  • 4664阅读
  • 8回复
比较齐全的Q简语列表 [复制链接]
离线jnwysh
只看楼主 倒序阅读 0楼 发表于: 2008-11-17
通用
qra ~ quz : for all service
qra the name of my station is...
qrb the approximate distance between our station is...nautical miles
 (or...kilometres)
qrc the accounts for charges of my station are settled by the private
 enterprise...(or state administration)
qrd i am bound for...form...
qre my estimated time of arrival at...(or over...)(place)is...hours
qrf i am returning to...(place)
qrg your exact frequency (or that of...)is...khz(or...mhz)
qrh your frequency varies
qri the tone of your transmission is 1.good
 2.variable
 3.bad
qrj i have...radiotelephone calls to book
qrk the intelligibility of your signals(or those of...)is 1.bad
 2.poor
 3.fair
 4.good
 5.excellent
qrl i am busy(or i am busy with...). please do not interfere
qrm i am being interfered with (1. nil
 2.slightly
 3.moderately
 4.severely
 5.extremely)
qro increase transmitter power.
qrp decrease transmitter power
qrq send faster(...words per minute)
qrr i am ready for automatic operation. send at...words per minute
qrs send more slowly (...words per minute)
qrt stop sending
qru i have nothing for you
qrv i am ready
qrw please inform...that i am calling him on...khz(or mhz)
qrx i will call you again at...hours(on...khz(or...mhz))
qsa the strength of your signal (or those of...)is
 1.scarcely perceptible
 2.weak
 3.fairly good
 4.good
 5.very good
qsb your signals are fading
qsc i am a cargo vessel
qsd your keying is defective
qse the estimated drift of the survival craft is...(figures and units)
qsf i have effected rescue and am proceeding to...base(with...persons
 injured requiring ambulance)
qsg send...telegrams at a time
qsh i am able to home on my d/f equipment (on station...)
qsi i have been unable to break in on your transmission
qsj the charge to be collected to...including my internal charge
 is...francs
qsk i can hear you between my signals; break in on my transmission
qsl i am acknowledging receipt
qsm repeat the last telegram which you sent me(or telegram(s)
 number(s)...)
qso i can communicate with...direct(or by relay through...)
qsp i will relay to...free of charge
qsq i have a doctor on board (or...(name of person)is on board)
qsr repeat your call on the calling frequency; did not hear you (or
 have interference)
qss i will use the working frequency...khz(normally only the last
 three figures of the frequency need be given)
qsu send or reply on this frequency (or on...khz(or...mhz)(with
 emissions of class...)
qsv send a series of vs on this frequency (or ...khz(or...mhz)
qsw i am going to send on this frequency (or on...khz(or...mhz)(with
qsx i am listening to...(call sign(s) on...khz(or...mhz))
qsy change to transmission on another frequency(or on...khz(or ...mhz))
qsz send each word or group twice (or ...times)
qta cancel telegram number...
qtb i do not agree with your counting of words; i will repeat the
 first letter or digit of each word or group
qte your true bearing from me is...degrees at...hours
qtf the position of your station according to the bearings taken by
 the d/f stations which i control was...latitude,...longitude(or
 other indication of position),class...at...hours
qtg i am going to send two dashes of ten seconds each followed by my
 call sign (repeated... times)(on...khz(or mhz))
qth my position is...latitude,...kilometres per hour or...statue
 miles per hour)
qti my ture track is...degrees
qtj my speed is...knots(or...kilometres per hour or...statute miles
 per hour)
qtk the speed of my aircraft in relation to the surface of the earth
 is...knots(or...kilometres per hour or...statue miles per hour)
qtl my true heading is...degrees
qtm my magnetic heading is...degrees
qtn i departed from...(place)at...hours
qto i have left dock (or port) or i am airborne
qtp i am going to enter dock (or part) or i am going to alight (or land)
qtq i am going to communicate with your station by means of the
 international code of signals
qtr the correct time is...hours
qts i will send my call sign for tuning purposes or so that my
 frequency may be measured now (or at...hour)on...khz(or...mhz)
qtt the identification signal which follows is superimposed to
 another transmission
qtu my station is open from...to,,,hours
qtv stand guard for me on the frequency of... khz (or... mhz) (from
 ... to... hours)
qtw survivors are in...condition and urgently need...
qtx i will keep my station open for further communication with you
 until further notice (or until...hours)
qty i am proceeding to the position of incident ans expect to arrive
 at...hours(on...(date))
qtz i am continuing the search for...(aircraft, ship, survival craft,
 survivors or wreckage)
qua here is new of...(call sign)
qub here is the information requested...
