  • 3003阅读
  • 4回复
咱也有BUG [复制链接]
离线bd3ct
只看楼主 倒序阅读 0楼 发表于: 2009-06-26
咱也有bug
离线bd3ct
只看该作者 1楼 发表于: 2009-06-26
有谁知道,这是什么?
离线BA1IO
只看该作者 2楼 发表于: 2009-06-26
微缺陷检测
rf signal detector 射频信号探测器
beeper size camera / mobile / bug detector bp机大小相机/手提电话/错误检测
made for general use, no need for professional electronic training or knowledge. 经费用于一般用途的,不需要专业的电子培训或知识。
this unique technique is applied to detect peeping cameras, tapping, cellular phones and other radio frequency devices. avoid peeping or tapping to protect privacy or protect information being disclosed secretly. stop disturbance of cellular phones communication within desired control areas. 这种独特的技术应用到检测偷窥摄像机,窃听 , 手机和其他无线电频率装置。避免偷窥或窃听 , 以保护隐私或保护信息披露秘密。停止干扰手机通信领域内所需的控制。
sh-055sv has 3 leds. when it discovers cellular phone or peeping camera, the leds will light from level 1 to level 2 to level 3 , and the beeping sound will change from slow to rapid indicating the strength of detected signal. 的sh - 055sv了3发光二极管。当发现移动电话或偷窥相机,发光二极管将光线从1级2级到3级 ,以及响闹声音会从慢到快 , 说明检测到的信号强度。
sh-055sv has vibration warning mode, just set the switch to silent. it will reduce the embarrassing of beep sound when scanning an environment. user also can detect by earphone hearing without others aware. specially designed for easy and simple use, which does not require complicated installation ro any professional knowledge. 的sh - 055sv了振动报警模式,只需设置切换到沉默 。 它将减少尴尬的蜂鸣声时 , 扫描的环境。用户还可以检测到的耳机听没有别人知道。专为轻松和简单的使用,这并不需要复杂的安装反渗透任何专业知识。
detecting distance: 探测距离:
wireless camera: 无线摄像机: 1.2ghz - about 20ft., 2.4ghz - about 5ft. 1.2ghz的-关于二十○英尺, 2.4 -关于五英尺
cellular phone: 手机: about 20 ft. 关于二零英尺
applications: 应用:
hospitals, medical centers or intensive care units, where cellular usage is forbidden. 医院,医疗中心或重症监护病房,其中移动电话的使用是被禁止的。
offices, factories, cinemas, theaters, concerts, museums or art galleries that prevent video body bugs. 办公室,工厂,电影院,剧院,音乐会,博物馆或美术馆 , 防止视频身体缺陷。
military or government premises that cellular or camera recording is forbidden. 军事或政府办公场所 , 手机或相机记录是被禁止的。
offices, restaurants or any commercial premises that would like to shun away cellular or rf disturbance. 写字楼,饭店或任何商业处所想顺了蜂窝或rf干扰。
find best signal spot for wireless cctv 寻找最佳信号位置无线闭路电视
detect peeping camera in shopping mall toilet, school toilet, locker room and fitting booth, club house, hotel, etc. 检测偷窥相机商场的厕所,学校厕所,更衣室及装修展台,会所,酒店等
specifications: 规格:
size: 大小: l 87 x w 55 x t 24mm l 87 x宽55 x Ť 24毫米
weight: 重量: about 85g (including battery) 关于八十五克(包括电池)
power: 功率: 3v dc (aaa/um-4 battery x2) 3v的直流电( aaa/um-4电池x2处理器)
detecting frequency: 检测频率: 50mhz - 6.0ghz 50mhz的- 6.0ghz
warning mode 1: 警告 : 模式1 : sound and 3 leds display 健全和3个发光二极管显示
warning mode 2: 预警模式2 : vibration and 3 leds display 振动和3发光二极管显示器
warning mode 3: 预警模式3 : silent, 3 leds display and earphone output 沉默, 3的led显示屏和耳机输出
sensitivity tuner: 灵敏度调谐器: eliminate the environment interference (noise) 消除环境干扰(噪声)
离线bd3ct
只看该作者 3楼 发表于: 2009-06-26
微缺陷检测
applications: 应用:
specifications: 规格:
你比较适合做侦查工作。
离线BA1IO
只看该作者 4楼 发表于: 2009-06-26
你比较适合做侦查工作。
