  • 8643阅读
  • 2回复
PLL用IC MB1504的翻译 [复制链接]
离线wb4916
只看楼主 倒序阅读 0楼 发表于: 2009-05-05
为了做10米手持机。肯定用会到pll,就翻译了mc1504的datasheet。
想做成如下模样:
http://www.hellocq.net/forum/showthread-t-189729.%e9%ab%98%e6%80%a7%e8%83%bd%e4%be%bf%e6%90%ba%e5%bc%8f%e5%8d%81%e7%b1%b3%e6%9c%badiy%e9%a1%b9%e7%9b%ae.html
高性能便携式十米机diy项目
http://www.hellocq.net/forum/showthread-t-190008.16%e9%a2%91%e9%81%9325w%e7%9a%84%e5%8d%81%e7%b1%b3%e5%b0%8f%e5%8f%b0%e6%9c%ba.html
16频道25w的十米小台机
要求规格:
体积:对讲机大小
频率:28mhz-31mhz
频道间隔:5khz(原状态)
其它的待补。
非科班出身,需要掌握那些方面的知识?
另:
http://www.hellocq.net/forum/showthread-t-204067.%e6%81%92%e6%b8%a9%e6%99%b6%e6%8c%afocxo%ef%bc%8c%e9%ab%98%e7%b2%be%e5%ba%a6%e3%80%81%e9%ab%98%e7%a8%b3%e5%ae%9a%e5%ba%a6%ef%bc%8c10mhz%e5%92%8c5mhz%ef%bc%8c%e8%bf%9b%e5%8f%a3%e6%8b%86%e6%9c%ba%e4%bb%b6.html
恒温晶振ocxo,高精度、高稳定度,10mhz和5mhz,进口拆机件
用在手持机里面,会不会得到超高的稳定度??
附件内容:
mb1504的翻译.zip   翻译的文档,没有整理成一篇。
mb1504 1994.pdf   原始pdf。1994版。
附件: MB1504的翻译.zip (0 K) 下载次数:648
附件: MB1504 1994.pdf (0 K) 下载次数:586
离线wb4916
只看该作者 1楼 发表于: 2009-05-06
第1页
fujitsu
ds04-c21301-5e
data sheet
mb1504/mb1504h/mb1504l
assp serial input pll frequency synthesizer
serial input pll frequency synthesizer with 520mhz prescaler
the fujitsu mb1504/mb1504h/mb1504l, utilizing bi-cmos technology, is a single chip serial input pll frequency synthesizer with pulse-swallow function.
the mb1504 series contains a 520mhz two modulus prescaler that can select either 32/33 or 64/65 divide ratio; control signal generator; 16-bit shift register; 15-bit latch; programmable reference divider (binary 14-bit programmable reference counter); 1-bit switch counter; phase comparator with phase inverse function; charge pump; crystal oscillator; 19-bit shift register; 18-bit latch; and a programmable divider (binary 7-bit swallow counter and binary 11-bit programmable counter).
the mb1504 operates from a low supply voltage (3v typ) and consumes low power (30mw at 520mhz).
features
high operating frequency: f(in max) =520mhz (v(in min) =0.20v(p-p) )
on-chip prescaler
low power supply voltage: 2.7v to 5.5v (3.0v typ)
low power supply consumption: 30mw (3.0v, 520mhz operation)
serial input 18-bit programmable divider consisting of:
-binary 7-bit swallow counter (divide ratio: 0 to 127)
-binary 11-bit programmable counter (divide ratio: 16 to 2047)
serial input 15-bit programmable reference divider consisting of:
-binary 14-bit programmable reference counter (divide ratio: 8 to 16383)
-1-bit switch counter (sw) sets divide ratio of prescale
2 types of phase detector output
-on-chip charge pump (bipolar type)
-output for external charge pump
wide operating temperature: t(a) = -40℃ to +85℃
plastic package dip-16p-m04
plastic package fpt-16p-m06
this device contains circuitry to protect the inputs against damage due to high static voltages or electric fields. however, it is advised that normal precautions be taken to avoid application of any voltage higher than maximum rated voltages to this high impedance circuit.
