  • 4328阅读
  • 5回复
求教用KG105搭建过中继的朋友帮帮我 [复制链接]
离线apufo
只看楼主 倒序阅读 0楼 发表于: 2008-11-27
本人属于菜鸟级的,知识少但是就是喜欢琢磨,现在想用kg105搭建一套中继,可是遇到了问题,还想请大家帮帮我。
这块控制板是我参照bd4itm的帖子:http://www.hellocq.net/forum/showthread-t-100267.二台对讲机改中继控制图.html
现在用这块板子我已经可以把接收的信号传给发射机,让发射机工作,但是就是无法把语音加载上,去掉22uf的电容也是一样的问题?
下面的是我接收机的图,请大家帮我看看这几个点的位置是否正确?配合我的控制板帮我分析为什么没有语音信号。
下面的是我发射机的图,请大家帮我看看这几个点的位置是否正确?配合我的控制板帮我分析为什么没有语音信号。
现在的问题就是我上面说的,我已经可以实现信号转发,但是就是无法加载语音信号?然后还想问一句加载延时需要在哪里上电容?需要多大的电容?
最后谢谢为我解答的朋友们!
离线BG7YN
只看该作者 1楼 发表于: 2008-11-28
在本坛子,找bd8uk发的,进行连接,肯定可行!!!!呵呵,
离线bd5ik
只看该作者 2楼 发表于: 2008-11-28
没搭过kg105但搭过其它机器.给个电路给你参考一下.中继只要找到一个控制点(即接收机收到信号时有电平高低变化的点).取来控制中继发射.发射的同进把接收机收到的话音信号去加重后得到分辨率高的语音信号送入发射机调制部分就可以了.要求高点可以加上发射限时功能防止中断受到干扰时长时间发射,以保护发射机.
离线baoerji9527
只看该作者 3楼 发表于: 2008-12-07
How to buy UGG sheepskin boots
how to buy ugg sheepskin boots?
everyone who wear the ugg sheepskin boots will get many benefits. ugg boots are made to be worn barefoot as they will form to your feet and provide natural arch support. when buying a pair of sheepskin boots or ugg boots (premier brand in luxury and comfort footwear), there are many things to look for:
first of all, you must make sure your sheepskin boots are actually made out of 100% authentic sheep skin. some manufacturers use cheap substitutes such as gluing synthetic wool on to cow hide. these imitation sheepskin boots come at a cheaper price tag, but unfortunately the less expensive alternatives may cause skin irritations, encourage bacteria growth, wear down, tear quickly and noticeably less comfortable. http://www.shoppingugg.com
when buying sheepskin boots, make sure they are manufactured from quality australian merino wool. australian merino sheepskin boots are considered the best material for making sheepskin boots and it also ensures that you will be able to use them for many years. authentic wool also allows your feet to breathe and help reduce feet sweating. merino sheep skin is by and large thicker and much more durable than other kinds of sheep skin, which helps your boots keep their shape as well as resist wear and tear. by purchasing sheepskin boots made from merino wool and sheep skin, you will be guaranteed that not only will they be the most comfortable pair of sheepskin boots you'll ever own, but they will also last for a long time to come.
i have included some links if you would like to learn more about sheepskin boots or youwant to know where can buy some ugg boots - australia markets the premier brand in luxury and comfort. their many products fit into your every day life offering you products that are fashionable, comfortable, and attainable.
ugg boots have been made and worn in australia/china for over 50 years and "ugg" is not associated with any brand or style of sheepskin boot. so if your looking for real australian made ugg boots look no further than shopping ugg see our full range of cardy ugg boots , classic short ugg boots , classic tall ugg boots , metallic ugg boots , sundance ugg boots and now even new mini ugg boots then you can find all the love from australia right here.
离线BG4IYR
只看该作者 4楼 发表于: 2008-12-08
离线zzj0108
只看该作者 5楼 发表于: 2008-12-15
