  • 12556阅读
  • 34回复
受了刺激找到的编程器--吐血推荐 [复制链接]
离线桃子病了
只看楼主 倒序阅读 0楼 发表于: 2002-12-20
没想到那个编程器还那么不管用,晚上找了一个晚上,到国外网上下了一个,大家看看吧
1. 直接编程芯片:
eprom 27c64, 27c128, 27c256, 27c512, 27c010, 27c020, 27c040,27c1001
m27c1001, m27c2001, m27c4001
27c080 (a19) ,m27c801
2716(vpp25v),2732, (adapter dip24)
2764, 27128, 27256, 27512, 27010,
vpp12.5v (21vpp modify circuit)
eeprom
28c65,28c64, 28c128, 28c256,28c512, 28c010, 28c020, 28c040
m28c16a/17a (dip28)
flash memory
28f64, 28f128, 28f256, 28f512,28f010(mx28f1000), 28f020
i28f001bx
command seq. 555/aa,2aa/55,555/90
29f64, 29f128, 29f256, 29f512,29f010, 29f020, 29f040
serial (i2c) eeprom
24cxx
24c02,24c04,24c08,24c16,
--- page write ----
24c32,24c64,24c128,24c256,24c512
microwire eeprom
93cxx
<------ data 8bit -----> (pin 6 ->org. [schematic connect to gnd])
93c06, 93c46, 93lc46, 93c56, 93c57,
93c66, 93c76, 93c86 (8bit)
<------data 16bit------> (pin 6 ->nc [no connect])
93c06a ,93c46x,93c56,93c66,93c76,93c86 (ns)
microchip pic
16c84, 16f84, 16f84a ,16f627/16f628
12c508, 12c509, 12c508a, 12c509a,
16c620, 16c621, 16c622
---icsp connector----
16f870 -> 16f877
atmel flash memory
(sector programming)
(software data protection)
at29c256, at29c512,at29c010a, at29c020, at29c040,at29c040a
w29ee512,w29ee011, w29ee012, w29c020(128),w29c040
ph29ee010(w29ee011)
asd ae29f1008 (at29c010), ae29f2008 (at29c020)
atmel flash memory
at49fxxx (subset 29fxxx)
(byte-by-byte programming)
command seq. 5555/aa, 2aaa/55, 5555/a0
at49f512, at49f010,at49f020,at49f040, m29f002x
sst39sf010,sst39f020,sst39sf040
at49f001,at49f002
command seq. 555/aa, 2aa/55, 555/a0
am29f512,am29f010, am29f020, am29f040,
29f002,29f002t,pm29f002t
serial peripheral interface (spi)
eeprom mode0 (0,0)
at25xxx, w95xxx
[atmel] at25010,020, 040 (a8-a0)
at25080, 160, 320, 640, 128, 256 (a15-a0)
[st] w95010....256, microchip 25x010 - 25x640
--- byte programming
25010,25020,25040
--- page programming
25c080,25c160,25c320,25c640,25c128,25c256,25c512
at25hp256,at25hp512
at25hp1024 (24bit address)
atmel eeprom (page prog.)
at28c256, at28c010, at28c040
nonvaltile sram (ds12xx)
ds1220,ds1225y, ds1230y/ab, ds1245y/ab, ds1249y/ab
static ram (test ram)
6116, 6264, 62256, 62512, 628128
eprom winbond,sst
electrical erase chip
w27e512, w27e010, w27c010
sst27sf256, sst27sf512, sst27sf010, sst27sf020
flash memory sst,sanyo
sst28sf040a ,le28f4001
2. 使用适配器可编程的芯片:
atmel at89cxx (mcs-51)
adapter 32pin to mcs-51
at89c51,52,55, at89lv51,52,55
at89s8252 (8k+2k), at89s53, at89ls8252,at89ls53
at89c1051,at89c2051,at89c4051 (20pin)
at89c51rc (32kb), at89c55wd
sst89c54/58, si89c52
i87c51, i87c51fa, i87c51fb
i8xc51,i8xc52,i8xc54,i8xc58 (twp = 100us*25 pulse)
mcs-48,mcs-41
adapter 32pin to mcs-48/41
rom (read/verify)
p8048ah, p8049ah,p8050ah, p8042ah vea = 12v
p8041, p8042
otp (read/verify/progam)
p8748,p8749h,p8742h vea = 18v
eprom (read/verify/progam)
d8748,d8749,d8742,d8741, d8742 vea = 18v
flash memory 8/16bit
adapter (tsop48)
am29f400,am29f800,29f160,29f320 (read,write byte mode)
hy29f200, hy29f400, hy29f800
flash memory 8/16bit (vpp12v) (software data protection)
adapter (tsop48)
i28f200,i28f400,i28f800 (tsop48)
28f001(dip32 or plcc32)
atmel risc mcu avr at90sxxx
(parallel programming)
(read,write,erase,verify,checkempty) [flash memory]
at90s1200,at90s2313
90s2333, 90s4433, 90s4414, 90s8515, 90s4434, 90s8535-
reference at90s2313
eprom 16bit (dip40) (1-4mbit)
adapter eprom 16bit
eprom only
27c1024 (27c210), 27c2048 (27c2002), 27c4096 (27c4002),
eprom 16bit (dip42) (4-32mbit)
adapter eprom dip42
eprom only
m27c400(dip40), 27c800, 27c160, 27c322
schematic by toomas toots
(read,program byte mode
by use resister pull up data bus (0xff), a0 select low or high byte)
adapter (tsop48lv)
29lv400,29lv800,29lv160,29lv320 (read,write byte mode)
pcb图
附件: willem_pcb3b.zip (0 K) 下载次数:1171
离线桃子病了
只看该作者 1楼 发表于: 2002-12-20
sch图
附件: willem_sch3bx.zip (0 K) 下载次数:847
离线桃子病了
只看该作者 2楼 发表于: 2002-12-20
编程程序
附件: epr097c.zip (0 K) 下载次数:946
离线BD7LM
只看该作者 4楼 发表于: 2002-12-20
好,但这个东西在国内已经有很多人做出来卖了。
离线桃子病了
只看该作者 5楼 发表于: 2002-12-20
最初由 bg7lm 发布
哦,什么价钱?