fujitsu
ds04-c21301-5e
数据手册
专用标准产品:串行输入 pll 频率合成器
520mhz的分频器的串行输入 pll 频率合成器
fujitsu 的 mb1504/mb1504h/mb1504l,采用 bi-cmos 技术,是一款单芯片串行输入 pll 频率合成器,带有吞脉冲功能。
mb1504 系列带有一个 520mhz 的双模分频器,可以选择 32/33 或者 64/65 两种分频比,控制信号发生器,16 位的移位寄存器,15 位锁存,可编程的参考除法器( 二进制 14 位可编程参考计数器 ),1 位开关计数器,带有相位反转功能的相位比较器,电荷泵,晶体振荡器,19 位的移位寄存器,18 位的锁存器和一个可编程的分频器( 二进制的 7 位吞计数器和二进制的 11 位可编程计数器 )。
mb1504 的工作电压低( 典型为 3v ),功耗低( 在 520mhz 时为 30mw )。
功能:
工作频率高:f(in max) =520mhz (v(in min) =0.20v(p-p) )
内置分频器
电源电压低:2.7v 到 5.5v ( 典型为3.0v )
串行输入的 18 位可编程除法器这样构成:
二进制的 7 位吞计数器( 分频比:0-127 )
二进制的 11 位可编程计数器( 分频比:16-2047 )
串行输入的 15 位可编程参考除法器包括:
二进制的 14 位可编程参考计数器( 分频比:8-16383 )
1 位开关计数器( sw ),设置分频比
2 种类型的相位检测器输出
集成电荷泵( 双极型 )
外部电荷泵输出
工作温度范围宽:t(a) = -40℃ - +85℃
塑料封装 dip-16p-m04
塑料封装 fpt-16p-m06
本器件内置保护电路,以防强静电或强电场的损坏。但是,还是推荐采取正常的预防措施,以防任何高于最大的额定的电压的电压施加于这个高阻抗的电路。
第2页
mb1504
mb1504h
mb1504l
pin assignment
note: permanent device damage may occur if the above absolute maximum ratings are exceeded. functional operation should be restricted to the conditions as detailed in the operational sections of this data sheet. exposure to absolute maximum rating conditions for extended periods may affect device reliability.
mb1504
mb1504h
mb1504l
引脚定义:
注意:在超过上述的绝对最大额定值时,器件可能会产生永久性损坏。请严格按照数据手册使用器件。( 仅限于在数据手册上面所罗列的可使用选项来使用器件。 )在接近最大额定值的情况下,长期使用器件可能会影响它的可靠性。
第5页
mb1504
mb1504h
mb1504l
functional descriptions
serial data input
serial data input is input using the data pin, clock pin and le pin. the 15-bit programmable reference divider and 18-bit programmable divider are controlled, respectively.
on rising edge of the clock, one bit of the data shifts into the internal shift registers.
when load enable (le) is high level (or open), data stored in the shift registers is transferred to the 15-bit latch or 18-bit latch depending upon the control bit
level.
control data "h" : data is transferred into the 15-bit latch.
control data "l" : data is transferred into the 18-bit latch.
the programmable reference divider consists of a 16-bit shift register, 15-bit latch and 14-bit reference counter. serial 16-bit data format is shown below.
sw: divide ratio of prescaler setting bit
sw= "h" : 32
sw= "l" : 64
s1 to s14 : divide ratio of programmable reference counter setting bits (8 to 16383)
c: control bit (control bit is set to high)
mb1504
mb1504h
mb1504l
功能描述
串行数据输入
串行数据是通过数据脚、时钟脚和 le 脚输入的。15 位的可编程参考除法器与 18 位的可编程除法器是单独受控的。
在时钟的上升沿,移一位数据进入内置的移位寄存器。
在使能负载 (le) 为高电平时(或开路时),储存在移位寄存器的数据要传输到 15 位锁存器或 18位锁存器,仅取决于控制数据。
控制数据为“h”:数据被传输到 15 位锁存器。
控制数据为“l”:数据被传输到 18 位锁存器。
可编程参考除法器
可编程的参考除法器这样构成:一个 16 位的移位寄存器,一个 15 位的锁存器与一个 14 位的参考计数器。串行 16 位数据的格式如下所示:
sw:分频器分频比的设置位
sw=“h”:32
sw=“l”:64
s1 到 s14:可编程参考计数器分频比的设置位(8-16383)
c:控制位(控制位被置高)
第6页
mb1504
mb1504h
mb1504l
the programmable divider consists of a 19-bit shift register, 18-bit latch, 7-bit swallow counter and 11-bit programmable counter.
