  • 5680阅读
  • 8回复
80米段超小框型天线 [复制链接]
离线BG4CTL
只看楼主 倒序阅读 0楼 发表于: 2008-12-11
见过仅有1.20米见方且容易制作成功的80米段天线吗?
瑞典sm0vpo设计制作的这个天线,真是小得有趣,惊叹之余,赶紧上具体尺寸图。
那个25pf的耐高压电容应可用几块环氧敷铜板堆叠后自制,据说加用410pf电容后还能在160米上工作。该天线制作不难,所用材料也很少,供同好们参考。
附上原文:
80 meter frame antenna
by harry lythall (sm0vpo)
this project was developed as a result of experiments to become qrv on 80 meters, again, using the little balcony of mine. i have now built several of these antennas with equal success every time. the frame antenna may not be the most efficient but it can get you qrv on 80 and is ideal for boats and holidays.
the construction of the antenna is shown in the picture and is a five-turn loop of one cable from 5 ampere mains cable. the cable must have a multi-stranded conductor. the antenna uses over 20 meters of the cable, so i stripped down 7 meters of 3-core cable and soldered the ends together. construction is otherwise quite straight forward if you follow the above drawing. note that all cable lengths shown are approximate.
the two boom poles - i have used both cane and a plastic clad tin (metallic) pipes, of the sort that are sold in garden shops. both worked very well in spite of the difference in materials. if you do use metal booms then insert some form of insulation in the holes before you pass wire through them. i used plastic drinking straws from macdonald’s. this will prevent the metal from digging into the cable insulation, as well as improving the insulation.
with the dimensions shown each loop will be separated by 4cm. the natural capacity between the turns will tune the antenna to (about) 4.15 mhz, just above the 80-meter band. one of those jackson 804 / 805 vhf tuning capacitors with about 25pf will tune the antenna down to 3.45 - 3.90 mhz. the tuning capacitor must be one with a couple of millimeters between the plates. the antenna has a very high q so the voltage across the capacitor will be very high, even with small qrp powers.
160 meters
a capacitor of 410 pf placed across the tuning capacitor move the antenna frequency down to 1.9 mhz. this capacitor must be a high voltage type. this antenna could get you qrv on 160-meter although efficiency is likely to suffer, but ok for local nets and the like.
trimming
if the 80-meter antenna does not naturally fall on 4.15 mhz, or the tuning capacitor is not centered on the band then some frequency adjustment can be made to the final antenna.
if the frequency is a little low and you need to increase it then some of the self-capacity must be removed. thread a bit of plastic tube between the wires of one side; in, out, in, out, in. (see note *1 in the picture)
repeat on more than one side of the frame antenna if a larger frequency increase is required. if the increase is still not enough then insert two tubes in each side and slide them apart to get a large increase.
if the frequency is too high and you need to decrease it then some more capacity must be added. connect a high voltage capacitor across the variable tuning capacitor. a short length of coaxial cable is ideal. cut the coaxial capacitor shorter to reduce to the required capacity (increase the frequency).
(if you use this antenna for transmitting, do not be tempted to make a 'gimmick' capacitor with two wires twisted together; it will burn, even with a couple of watts of rf. this means that you have added more losses.)
离线BH3NEK
只看该作者 1楼 发表于: 2008-12-11
离线BG9ADQ
只看该作者 2楼 发表于: 2008-12-12
做过。效率低。没10来米线加天调好。巧的话,刚好谐振,25pf电容不必存在。
离线BG4CTL
只看该作者 3楼 发表于: 2008-12-15
作为野外用,此天线还是有其使用的价值.
离线BH3NEK
只看该作者 4楼 发表于: 2008-12-16
如何电容不用那么原来接电容的两端是断路还是短接?
离线bg1wqn
只看该作者 5楼 发表于: 2008-12-16
能承受发射功率有多大?
离线BG4CTL
只看该作者 6楼 发表于: 2008-12-16
电容不可缺少
25pf的电容是必须的。靠线间分布电容无法调到谐振波段范围,况且发射时大框内将感应出高压,两根引出线不能缠绕,否则容易出现打火击穿。该天线发明者在上文的最后也给出了提醒。
离线浦东星
只看该作者 7楼 发表于: 2009-10-04
放大2—3倍。有空试。
离线swift
只看该作者 8楼 发表于: 2009-10-04
根据软件的模拟,该天线发射时大概为-20db,没有发射价值.
