  • 2671阅读
  • 1回复
IC-7800 固件已更新到v2.20 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2009-05-28
there is a new firmware update (rev. 2.20) for the ic-7800 on the english homepage of the icom inc. website.
the firmware update will provide the following improvements:
• improved transmit function in sending transmit memory contents in operation in the rtty/psk mode (using an external keypad)
• improvement in sending voice memory in ssb mode and cw memory keyer contents in the cw mode (using external usb keyboard)
• programmable custom band-edge frequencies. user hears a beep when tuning out of, or into the programmed amateur radio band. an operator can now limit transmitting outside the programmed frequency band.
流着哈喇子的点
离线BG7OAF
只看该作者 1楼 发表于: 2009-05-29
有一个新的固件升级(版本2.20 )的集成电路, 7800的英文主页上的国际博物馆理事会的公司网站。
固件更新将提供以下改进:
•改进的传输功能的记忆体内容发送传输运作的rtty /调制模式(使用外部键盘)
•改进发送语音记忆的单边带模式和连续记忆键控器内容在cw模式(使用外部usb键盘)
•可编程定制带边频率。用户听到响铃时调整的,或纳入规划业余无线电波段。运营商现在可以限制转递程序以外的频带。
www.google.com 翻译出来的
