平板模式
呼号认证怎么没通过?
呼号认证怎么没通过?
BG4QXW
UID:51287
719小时
发表于: 2009-02-13
看楼顶帖子里照着做了,把执照登记表什么的都拍了照传到了他们站点上,他们回复好象没通过,用手机拍的,不会模糊吧,自己看上去蛮清晰的!郁闷~~~~
hplc
UID:50547
0小时
发表于: 2009-02-14
那就用dc拍清晰些
BG4EWJ
UID:47862
3111小时
发表于: 2009-02-14
我当初也是第一次没通过,后来以电台为背景,又将三证拍好,用红色将三证中的呼号圈出来再发过去,很快就通过认证了。
BG4QXW
UID:51287
719小时
3楼
发表于: 2009-02-14
the authentication information you provided for bg4qxw has been received and verified. this callsign is now validated for echolink. enjoy the program! 73,echolink support
重新拍了照片,确实必须以电台为背景,拍了3证!
说明已经生效了.怎么打开ECHOLINK里没电台列表!郁闷!!
BG4QXW
UID:51287
719小时
4楼
发表于: 2009-02-14
windows xp service pack 2
local ip address: 169.254.135.22
firewall test results: pass
all tests passed. the internet connection appears to be correctly configured for echolink.
the test successfully connected to the echolink server on tcp port 5200. this means that your system's tcp configuration is correct for use with echolink
echolink软件界面的连接和断开连接按钮是灰色不可用状态,是不是还没通过验证啊!
BG4QXW
UID:51287
719小时
5楼
发表于: 2009-02-14
解决了~~~
jms523
UID:45168
474小时
6楼
发表于: 2009-02-21
总收不到电子邮件