quc the number (or other indication) of the last message i received
 from you (or from...(call sign))is...
qud i have received the urgency signal sent by...(call sign of mobile
 station) at...hours
que i can use telephony in...(language)on...khz(or...mhz)
quf i have received the distress signal sent by...(call sign of
 mobile station)at...hours
qug i am froced to alight(or land)immediately
quh the present barometric pressure at sea level is...(units)
qui my navigation lights are working
quj the true track to reach me (or...)is...degrees at...hours
quk (the sea at...(place or coordinates)is...
qul the swell at ...(place or coordinates) is...
qum (normal working may be resumed
qun my position, true course and speed are...
quo please search for
 1.aircraft
 2.ship
 3.survival craft in the vicinity of...latitude,...longitude
 (or according to any other indication)
qup my position is indicated by 1.searchlight
 2.black somke trail
 3.pyrotechnic lights
quq please train your searchlight on a cloud, occulting-if possible
 and, if my aircraft is seen or heard, deflect the beam up wind
 and on the water (or land) to facilitate my landing
qur survivors 1.are in possession of survival equipment dropped by...
 2.hve been picked up by rescue vessel
 3.have been reached by ground rescue party
qus have sighted 1.survivors in water
 2.survivors on rafts
 3.wreckage in position...latitude,...longitude
qut position of incident is marked by 1.flame or smoke float
 2.sea marker
 3.sea marker dyce
 4....(specify other marking)
quu home ship or aircraft...(call sign)
 1.to your position by transmitting your call sign and long
 dashes on...khz(or...mhz)
 2.by transmitting on...khz(or...mhz) true track to reach you
quw i am in the ...(designation)search area
qux i have the following nevigational warning(s) or gale warning(s)
 in force:...
quy position of survival craft was marked at...hours by
 2.sea marker
 3.sea marker dyce
quz distress phase still in force; restricted working may be resumed
离线jnwysh
只看该作者 1楼 发表于: 2008-11-17
航空用
qab you are cleared (or...is cleared)by ... from... (place) to...
 (place) at flight level/altitude...
qaf i am(was)at(over)...(place)(at...hours)at flight level/altitude...
qag iam arranging my flight in order to arrive over...(place) at
 ...hours
qah i am at flight level/altitude...
qai the essential traffic respecting your aircraft is...
qak there is risk of collision
qal i am going to land at....(place)
qam meteorological observation made at...(place)at...hours is ...
 (direction)... (speed figures and units)
qao the wind direction and speed at...(position or zone/s)at flight
 level/altitude...is... (vertical distance in figures and units)
 ... degrees true... (speed in figures and units)
qap listen for me(or for...)on...khz(...mhz)
qaq you are 1.near
 2.flying within area...(identification of area)
qar you may stop listening on the watch frequency for...minutes
qau i am about to jettison fuel
qaw i am about to carry out overshoot procedure
qay i passes...(place)bearing...degrees relative to my heading at...hours
qaz i am experiencing communication difficulties through flying in a
 storm
qba the horizontal visibility at...(place)at...hours is...(distance
 figures and units)
qbb the amount, type and height above official aerodrome elevation of
 the base of the cloud at...(place) at... hours is... eighths
 (...type) at... (figures and units)height above official
 aerodrome elevation
qbc the meteorological conditions as observed from my aircraft at...
 (position or zone)at... hours at...(figures and units) height
 above... (datum) are...
qbd my fuel endurance is...(hours and/or minutes)
qbe i am about to wind in my aerial
qbf i am flying in cloud at flight level/altitude...(and i am
 ascending (descenging) to flight level/altitude...)
qbg i am flying above cloud and at flight level/altitude...
qbh i am flying below cloud and at flight level/altitude...
qbi flight under ifr is compulsory at...(place)(or from...to...(place))
qbj at...hours at...(position or zone)the top of the cloud is amount
 ... eighths (...type) at... (figures and units) height above...