离线BD7LM
只看该作者 6楼 发表于: 2002-12-21
你去这里看看http://www.kitopen.net/
离线许涛
只看该作者 7楼 发表于: 2002-12-24
科海KH01多功能编程器
一、产品简介
  科海kh01多功能编程器支持绝大多数的eprom、eeprom、flash和串行eeprom系列芯片,并且还直接支持一些常用的pic单片机芯片。此编程器既适合于电子和电脑爱好者使用,也适合于电子电脑维修人员和单片机开发人员使用,具有很高的性价比。
  本编程器配套有各种适配器,比如:atmel适配器和pic适配器。这样无需购买新的编程器设备,只需根据需要购买相应的适配器,即可对atmel公司的51全系列单片机,avr系列单片机和microchip公司的pic系列单片机进行编程。
  对于电脑爱好者,则可用此编程器对电脑的各种板卡的bios芯片进行编程。比如修复被病毒破坏的主板bios芯片,对主板、显卡等的bios芯片进行升级以提升计算机性能等等。
  与多功能编程器配套的软件采用 windows下的图形界面,使用鼠标进行操作,全中文操作环境,使得对芯片的各种操作变得十分简单,无论是电子还是电脑爱好者都可轻松掌握。并且程序将不断升级,将支持更多的芯片。
1. 产品照片
2. 产品性能
  本编程器必须与ibm pc机或其他兼容机相连接,通过配套软件对各种芯片进行编程。
3. 设备构成
  本编程器包括:科海kh01多功能编程器主机、并口连接线、外置电源、配套软件光盘(光盘内容:中文版编程器软件,电子版51系列、avr系列、pic系列单片机图书及电子技术图书,protel99se,protel dxp破解版,pads powerpcb4.0,keilc51v6.23完全版等)
  配套适配器(选件):atmel89适配器、plcc32适配器、atmel plcc44适配器、fwh/lpc适配器、pic适配器等,可根据需要选购。
4. 工作环境*
ibm 486以上计算机或兼容机   * 5m硬盘空间* windows 9x、windows nt、windows 2000操作系统
copyright &copy; 2002-2003, http://sdmcu.126.com/
all rights reserved.
山东.淄博.科海电子 e-mail: sdmcu51@163.com
服务热线:0533-8637497 0533-2887297
传真:0533-2887297
离线桃子病了
只看该作者 8楼 发表于: 2002-12-25
Re: 科海KH01多功能编程器
科海kh01多功能编程器
就是我发的这种编程器,但是价格太高了,自制根本要不了那么多钱
离线BD3RJ
只看该作者 9楼 发表于: 2002-12-25
本来我也想做,可是有几个ic本地买不到,另外那个插座也买不到。小地方就是麻烦呀!
离线桃子病了
只看该作者 10楼 发表于: 2002-12-26
最初由 bg3rj 发布
可以请大城市的ham帮个忙啊,比如是南京的,广州的等
离线BD3RJ
只看该作者 11楼 发表于: 2002-12-27
买1 2个不合算。
只看该作者 12楼 发表于: 2003-01-24
哪里可以买到这个编程器的pcb板?我想diy一个试一下。或者大家组织一下,看有多少人想要这个编程器的pcb电路板,如果需要的人多,干脆找个工厂订做一批pcb板给大家diy一下不是很好吗?我相信有很多人都对这个东西感兴趣的。看一下大家的意见怎么样?集成电路、晶体管、排式电阻、独石电容、跳线组、ic插座、dc电源插座、25针接口、0插拨zip插座都可以通过广州赛格电子城里的电子公司解决,里面有几间公司好象还有邮购业务的。我相信成本不会超过50元。现在就是pcb电路板解决不了。
离线bg5gaw
只看该作者 13楼 发表于: 2003-01-24
我这里元件都能买到,但是电路板是个大问题,我认为大家组织起来到工厂做一批是个好办法
离线bg5gaw
只看该作者 14楼 发表于: 2003-01-25
请教各位
请教各位,编程器的pcb图下载解压后怎么也打不开,请问这是怎么回事?请高人指点,非常感谢!
离线桃子病了
只看该作者 15楼 发表于: 2003-01-27
电路板做要30块钱版费,然后是每平方厘米3毛钱,这是我最近在南京华龙问的价格,你可以把电路图用磁盘带给制版的店家,由他帮你做好
离线liufei918
只看该作者 16楼 发表于: 2003-02-13
向许涛团购
许涛你看如何!
离线bg4ifu
只看该作者 17楼 发表于: 2003-02-14
没有那么贵吧,我记得好像是1毛1一个平方厘米
如果是双面板的话,单面板得更便宜。也就几分钱的事情。
现在做电路板的厂家很多,有些厂家为了保证货源,连刻板费也省了,找他们就可以了,如果板子上的线不是很细的话,一般可以保证不出问题。
离线许涛
只看该作者 18楼 发表于: 2003-02-15
我的电话是0533-8637497,网址sdmcu.126.com
请看网址,上面有详细介绍,做的线路板包括过孔,字符,全部数控制版,非手工做!
离线桃子病了
只看该作者 19楼 发表于: 2003-02-15
今天在华龙问了一下,有一个店铺制版费50元,然后每块板在8,9块钱
