  • 6122阅读
  • 2回复
低功耗的 FM 发射系统 MC2833 [复制链接]
离线wb4916
只看楼主 倒序阅读 0楼 发表于: 2009-05-31
fm发射机用!
附件: MC2833EN完成 20090526 1811.zip (0 K) 下载次数:248
离线wb4916
只看该作者 1楼 发表于: 2009-05-31
第一页
order this document by mc2833/d
motorola
mc2833
low power fm transmitter system
semiconductor technical data
mc2833 is a one-chip fm transmitter subsystem designed for cordless telephone and fm communication equipment. it includes a microphone amplifier, voltage controlled oscillator and two auxiliary transistors.
wide range of operating supply voltage (2.8-9.0v)
low drain current (icc=2.9ma typ)
low number of external parts required
-30 dbm power output to 60 mhz using direct rf output
+10 dbm power output attainable using on-chip transistor amplifiers
users must comply with local regulations on r.f. transmission (fcc, dot, p.t.t., etc)
p suffix plastic package case 648
d suffix plastic package case 751b (so-16)
ordering information
mc2833/d 的规格书
motorola
mc2833
低功耗的 fm 发射系统
半导体技术手册
低功耗的 fm 发射系统
mc2833 是一款单芯片的 fm 发射机子系统,它适用于无绳电话、fm 通信设备。它内置了麦克风放大器、电压控制振荡器与两个起辅助作用的晶体管。
工作电压范围宽(2.8-9.0v)
漏电流低(典型值:icc=2.9ma)
所需要的外置元件少
使用直接 rf 输出,在 60 mhz时,可达到 -30 dbm 的功率输出
在使用内置晶体管放大器时,可达 +10 dbm 的功率输出
用户必须遵守当地的 rf 发射有关的法律法规(例如:fcc、 dot、p.t.t.……)
p 后缀的塑料封装
648 号
d 后缀的塑料封装
751b 号(so-16)
订货须知
第二页
maximum ratings
electrical characteristics (vcc = 4.0 v, ta = 25°c, unless otherwise noted)
fm modulator
mic amplifier
auxiliary transistor static characteristics
auxiliary transistor dynamic characteristics
最大额定值
电气特性(vcc = 4.0 v,ta = 25°c,除非另外说明)
fm 调制器
mic 放大器
辅助晶体管静态特性
辅助晶体管动态特性
第三页
figure 1. test circuit
figure 2. single chip vhf narrowband fm transmitter
notes:
1. components versus output frequency:
2. crystal x1 is fundamental mode, calibrated for parallel resonance with a 32 pf load. the final output frequency is generated by frequency multiplication within the mc2833 ic. the rf output buffer (pin 14) and q2 transistor are used as a frequency tripler and doubler, respectively, in the 76 and 144.6 mhz transmitters. the q1 output transistor is a linear in the 49.7mhz and 76 mhz transmitters, and a frequency doubler in the 144.6 mhz transmitter.
3. all coils used are 7 mm shielded inductors, coilcraft series m1175a, m1282a-m1289a, m1312a or equivalent.
4. power output is ≈ + 10 dbm for 49.7 mhz and 76mhz transmitters, and ≈ + 5.0 dbm for the 144.6 mhz transmitter at vcc = 8.0 v. power output drops with lower vcc.
5. all capacitors in microfarads, inductors in henries and resistors in ohms unless otherwise specified.
6. other frequency combinations may be set-up by simple scaling of the 3 examples shown.
图1:测试电路
图2:单芯片 vhf 窄带 fm 发射机
笔记:
1、组件与输出频率:
2、晶体 x1 工作在基频模式下,所并联得 32pf 的谐振电容负载被用来来校准。最终的输出频率通过 mc2833 这款 ic 内部的倍频产生。在发射机工作在 76mhz 与 144.6mhz 时,rf 输出缓冲区(第14脚)与 q2 晶体管被用作三倍频与倍增器。在发射机工作在 49.7mhz 与 76mhz 时,输出晶体管 q1 的特性曲线是线性的,在 144.6mhz 的发射机里有一个倍频器。
3、所有的线圈都使用 7mm 的屏蔽电感,coilcraft 系列的 m1175a、m1282a-m1289a、m1312a或相当的电感。
4、对于 49.7 mhz 到 76mhz 的发射机来说,输出功率的增益约为 +10 dbm,在 vcc = 8.0 v 时,对于 144.6 mhz 的发射机,输出功率的增益约为 +5 dbm。在 vcc 下降时,输出功率会相应地下降。
5、单位:电容为 μf,电感为 h,电阻为 Ω。如果使用其它单位会事先说明。
6、可通过对如下所示的 3 个例子进行简单的改进,以生成其它所需要的频率。
离线BG9TL
只看该作者 2楼 发表于: 2009-06-01
做个无线耳机?