 (datum)
qbk i am flying with no cloud in my vicinity and at flight
 level/altitude...
qbm here is the message sent by...at...hours
qbn i am flying in and out of clound and at flight level/altitude...
qbo flying under vfr is permissible at...(place)which would be
 suitable for your landing
qbp i am flying in and out of clound and at flight level/altitude...
qbs ascend(or descend)to...(figures and units)height above (datum)
 before encountering instrument meteorological conditions or if
 visibility falls below... (figures and units of distance) and
 advise
qbt the runway visual range at...(place)at...hours is...(distance
 figures and units)
qbv i have reached flight level/altitude...(or...(area or place))
qbx i have left flight level/altitude...(or...(area or place))
qbz i am reporting my flying conditions in relation to clouds
qca i am changing my flight level/altitude from...to...
qcb delay is being caused by 1.your transmitting out of turn
 2.your slowness in answering
 3.lack of your reply to my...
qce expect approach clearance at...hours
qcf delay indefinite.expect approach clearance not later than...hours
qch cleared to taxi to...(place)
qci i am making a 360-degree turn immediately(turning to the...)
qcs my reception on...frequency has broken down
qcx my full call sign is...
qcy i am working on traling aerial
qdb i have sent message...to...
qdf my d-value at...(position)at...(figures and units)height above
 the 1013.2 hectopascal datum is...(d-value figures and units)...
 (specify plus or minus)
qdl i intend to ask you fir a series of bearings
qdm the magnetic heading for you to steer to reach me(or...)will no
 wind was...degrees(at ...hours)
qdp i will accept control(or responsibility)of(for)...now(or at...hours)
qdr your magnetic bearing from me(or from...)was...degrees(at...hours)
qdt i am flying in visual meteorological conditions
qdu cancelling my ifr flight
qdv i am flying in a flight visibility of less than...(figures and
 units) at flight level/altitude...
qea you may cross the runway ahead of you
qeb tazi as follows at the intersection...(turn left left turn right rite)
qec you may make a 180-degree turn and return down the runway
qed follow the pilot vehicle
qef i have left the parking area
qeh i have moved to the holding position for runway number...
qej i am assuming take-off position for runway number...and am holding
qek i am ready for immediate take-off
qel you are cleared to take-off(turn as follows after take-off...)
qem the condition of the landing surface at...(place)is...
qen hold your position
qeo i have cleared the runway(or landing area)
qes a right-hand circuit is in force at...(place)
qfa the meteorological forecast for...(flight, route, section of
 route or zone)for the period... hours until...hours is...
qfb the 1.approach
 2.runway lights are out of order
 3.approach and runway
qif ...isusing...hkz(or...mhz)
qfc at...(place, position or zone)the base of the cloud is... eighths
 ... type at... (figures and units) height above... datum)
qfd 1.the...visual beacon(at...(place))is in operation
 2.i will extinguish the aerodrome visual beacon(at...(place))
 until your landing is completed
qfe if you set the subscale of your altimeter to read...hectopascal,
 the instrument would indicate its height above aerodrome
 elevation(above treshold, runway number...)
qff at...(place)the atmospheric pressure converted to mean sea level
 in accordance with meteorological practice is...(or was
 determined at...hours to be)...hectopascal
qfg you are overhead
qfh you may descend below the clouds
qfi the aerodrome lights are lit
qfm 1.maintain(or fly at)flight level/altitude...
 2.i am maintaining flight level/altitude...
 3.i intend cruising at flight level/altitude...
qfo you may land immediately
qfp the latest information concerning...facility(at...(place))is as
 follows...
qfq the approach and runway lights are lit
qfr your landing gear appears damaged
qfs the radio facility at...(place)is in operation(or will be in
 operation in...hours)
qft ice formation has been observed at...(position or zone)in the
 type of...and with an accretion rate of...between...(figures and
 units)heights above...(datum)
qfu the magnetic direction(or number)of the runway to be used is...
qfv the floodlights are switched on
qfw the length of runway...now in use is...(figures and units)
qfx i am working(or am going to work)on a fixed aerial
qfy the present meteorological landing conditions at...(place)area...
qfz the aerodrome meteorological forecast for...(place)for the
 period...hours until...hours is...
qgc there are obstructions to the...of runway...
qgd there are obstructions on your track...(figures and units)height
 above...(datum)
qge your distance to my station(or to...)is...(distance figures and
 units)
qgh you may land using...(procedure or facility)
qgk i am making good a track from...(place)on...degrees...(true or
 magnetic)
qgl you may enter the...(control area or zone)at...(place)
qgm leave the...(control area or zone)
qgn you are cleared to land(at...(place)
qgo landing is prohibited at...(place)
qgp you are number...to land
qgq hold at...(place)at flight level/altitude..., and await further
 clearance
qgt fly for...minutes on a magnetic heading of...degrees
qgv i see you at...(cardinal or quadrantal point of direction) or i
 can see the aerodrome or i see...(aircraft)
qgw your landing gear appears to be down and in place
qgz hold on...direction of...facility
qhe i am on 1.cross-wind leg
 2.down-wind leg
 3.base leg of approach
 4.final leg
qhg cleared to enter traffic circuit at flight level/altitude...
