  • 8142阅读
  • 6回复
ICOM IC-92AD水货扩频 [复制链接]
离线djhanfei
只看楼主 倒序阅读 0楼 发表于: 2009-02-05
tx frequency coverage expansion for icom ic 92ad remove d4 as shown below:
procedure:
turn off the unit, remove the battery or battery case and then remove the six screws on the back side of the transceiver
carefully separate the front and back halves of the housing (there are a cable harness and a flat cable connecting the two halves together inside. the visible circuit board in the keyboard/display half is the logic unit)
unlock the locking flap at the flat cable connector on the logic unit and gently pull out the flat cable (after this step the two halves can be turned down side by side and the logic unit is conveniently accessible)
locate diode d4 on the logic unit just below liner codec ic 503 and remove it by means of smd unsoldering equipment or a suitable soldering iron (if no special smd unsoldering equipment is available a soldering iron with a sharp screwdriver tip can be used. do not use more than 25 w for the soldering iron and edge the tip sharp enough. heat up the two solder points on one side of the diode simultaneously by touching them with the flat soldering iron tip (don't touch for more than 2 or 3 seconds) while pulling up the diode with a sharp pair of tweezers. the surface of the diode will melt and doesn't look very beautiful after the "surgery" but it will no longer be of any use...
after removal of the diode check the logic unit carefully with a magnifying glass and remove any residuals with an appropriate sized and not to hard paint brush
reconnect the flat cable to the logic unit and rejoin the two housing halves paying attention to the correct fit of the oring seal that is responsible for the waterproofness of the transceiver
reinsert and tighten the six screws removed in step 1 gently.
switch on the transceiver and check the tx frequency coverage. if necessary do a full reset.
离线djhanfei
只看该作者 1楼 发表于: 2009-02-05
还有icom ic 92ad的原厂检修手册,有详细电路图和故障检修拆机方法
离线hrj
只看该作者 2楼 发表于: 2009-04-03
在哪里下载?
离线BA5EA
只看该作者 3楼 发表于: 2009-04-03
好几个网站都有了
离线清清点点
只看该作者 4楼 发表于: 2009-04-30
德克萨斯州的频率范围扩大国际博物馆理事会的ic 92ad删除d4类如下所示:
程序:
关闭股,删除电池或电池盒,然后删除六个螺丝背面的收发器
仔细分离的正面和背面半的住房(有电缆线束和扁平电缆连接在一起的两半内。明显的电路板中的键盘/显示一半是逻辑单元)
解锁锁定皮瓣在扁平电缆连接器的逻辑单元,轻轻拔出扁平电缆(此步骤后的两半可以拒绝并排和逻辑单元是方便)
找到二极管d4类的逻辑单元略低于班轮解码芯片503和删除它通过贴片unsoldering设备或一个合适的烙铁(如果没有特殊的表面贴装unsoldering设备提供了烙铁急剧螺丝刀提示都可以使用。不要使用超过25 w的烙铁和边缘的冰山尖不够。加热焊接点的两个一方的二极管同时通过触摸它们的平面焊接烙铁头(请勿触摸超过2或3秒) ,同时拉动了二极管急剧对镊子。表面的二极管将融化,不看后非常美丽的“手术” ,但将不再使用任何...
搬迁后的二极管检查逻辑单元进行了仔细放大镜和消除任何残留物的适当规模,而不是硬画笔
重新扁平电缆的逻辑单元,并加入这两个住房减半注意正确合适的oring印章负责防水的收发器
重新和加强六个螺丝取出轻轻在第1步。
开关的收发器和检查的tx频率范围。如果有必要做了充分复位。
离线osagem
只看该作者 5楼 发表于: 2009-06-12
扩频后收发如何?
离线BH4XBU
只看该作者 6楼 发表于: 2009-06-13
扩频后会怎样呢?
