  • 2369阅读
  • 1回复
PIC 16F84A EchoLink界面 [复制链接]
离线BG1HOE
只看楼主 倒序阅读 0楼 发表于: 2009-03-22
http://www.foxdelta.com/products/foxecho.htm#fe
pic16f84a micro controller echolink* interface is designed to achieve some of the following points of interest to radio amateurs:
real rs232 signals
100% galvanic separation
plug-in tone & agc module (option)
cor (positive or negative logic selectable)
hardware dtmf decoding
muting (automatic) of receiver audio
adjustable receiver and transmitter audio levels
power status, dtmf, ptt and cor led's
uses a pic16f84a
din 5 front panel connector for easy interface to rig
transceiver connection has “ht” header for portables
no relays. uses hfe4053 analog switches.
12cm x 7cm, double sided pth board.
usable for other digital modes like psk31
a true homebrew project, you can build.
离线BG1HOE
只看该作者 1楼 发表于: 2009-03-22
附件继续
其余的附件,还有几个图片太大,感兴趣的去上面给的链接找吧