qhh i am making an emergency landing
qhi i am(or...is) 1.waterborne
 2.on land at...hours
qhq i am making a...approach
qhz circle the aerodrome(or go around)
qic i will establish communication with...radio station on...khz(or
 mhz)now (or at
qja your 1. type
 2.mark and space is reversed
qjb i will use 1.radio
 2.cable
 3.telegraph
 4.teletypwrite
 5.telephone
 6.receiver
 7.transmitter
 8.reperforator
qjc i will check my 1.transmitter distributor
 2.auto-head
 3.perforator
 4.reperforator
 5.printer
 6.printer motor
 7.keyboard
 8.antenna system
qjd you are transmitting 1.in letters.
 2.in figures
qje your frequency shift is 1.too wide
 2.too narrow (by...cycles)
 3.correct
qjf my signal as checked by monitor...is satisfactory 1.locally
 2.as
radiated
qjg revert to automatic relay
qjh run 1.your test tape
 2.a test sentence
qji i am transmitting a continuous 1.mark
 2.space
qjk i am receiving 1.a continuous mark
 2.a continuous space
 3.a mark bias
 4.a space bias
qkc the sea conditions(at...position)...
 1.permit alighting but not take-off
 2.render alighting extremely hazardous
qkf you may expect to be relieved at...hours
 (by 1.aircraft...(identification)(type...)
 2.vessel whose call sign is...(call sign)(andlor whose
 name is...(name))
qkg relief will take place when...(identification)establishes
 1.visual
 2.communication contanct with survivors
qkh the parallel sweep(track)search is being(or to be)conducted
 1.with direction of sweeps...degrees...(true or magnetic)
 2.with...(distance figures and units)spearation between sweeps
 3.at flight level/altitude...
qkn aircraft plotted(believed to be you)in position...on track...
 degrees at...hours
qko in the operation(...(identification)),the following units are(or
 will be)taking part... (name of units)
qkp the search pattern is 1.parallel sweep
 2.square search
 3.cerrping line ahead
 4.track crawl
 5.contour search
 6.combined search by aircraft and ship
 7....(specify)
qlb i have monitored...station and report(briefly as follows...
qlh i will know key simultaneously on...frequency and...frequency
qlv the...radio facility is still required
qmh shift to transmit and receive on...khz(or...mhz);if communication
 is not established within 5 minutes, revert to present frequency
qmi the vertical distribution of cloud as observed from my aircraft
 at...hours at...(position or zone)is: lowest layer observed...
 eighths (...type) with base of... (figures and units) and tops of
 ... (figures and units) height above... (datum)
qmu the surface temperature at...(place)at... hours is...degrees and
 the dew point temperature at that time and place is...degrees
qmw at...(position or zone)the zero celsius isotherm(s) is (area) at
 flight level(s)/altitude(s)...
qmx at...(position or zone)at...hours the air temperature
 is...(degrees and units)at flight level/altitude...
qmz the following amendment(s) should be made to the flight forecast...
qne on landing at...(place)at...hours, with your subscale being set
 to 1013.2 hectopascal, your altimeter will indicate...(figures
 and units)
qnh if you set the subscale of your altimeter to read...hectopascal,
 the instrument would indicate its elevation if your aircraft were
 on the ground at my station at... housr
qni turbulence has been observed at...(position or zone) with an
 intensity of...between... (figures and units) and...(figures and
qno i am not equipped to give the information(or provide the
 facility) requested
qnr i am approaching my point of no return
qnt the maximum speed of the surface wind at...(place)at...hours
 is...(speed figures and units)
qny the present weather and intensity thereof at...(place, position
 or zone)at...hours is...
航海用
qoa ~ qqz : for martime service
qoa i can communicate by radiortelegraphy (500khz)
qob i can communicate by radiortelephony (2182khz)
qoc i can communicate by radiotelephony (channel 16-frequency 156.80
 mhz)
qod i can communicate with you in 0. dutch
 1. english
 2. french
 3. german
 4. greek
 5. italian
 6. japanese
 7. norwegin
 8. russian
 9. spanish
qoe i have received the safety signal sent by...(name and/or call sign)
qof the quality of your signal is 1.not commercial
 2.marginally commerical
 3.commercial
qog i have...tapes to send
qoh send a phasing signal for...seconds
qoi send your tape
qoj i am listening on...khz (or...mhz) for signals of emergency
 position-indicating radiobeacons
qok i have received the signals of an emergency position-indicating
 radiobeacon on...khz(or...mhz)
qol my vessel is fitted for the reception of selective calls. my
 selective call namber or signal is...
qom my vessel can be reached by a selective call on the following
 frequency/ies...(periods of time to be added if necessary)
qoo i can send on any working frequency
qot i hear you call; the approzimate delay is...minutes
离线bg2rlw
只看该作者 2楼 发表于: 2008-12-22
如果你能把它翻译成汉语就更好了
离线深圳上尉
只看该作者 3楼 发表于: 2008-12-24
qra 〜 quz :所有服务
qra的名字我站...
qrb的近似我们之间的距离站是海里...
