  • 3530阅读
  • 0回复
N1MM Logger又升级了9.22 [复制链接]
离线BG3PCH
只看楼主 倒序阅读 0楼 发表于: 2009-02-19
correct error message when there are no files in letters path.
update the default radio address for the ic-7600. (coded by k3ct)
cqwpx rtty bug fix(id #213): scoring 2 points for contacts with same country on 40m & 80m. should be 1 point for same country regardless of band (n3qw) (coded by k1mk)
bug fix (id #193): available window updating erratically (ve1dt) (coded by k1mk)
bug fix: (id #207): info window not updating (k4ab) (coded by k1mk)
bug fix (id #210): problem clicking on spots in available window when non-usa windows regional preferences set (dk8nt) (coded by k1mk)
9.22升级下载
9.0.0完全版下载
