitely. rugged and easy-to-read leds indicate swr and status. the z-11pro uses latching relays which retain the tuned configuration even when powered down; current draw when not tuning is effectively zero. control from the front panel is simple and straightforward; just press tune while transmitting, and the z-11pro will begin a tuning cycle. the z-11pro will even tune while you talk on am or ssb. for more integrated operation, optional interfaces are available for most icom, kenwood, yaesu and alinco transceivers. with the interface, a single button-press transmits a carrier, executes a tuning cycle and returns the radio to its original power and mode. add the special steel top if you need to use magnetic mounts (only from w4rt). really nice to mount your cw key (like the palm paddles) or microphone when operating portable!
specifications
• 0 to 125 watts ssb and cw peak power, 100 watts digital
• easy to read leds indicate swr and status
• 8000 "3-d" memories for instantaneous frequency or band changing
&#8226; tuning time: 0.1 to 4 seconds full tune, < 0.1 second memory tune
&#8226; built in frequency counter for memory operation
&#8226; frequency coverage: 1.8 to 54.0 mhz.
&#8226; tunes 6 to 1000 ohm loads (16 to 150 ohms on 6m), 6 to 4000 ohms with optional 4:1 balun (ldg rba-4:1)
&#8226; for dipoles, verticals, vs, beams or and coax fed antenna
&#8226; optional external balun allows tuning of random length, long wire or ladder line fed antennas
&#8226; interfaces for icom and yaesu included
&#8226; power requirements: 8 to 16 volts dc at 300 ma max during tuning, 25 ua idle
&#8226; enclosure: 7.5 x 5.75 x 1.75 inches
&#8226; weight: 1.5 pounds (no internal batteries)
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 设备 - LDG Z-11Pro ULTRA手自一体天调
离线BG2RHY
只看该作者 1楼 发表于: 2009-07-23
离线BG1EAO
只看该作者 2楼 发表于: 2009-07-23
看看内部的样子哦!
离线幽游白狐
只看该作者 3楼 发表于: 2009-07-23
很快啊! 都到手了~
离线BG2RHY
只看该作者 4楼 发表于: 2009-07-23
看看内部的样子哦!
我贴了啊 你使劲看 不收费
要是不过瘾 就来我这给你看真的
离线BA1IO
只看该作者 5楼 发表于: 2009-07-23
的色好货!支持!
还可以用电池比较满意!
离线BG2RHY
只看该作者 6楼 发表于: 2009-07-23
的色好货!支持!
还可以用电池比较满意!
和z817相比
塑料壳子变成了金属壳子
4节电池变成了6节
25w变成了125w
1000个记忆点变成了8000个记忆点
所以我说是z-817 plus
离线BG2QHW
只看该作者 7楼 发表于: 2009-07-24
看到7k已经搞回来了,ldg z-11pro ultra手自一体天调是多少银两搞回来的!
离线公鸡先生
只看该作者 8楼 发表于: 2009-07-24
来看 rhy 的新设备
离线bg2txv
只看该作者 9楼 发表于: 2009-07-24
rhy是玩命折腾ldg啊,z100 z817 z-11pro …………
离线BG2RHY
只看该作者 10楼 发表于: 2009-07-24
前面那俩都卖了
怀念一下
离线BH1JCL
只看该作者 11楼 发表于: 2009-07-24
前面那俩都卖了
怀念一下 [表情]
你的z-817在我这呢,想怀念随时来呀,哈哈。
离线BG2RHY
只看该作者 12楼 发表于: 2009-07-24
哈哈 玩的咋样了?
离线BA1IO
只看该作者 13楼 发表于: 2009-07-24
和z817相比
塑料壳子变成了金属壳子
4节电池变成了6节
25w变成了125w
1000个记忆点变成了8000个记忆点
所以我说是z-817 plus [表情]
太大!长了很多!hw那个857的就是!可以微调还不错!
离线BG2RHY
只看该作者 14楼 发表于: 2009-07-24
是的 ldg的调自动还不是很智能 往往都调到1.2了 自己又傻乎乎的给调到1.5去了
还得手动给它调回来
离线bd7cv
只看该作者 15楼 发表于: 2009-07-24
[表情]
还用上了温控器