( or. ..公里)
电路的决算费用,我站得到解决私营
企业... (或州政府)
qrd我约束的形式... ...
qre我估计到达时间在... (或以上...)(位)是...小时
快速应变部队,我回... (地方)
qrg您确切的频率(或... )是...千赫( or. ..兆赫)
qrh您的频率各不相同
qri的语气你的传输1.good
2.variable
3.bad
qrj我...无线电话呼吁书
qrk的可懂度的信号(或者是... )是1.bad
2.poor
3.fair
4.good
5.excellent
qrl我忙(或我忙...).请不要干涉
质量风险管理,我被干扰( 1 。为零
2.slightly
3.moderately
4.severely
5.extremely )
qro增加发射机功率。
qrp降低发射机功率
qrq传送速度( ...话每分钟)
qrr我已经准备好了自动操作。传送时...话每分钟
qrs波传送更慢( ...话每分钟)
qrt停止派
qru我没有你
qrv我准备好了
快速反应窗口请告知...那我打电话他就...千赫(或兆赫)
qrx我会请你再次...小时( on. ..千赫( or. ..兆赫) )
qsa的力量您的信号(或者是... )是
1.scarcely明显
2.weak
3.fairly良好
4.good
5.very良好
qsb您的信号衰落
我的qsc一艘货船
qsd您输入有缺陷
qse估计漂移的救生艇筏是... (数字和单位)
qsf我对救援和10:00程序...基地( with. ..者
受伤需要救护车)
qsg ...电报传送的时间
qsh我能够在我的家里d / f索赔设备(站... )
优质服务倡议我一直无法打破在您的传输
qsj收费将收集到...包括我的内部收费
是...法郎
qsk我可以听到你我的信号;打破在我国传播
qsl我承认收到
qsm重复最后一次电报你寄给我(或电报(星期日)
号码(带)...)
qso我可以沟通...直接(或通过接力... )
快启方案我将中继...免费的
qsq我有一个医生在船上( or. .. (名字的人)是在船上)
qsr品牌重复您的呼吁,要求频率;没有听到您(或
有干扰)
qss我将使用工作频率...千赫(通常只有最后
三个数字的频率需要考虑)
qsu发送或回复就这个频率(或...千赫( or. ..兆赫) (与
排放的阶级... )
qsv发送了一系列的速度在这个频率(或...千赫( or. ..兆赫)
qsw我要在此发出的频率(或...千赫( or. ..兆赫) (与
排放的阶级... )
qsx我听... (呼号(星期日)的...千赫( or. ..兆赫) )
qsy变化的另一个传输频率(或...千赫(或...兆赫) )
qsz发送每个单词或一组的两倍(或...倍)
qta取消电报号码...
qtb我不同意你的票的话,我会重复
第一个字母或数字,每个字或组
qte您的真实轴承我是... ...度分
qtf的立场你站根据所采取的轴承
为d / f索赔站,我控制...纬度,经度... (或
其他表明的立场) ,阶级... ...时间在
qtg我要派两个破折号的每十秒钟后我
呼号( repeated. ..次) ( on. ..千赫(或兆赫) )
qth我的立场是...纬度, ...公里每小时或雕像...
英里每小时)
qti我真赛道度...
qtj我的速度是...节( or. ..公里每小时或章程英里...
每小时)
qtk的速度,我国的飞机与地球表面的
是...节( or. ..公里每小时或...雕像英里每小时)
我真正的qtl标题是...度
qtm我国磁航向是...度
qtn我离开... (地方)在...小时
qto我已离开码头(或港口)或我空降兵
qtp我要进入码头(或部分)或我要下车(或土地)
qtq我要与您站通过
国际代码信号
qtr公司的正确时间是...小时
优质旅游服务我会用我的呼号为目的或调整,使我国
频率可衡量现在(或...小时)的...千赫( or. ..兆赫)
qtt的识别信号,以下是叠加到
另一种传输
qtu我站的开放时间...来, , ,分
qtv站岗,我的频率...千赫( or. ..兆赫) (从
...到...小时)
qtw幸存者英寸..条件和迫切需要...
