  • 6286阅读
  • 15回复
YAESU FT-950升级!!! [复制链接]
离线牧鹰人
只看楼主 倒序阅读 0楼 发表于: 2009-01-25
2009年1月16日ft950也发布升级程序,经省级之后,增加部分功能显示!dsp系统程序也更新!按照八崇州公司报告!实现ftdx9000 (pep9000) edsp技术。。。。。。
文件链接:
1/16/09
rev. 1/18/09
pep950
this procedure is used to update main cpu v0105 and edsp v11.39 the flash
programming for the ft-950 transceivers.
we recommend installing the flash programming software on a pc computer with windows 2000,
xp or vista operating system; and use the serial cable rs-232c, db9f to db9f straight cable.
note: there are many usb adapters available; however some may not function with this
software. we recommend using the latest usb adapter driver software when available.
install the data file to pc
*before you install this software make sure that you delete all of the old update files ah031 and
edsp3k that are saved on your computer. do not keep any of the old files or folders on your
computer.
1. down load the ft-950 data file [ft-950_pep950_1-16-09.zip] from the following website:
http://www.yaesu.com/indexvs.cfm?cmd=displayproducts&prodcatid=102&encprodid=292e
02f4e4d00ec99887a63e7b8ecd1b&divisionid=65&isarchived=0
2. save the ft-950 data file [ft-950_pep950_1-16-09.zip] to the desktop on your computer.
3. unzip and extract the contents of [ft-950_pep950_1-16-09.zip] to the desktop of your
computer.
4. you will find the pep950_edsp3 and pep950_main folders on your desktop.
the programmer and software are now stored on your computer on the desktop. the files designated
in the last step above are ready to update your ft-950 transceiver.
the software updates will work with all versions (af, as, eu, na, oc, sa or all countries) of the ft-950.
ver. 0105 main cpu implements improvements:
• att, flt, ipo, rfil, agc, bar statuses are now displayed during transmit in split tx mode.
• the agc, dnr etc information is transferred a ⇒ b, when quick split is enabled from split off.
• when utune button is pressed, the "thru"&"μtune" indicator will light (without the utune kit).
also it is possible to connect and external bpf between the utune connectors.
• the speed/pitch values are now indicated on the vfd display.
• the cw carrier is moved slightly outside of the filter on rx mode.
• the response speed of the s meter is reduced, to provide an average reading.
• the ad conversion errors of the rotator direction indication are improved.
• a long press of the cont button in cw mode will activate the contour apf function.
• the characteristic of the nb level gain is changed.
• the fixed value of the agc hold time is set to 20 msec to improve the agc-related pulse noise.
• improved the acs operation.
• tx microphone equalizer default values are changed.
• the apf on/off can now be controlled by a cat command.
* the updated ft-950 operation manual will be posted on the website around mid february.
ver. 11.39 edsp implements improvements:
• implements the ftdx9000 (pep9000) edsp technology.
• improved the dnr and dnf.
• improved the agc.
• ssb speech processor audio augmented.
• includes apf function on cw mode.
附件: FT-950_PEP950 Software Procedure 1-16-09.pdf (0 K) 下载次数:175
附件: FT-950_PEP950_1-16-09.zip (0 K) 下载次数:172
离线牧鹰人
只看该作者 1楼 发表于: 2009-01-25
离线牧鹰人
只看该作者 2楼 发表于: 2009-01-25
对了!开机按着gen +50 +ent三个键能显示版本号!升级之后显示11.391.05
离线ba2ia
只看该作者 3楼 发表于: 2009-01-25
我一会试试。我用的就是950
只看该作者 4楼 发表于: 2009-01-25
升级好   。
离线ba2ia
只看该作者 5楼 发表于: 2009-01-26
吓死我了~考。升级还有步骤。没细看说明就生了。结果机器打不开了。吓死我了
现在已经搞定~
离线牧鹰人
只看该作者 6楼 发表于: 2009-01-26
现在已经搞定~
i服了you!!
离线老火腿
只看该作者 7楼 发表于: 2009-01-26
为什么ft-1000 mp 没有升级!?
离线BD4AAF
只看该作者 8楼 发表于: 2009-01-26
越是dsp控制多的机器越容易升级出新花头。
有些专业用途的机器按照不同应用的侧重还有不同的固件可以选择
离线牧鹰人
只看该作者 9楼 发表于: 2009-01-26
这是更新后菜单操作部分说明,还有全版升级后的说明书,维修手册因为太大无法上传需要的朋友可以邮箱联系!!!
附件: FT-950(PEP功能).pdf (0 K) 下载次数:175
离线ba2ia
只看该作者 10楼 发表于: 2009-01-26
[quote=牧鹰人]这是更新后菜单操作部分说明,还有全版升级后的说明书,维修手册因为太大无法上传需要的朋友可以邮箱联系!!![/quote]
你也用950?"
离线牧鹰人
只看该作者 11楼 发表于: 2009-01-27
你也用950?"
是的 !ft950
离线BG8GAM
只看该作者 12楼 发表于: 2009-01-27
谢谢 牧鹰人 我的邮箱 ccqt@tom.com
离线husy
只看该作者 13楼 发表于: 2009-01-29
这些升级都是让ic-7600逼出来的,就在这些升级放出来的2-3日内,在日本可以买到ic-7600了。
离线牧鹰人
只看该作者 14楼 发表于: 2009-01-30
离线bg8nng
只看该作者 15楼 发表于: 2017-02-10
回 牧鹰人 的帖子
牧鹰人:这是更新后菜单操作部分说明,还有全版升级后的说明书,维修手册因为太大无法上传需要的朋友可以邮箱联系!!! (2009-01-26 14:29)
1762573@qq.com   麻烦传个手册,谢谢~~~~