serial 19-bit data format is shown below.
s8 to s18 : divide ratio of programmable counter setting bits (16 to 2047)
s1 to s7 : divide ratio of swallow counter setting bits (0 to 127)
c : control bit (control bit is set to low)
data is input from the msb.
mb1504
mb1504h
mb1504l
功能描述
可编程除法器
可编程除法器这样构成:19 位的移位寄存器,18 位的锁存器,7 位的吞计数器与 11 位的可编程计数器。
串行 19 位数据的格式如下所示:
s8-s18 : 可编程计数器分频比设置位(16-2047)。
s1-s7 : 吞计数器分频比设置位(0-127)。
c : 控制位(控制位被置低)
数据从 msb 位开始输入。
第7页
mb1504
mb1504h
mb1504l
serial data input timing
on the rising edge of the clock, one bit of the data shifts into the shift registers.
data in () is used for setting the divide ratio of the programmable reference divider.
phase characteristics
vco characteristics
the fc pin (pin 12) is provided to inverse the phase comparator characteristics. the characteristics of the internal charge pump output (do
), and phase detector outputs ( r, p) can be inversed depending upon the fc input data. outputs are shown below.
note: z=(high impedance)
depending upon vco characteristics, fc pin should be set accordingly:
when vco characteristics are like ①, fc should be set high or open circuit;
when vco characteristics are like ②, fc should be set low.
mb1504
mb1504h
mb1504l
串行数据输入的时序
在时钟的上升沿,移一位数据进入移位寄存器。
()中的数据被用来设置可编程参考除法器的分频比。
相位特征
fc 脚(第12脚)可以反相相位比较器的特征。内置电荷泵特征的输出(do脚)、相位检测器输出(r,p)可被反相,仅取决于 fc 的输入数据。输出如下所示:
注意:z = 高阻抗
vco 特征
取决于 vco 特征,fc 脚应相应地设置:pin should be set accordingly:
当 vco 特征像 ① 时,fc 脚应拉高或开路。
当 vco 特征像 ② 时,fc 脚应置低。
第8页
mb1504
mb1504h
mb1504l
recommended operating conditions
handling precautions
this device should be transported and stored in anti-static containers.
this is a static-sensitive device; take proper anti-esd precautions. ensure that personnel and equipment are properly grounded. cover workbenches with grounded conductive mats.
always turn the power supply off before inserting or removing the device from its socket.
protect leads with a conductive sheet when handling or transporting pc boards with devices.
mb1504
mb1504h
mb1504l
推荐使用的环境
操作注意事项
本器件在储运时应防静电。
本器件对静电敏感,应采取合适的防静电措施。确保人员和设备都可靠地接地。请在工作台铺设接地垫。
在把本器件插入或者拔出插座的时候,请关闭电源。
在操作或者传送带有本器件的pcb的时候,请使用导电片来保护它。
第9页
mb1504
mb1504h
mb1504l
electrical characteristics
(vcc = 2.7 to 5.5v, t(a) =-40 to +85℃)
note:
*1 vcc = 3.0v, f(in) = 520mhz, f(osc) = 12mhz crystal.
inputs are grounded except f(in), and outputs are open.
*2 input coupling capacitor 1000pf is connected.
mb1504
mb1504h
mb1504l
电气特征
注意:
*1 vcc = 3.0v, f(in) = 520mhz, f(osc) = 12mhz 的晶体。
除f(in)外,其余的输入都接地,输出开路。
*2 输入的偶和电容为 1000pf。
离线蓝梦祥
只看该作者 2楼 发表于: 2009-11-21
单片机at89c52控制+用锁相环频率合成芯片mb1504.现在频率在286mhz.什么改才到520mhz最高频率