qtx我将随时向我站开放的进一步交流与你
直至另行通知(或直到...小时)
数量程序,我的立场事件岁预计到达
在...小时( on. .. (日期) )
qtz我继续寻求... (飞机,船舶,救生艇筏,
幸存者或飞机残骸)
这里条件是新的... (呼号)
qub的下面是所要求的信息...
quc的人数(或其他指示)在过去的讯息我收到了
从你(或从... (呼号) )是...
qud我收到的紧迫发出的信号... (呼号移动
站)在...小时
阙我可以使用电话进来.. (语文)关于...千赫( or. ..兆赫)
quf我已收到求救信号发出的... (呼号的
移动站)在...小时
qug我froced下车(或土地)立即
quh本气压在海平面... (单位)
归仁我国航行灯工作
quj真正的赛道达到箱( or. .. )是... ...度分
quk (大海... (或坐标)是...
qul的膨胀在... (或坐标)是...
库姆(正常工作可能会恢复
群我的立场,真正的课程和速度是...
现状,请搜索
1.aircraft
2.ship
3.survival船附近的...纬度,经度...
(或根据任何其他指示)
qup我的立场表明了1.searchlight
2.black somke线索
3.pyrotechnic灯
quq请您探照灯火车上云,闪动,如果可能的话
如果我的飞机是看到或听到,转移了梁风
和水(或土地) ,以促进我国登陆
古兰经幸存者1.are拥有生存设备下降了...
2.hve被拾起,救援船只
3.have已达成的地面救援党
定量超声短视1.survivors有水
2.survivors上筏
在位置3.wreckage ...纬度,经度...
(或根据任何其他指示)
昆士兰科技大学的地位发生的特点是1.flame或烟雾浮动
2.sea标志
3.sea标记戴斯
第4 ....(指定其他标记)
quu主页船只或飞机... (呼号)
1.to您现在的位置是把你的呼号和长期
破折号的...千赫( or. ..兆赫)
2.by转递...千赫( or. .. mhz )的真正的轨道,就可以
quw我的... (指定)搜索范围
qux我有以下nevigational预警( s )或烈风警告(星期日)
生效: ...
葵位置救生艇筏的特点是在...小时
1.flame或烟雾浮动
2.sea标志
3.sea标记戴斯
第4 ....(指定其他标记)
quz危难阶段仍然有效;限制的工作可能会恢复
英语 > 中文(简体) 互换翻译
离线深圳上尉
只看该作者 4楼 发表于: 2008-12-24
航空用
查布您正在清除( or. ..被清除)由来自... ... (地方) ,以...
(地方)在飞行高度层/高空...
qaf我(是)在(超过)...(的地方) ( at. ..小时)在飞行高度层/高空...
qag荫安排我的航班,以便达成了... (地方)在
...小时
qah我在飞行高度层/高空...
质素保证视学的基本交通尊重您的飞机...
qak有相撞的危险
堡我要土地....(位)
气象观测的qam上所作... (地方)在...时间是...
(方向) ... (高速数字和单位)
qao的风向和风速在... (立场或区/秒)在飞行
水平/ altitude...is ... (垂直距离的数字和单位)
... ...如此程度(高速数字和单位)
亚太听我(或... )的...千赫( ...兆赫)
qaq您正在1.near
2.flying内地区... (鉴定区)
加尔您可能会停止听的观看频率分钟...
qau我要抛弃燃料
qaw我即将进行超程序
qay我通行证... (地方)轴承...度相对我的标题...小时
qaz我遇到沟通困难通过悬挂在
风暴
qba水平能见度... (地方)在...时间是... (距离
数字和单位)
qbb的数量,种类和高度以上的正式海拔机场
的基础上云... (地方)在... ...时间是八分之七
( ...型)在... (数字和单位)以上官员的高度
机场海拔
qbc气象条件,从我观察到飞机上...
(立场或区) ,在时间上... ... (数字和单位)高度
上述... (基准)的...
qbd我国燃料耐力是... (小时和/或分钟)
昆士兰我将在我的风空中
qbf我飞在云中飞行高度层/高空... (我很
升序( descenging )的飞行高度层/高空... )
qbg我云层上空飞行,并在飞行高度层/高空...
qbh我下面悬挂云和飞行高度层/高空...
qbi下飞行航班是义务教育... (位) (或从...到... (地方) )
qbj在小时... ... (立场或区)的顶端是云量
...八分之七( ...型)在... (数字和单位)以上的高度...
(资料)
qbk我飞行,没有云,我在附近飞行
水平/高空...
qbm这里发出的信息... ...时间在
qbn我飞行进出clound和飞行高度层/高空...
