  • 4652阅读
  • 7回复
国内有人做IC751A的UX-14PX电脑控制接口吗? [复制链接]
离线BG7RMD
只看楼主 倒序阅读 0楼 发表于: 2009-03-28
larger image ux-14px plus serial interface / band memory module
serial interface / band memory module for the icom ic-751(a) and ic-r71a. now with extended command set!
if you have a icom ic-751 or ic-751a transceiver, or a ic-r71a receiver, and have tried to add the computer interface capability, you probably found that the accessory serial interface board is nearly impossible to find. piexx has corrected this problem with the new ux-14px plus serial interface / band memory kit. the ux-14px plus board is a new, plug compatible, module that fits in exactly the same location as the original ux-14. our kit includes the board, accessory mounting plate, hardware and cables. installation is a snap!
features:
computer serial interface
extended command set allow reading s-meter and keying the rig via the serial port
built in ci-v to rs-232 level converter
supports ci-v bus as well as rs-232 communications, simultaneously
programable band start memory
remembers the last place in band, and returns to this freq when you return to the band
6 level memory stack
includes cables, hardware and brackets
离线BA4WI
只看该作者 1楼 发表于: 2009-03-28
同问.不能与日志同步比较郁闷
离线BG6QCB
只看该作者 2楼 发表于: 2009-03-28
离线BG7RMD
只看该作者 3楼 发表于: 2009-03-28
除了了用ham radio deluxe的基本功能进行控制外,还能读取s表和纪录发报。希望国内diy高手能整一个。
离线dzyj
只看该作者 4楼 发表于: 2009-03-28
学习学习了.
在线zsh
只看该作者 5楼 发表于: 2009-03-28
没资料 没原板 没法仿 难度太大 成本太高
离线BG7RMD
只看该作者 6楼 发表于: 2012-03-23
多年前的愿望一直未实现!
离线BG8GGG
只看该作者 7楼 发表于: 2014-03-09
国内diy高手能整一个
