  • 2586阅读
  • 7回复
高手帮忙看看这是个什么元件? [复制链接]
只看楼主 倒序阅读 0楼 发表于: 2008-12-15
近日在一个手持设备里看到这个元件,不知道是什么元件,运放?场效应管?依据上面的字符在网上也没有搜到相关资料,还请高手指点迷津,先在这里谢谢了
离线BA4II
只看该作者 1楼 发表于: 2008-12-15
看这里:
http://www.minicircuits.com/pages/s-params/vacc-22+_view.pdf
工作在1.5ghz--2.3ghz
属于低电压,高增益器件,应该用于手机1900mhz的发射!
只看该作者 2楼 发表于: 2008-12-15
谢谢老乡,我看看
离线BA4II
只看该作者 3楼 发表于: 2008-12-15
谢谢老乡,我看看
不用客气!!
离线8200
只看该作者 4楼 发表于: 2008-12-16
会不会是5端稳压ic
只看该作者 5楼 发表于: 2008-12-16
[quote=8200]会不会是5端稳压ic
我看很有可能是您说的这种5端稳压ic,可那上面怎么标注“vacc”?是型号还是符号?另外您说的34bat6这种5端稳压ic有没有详细资料呀?谢谢!!!
离线bg8am
只看该作者 6楼 发表于: 2008-12-16
http://focus.ti.com/lit/ds/symlink/tlv2211.pdf
single lincmos(tm) rail-to-rail upower operational amplifier
上面标记就是vacc
the tlv2211 is a single low-voltage operational
amplifier available in the sot-23 package. it
consumes only 11 μa (typ) of supply current and
is ideal for battery-power applications. looking at
figure 1, the tlv2211 has a 3-v noise level of
22 nv/√hz at 1khz; 5 times lower than competitive
sot-23 micropower solutions. the device
exhibits rail-to-rail output performance for increased
dynamic range in single- or split-supply
applications. the tlv2211 is fully characterized
at 3 v and 5 v and is optimized for low-voltage
applications.
the tlv2211, exhibiting high input impedance
and low noise, is excellent for small-signal
conditioning for high-impedance sources, such as
piezoelectric transducers. because of the micropower
dissipation levels combined with 3-v
operation, these devices work well in hand-held
monitoring and remote-sensing applications. in
addition, the rail-to-rail output feature with single
or split supplies makes this family a great choice
when interfacing with analog-to-digital converters
(adcs).
只看该作者 7楼 发表于: 2008-12-16
********啊,我终于找到了,是的,是的,就是bg8am提供的tlv2211,真的感谢各位无私的朋友