准两年振荡下vfr飞行,允许在... (地方)这将是
适合您的目标
qbp我飞行进出clound和飞行高度层/高空...
qbs细节(或下降) ,以... (数字和单位)高度以上(基准)
之前遇到的文书气象条件或者如果
能见度低于... (人物和单位的距离)和
提醒
qbt的跑道视程在... (地方)在...时间是... (距离
数字和单位)
qbv我已经达到飞行高度层/高空... ( or. .. (地区或地方) )
qbx我已离开飞行高度层/高空... ( or. .. (地区或地方) )
qbz我汇报我的飞行条件有关的云彩
我的qca改变我国飞行高度层/高度从...到...
qcb时滞正在造成的1.your转递的反过来
2.your在回答缓慢
3.lack您的答复我的...
qce预计办法关...小时
qcf时滞indefinite.expect办法清除不得迟于...小时
qch清除的士到... (地方)
qci我提出一个360度大转弯立即(转向... )
卡塔尔慈善协会接待的我...频率细分
qcx我国全面呼号是...
qcy我工作的traling空中
qdb我发出讯息...到...
qdf我国右旋价值... (位置)在... (数字和单位)高度以上
1013.2 hectopascal的基准是... (丁价值的人物和单位) ...
(指定正负)
qdl我打算请你杉木了一系列的轴承
qdm的磁航向为您引导到我( or. .. )将不会
风...度(在...小时)
qdp我将接受控制(或责任)的(对) ...现在(或...小时)
您的qdr磁轴承从我(或从... )是...度( at. ..小时)
qdt我在视觉飞行气象条件
qdu取消我的飞行航班
qdv我飞行的飞行能见度小于... (数字和
单位)在飞行高度层/高空...
qea您可以跨跑道前面
qeb tazi如下的交叉点上... (左转左转右礼)
qec您可能作出180度大转弯,回到了跑道
量子电动力学试验后续车辆
优质教育基金我已经离开了停车区
伊利沙伯医院我已经搬到举行的立场跑道若干...
qej我承担起飞的跑道位置和数量...上午举行
qek我已经准备好立即起飞
qel您正在清理起飞(反过来如下起飞后... )
qem的状况表面着陆... (地方)是...
qen按住你的位置
qeo我已经清除了跑道(或着陆区)
坛彗星伊馆献艺甲右手电路是有效的... (地方)
qfa气象预报... (飞行路线,一节
路线或区)期间小时,直到... ...小时...
qfb的1.approach
2.runway灯失灵
3.approach和跑道
qif ... isusing ... hkz ( or. ..兆赫)
qfc在... (地点,位置或区)的基础云...八分之七
... ...类型(数字和单位)的高度...基准面以上)
qfd的1 ...视觉灯塔( at. .. (地方) )正在运作
2.i将取消机场视觉灯塔( at. .. (地方) )
直到您到达完成
qfe如果您设置的分量的高度表阅读... hectopascal ,
仪器将显示其高度上述机场
海拔(以上treshold ,跑道数量... )
qff在... (位)的大气压力转化为平均海平面
根据气象做法是... (或
确定...小时是) ... hectopascal
qfg您的开销
qfh您可能会下降低于云彩
qfi的机坪照明灯,照亮
qfm 1.maintain (或飞行)飞行高度层/高空...
2.i时保持飞行高度层/高空...
3.i打算在巡航飞行高度层/高空...
qfo您可以立即土地
封装的最新资料...设施( at. .. (地方) )是
如下...
qfq的做法和跑道灯都点亮
qfr您的起落架出现损坏
qfs无线电设施... (地方)是在运作(或将在
操作英寸..小时)
定量反馈理论的形成冰已观察到... (立场或区)的
类型的...并以积率之间... ... (数字和
单位)高度以上... (基准)
qfu磁方向(或号码)跑道被用来是...
qfv的泛光灯的开关
qfw的长度跑道...现在使用的是... (数字和单位)
qfx我的工作(或上午上班)固定空中
qfy本降落的气象条件... (位)面积...
qfz的机场气象预报的... (位)的
期间小时,直到... ...小时是...
qgc有障碍物的跑道... ...
qgd有障碍物的轨道... (数字和单位)高度
上述... (基准)
qge您的距离我站(或... )是... (距离数字和
单位)
qgh您可能土地利用... (程序或设施)
qgk我取得良好的轨道从... (地方)的程度... ... (真实或
磁)
qgl您可以进入... (控制区或区)在... (地方)
qgm离开... (控制区或区)
qgn您正在清理土地( at. .. (位)
qgo登陆,禁止在... (地方)
qgp您的一些土地...
