  • 4642阅读
  • 15回复
160m天线!哪位老大再给点建议! [复制链接]
离线BA1IO
只看楼主 倒序阅读 0楼 发表于: 2009-03-12
按ba7io老师的方法用鱼竿弄了一个!效果不理想!
还有别的天线么?
看到了个这个不错!价格高,架设条件更为艰巨!
voyager dx
4 band multiband dx antenna
specifications
bands
160m 80m 40m 20m
bandwidth -- under 2:1
entire band on 80m 40m 20m;
160m over 90 khz
height -- 45 ft.
weight -- 30 lbs.
wind load-- 7 sq. ft., requires two sets of guy ropes
mount : ground. aluminum pivot and guy brackets supplied.
counterpoise : 3 at 57 ft. deployment pattern is very flexible.
ground area required : 4 guy anchor points 25 ft. from base mount
离线BA1IO
只看该作者 1楼 发表于: 2009-03-12
challenger dx
8 band multiband dx antenna
specifications
bands
80m 40m 20m 15m 12m 10m 6m 2m
entire band on 40m 20m 15m 12m 10m 6m 2m
80m over 130 khz; 10m over 1mhz
height -- 31.5 ft.
weight -- 18 lbs.
radiation efficiency : exceed conventional verticals by up to 600%
mount : ground or elevated. a ground mount is supplied.
counterpoise : 3 at 25 ft.
ground area required : fits in 10 ft. by 12 ft. area.
这个和下面一个跟r8类似!
离线BA1IO
只看该作者 2楼 发表于: 2009-03-12
eagle dx
6 band multiband dx antenna
specifications
bands
40m 20m 17m 15m 12m 10m
with supplied extender, this can be customized to your favorite part of the band
entire band on 40m 20m 17m 15m 12m
10m over 500 khz
height -- 21 ft.
weight -- 11 lbs.
mount : virtually anywhere. supplied pole mount fits your 1.25 in antenna mast
counterpoise : 3 rigid counterpoises 80" long
ground area required : none
power-- *300 watts on 40 meters - eagle only
离线BA1IO
只看该作者 3楼 发表于: 2009-03-12
titan dx
specifications
bands
10m 12m 15m 17m 20m 30m 40m and 100 khz on 80m
entire band on 40m 30m 20m 17m 15m 12m 10m
100khz on 80m
height -- 25 ft
weight -- 25 lbs
mount : all hardware supplied except the 1 1/4" o.d. steel mast
counterpoise : 4 rigid counterpoises 80" long each
离线BA1IO
只看该作者 4楼 发表于: 2009-03-12
离线BA5AS
只看该作者 5楼 发表于: 2009-03-12
催老师尝尝鲜,等着您的体验报告,呵呵!
离线BA1IO
只看该作者 6楼 发表于: 2009-03-12
催老师尝尝鲜,等着您的体验报告,呵呵!
550刀!忒贵了! :d
离线ahhui
只看该作者 7楼 发表于: 2009-03-12
上面的无非还是gp天线的形式,有电容顶,地网不太好,有匹配网络免调谐。既然要玩160m,不如就搞单波段的,振子越长越好,地网可以用软线拉,比商品天线那一丁点地网效果要好。难度在于机械部分。
离线BA1IO
只看该作者 8楼 发表于: 2009-03-12
谢谢哥哥!
离线BD4KA
只看该作者 9楼 发表于: 2009-03-12
来个10米加强鱼竿再想想招数!
离线BA1IO
只看该作者 10楼 发表于: 2009-03-12
来个10米加强鱼竿再想想招数!
继续努力!谢谢哥哥支持!
离线bg7ihm
只看该作者 11楼 发表于: 2009-03-13
用多波段方式加感来缩短主长度试下。如20,30,40,75,80,160,在同一主杆上,这样可能短些,但调试会麻烦,但你只要160米波别的波段不调也可
离线BD7IWW
只看该作者 12楼 发表于: 2009-03-13
其实只要低波段就行了。
40/75/80/160米四段,总净高度12米应该可接受了。
离线BA1IO
只看该作者 13楼 发表于: 2009-03-13
黎老师好!只要160m要能坚固80m最好!好搞么? :o
离线yk_zy
只看该作者 14楼 发表于: 2009-03-13
等待使用报告
离线BA5AS
只看该作者 15楼 发表于: 2009-03-13
可找一下广电的朋友,中波广播正在推广小型化发射天线,弄点资料来参考参考。
http://www.hellocq.net/forum/showthread-t-192871&highlight=bd5eld.谁了解锥形中波天线.html