qgq举行... (地方)在飞行高度层/高空... ,并等待进一步
qgt粉煤灰的...分钟的磁航向度...
qgv我看到你在... (基数或quadrantal点方向)或i
可以看到机坪或我看到... (飞机)
qgw您的起落架似乎并到位
qgz等一下方向... ...设施
qhe我在1.cross风腿
2.down风腿
3.base腿的做法
4.final腿
qhg清除进入交通线路在飞行高度层/高空...
qhh我作紧急降落
qhi我( or. ..是) 1.waterborne
2.on土地...小时
qhq我提出的办法字母a. ..
qhz圈机场(或环绕)
qic我将建立通信与广播电台... ...千赫的(或
兆赫)现在(或
qja您的1 。类型
2.mark和空间得到扭转
qjb我将利用1.radio
2.cable
3.telegraph
4.teletypwrite
5.telephone
6.receiver
7.transmitter
8.reperforator
qjc我会检查我的1.transmitter经销商
2.auto头
3.perforator
4.reperforator
5.printer
6.printer电机
7.keyboard
8.antenna系统
qjd您正在1.in转递信件。
2.in数字
qje您的频移是全1.too
2.too窄( by. ..周期)
3.correct
qjf我的信号作为检查监督...是令人满意的1.locally
2.as
辐射
qjg还原到自动中继
qjh运行1.your测试磁带
2.a测试句
qji我转递连续1.mark
2.space
qjk我收到简持续标志
2.a连续空间
3.a标志偏见
4.a空间偏见
qkc的海况( at. ..立场) ...
1.permit下车但起飞
2.render落极其危险
qkf您可以期望得到宽慰...小时
(按1.aircraft ... (鉴定) ( type. .. )
2.vessel的呼号是... (呼号) ( andlor其
名字是... (姓名) )
qkg救济将在何时... (鉴定)规定
1.visual
2.communication contanct幸存者
qkh平行扫描(田径)正在搜寻(或)进行
1.with方向扫荡度... ... (真实或磁场)
2.with ... (距离数字和单位)之间的扫荡spearation
3.at飞行高度层/高空...
qkn飞机阴谋(相信你)的立场上轨道... ...
度...小时
qko在行动中(...(识别) ) ,以下单位(或
将)参加... (单位名称)
qkp搜索模式是1.parallel扫描
2.square搜索
行前3.cerrping
4.track检索
5.contour搜索
6.combined搜寻飞机和船舶
7日....(具体说明)
qlb我...站监测和报告(简要如下...
qlh我知道关键的同时... ...频率和频率
qlv的...无线电设施仍然需要
玛丽医院移来传输和接收上...千赫( or. ..兆赫) ;如果通信
是不是设在5分钟之内,恢复到目前的频率
q波心肌梗死的垂直分布观察云从我的飞机
在... ...小时(立场或区)是:最低的一层观察...
八分之七( ...型)与基地... (数字和单位)和顶部
... (数字和单位)高度以上... (基准)
qmu的表面温度在... (地方)在... ...时间是学位及
露点温度在时间和地点是...度
qmw在... (立场或区) ,零摄氏度等温线(星期日)是(地区)在
飞行高度层(星期日) /高度(星期日) ...
qmx在... (立场或区)在...时,空气温度
是... (度和单位)在飞行高度层/高空...
qmz下列修正案(星期日)应作出预测的飞行...
qne在降落时... (地方)在...时,你的分量正在建立
以1013.2 hectopascal ,您高度表将表明... (数字
和单位)
qnh如果您设置的分量的高度表阅读... hectopascal ,
该文书将表明其海拔如果您的飞机
在地面上我的站...小时
qni湍流一直观察... (立场或区)的
强度之间... ... (数字和单位)和... (数字和
单位)高度以上... (基准)
侠诺我不给装备的信息(或提供
设施)要求
qnr我很接近我的不归路
qnt的最高速度的表面风... (地方)在...小时
是... (高速数字和单位)
qny目前的天气和强度有在... (地点,位置
或区)在... ...时间是
航海用
qoa 〜 qqz :为martime服务
qoa我可以沟通的radiortelegraphy ( 500khz )
qob我可以沟通的radiortelephony ( 2182khz )
qoc我可以沟通的无线电话( 16频道频率156.80
兆赫)
隔日1次我可以与您沟通在0 。荷兰语
1 。英文
2 。法国
3 。德国
4 。希腊
5 。意大利
6 。日本
7 。挪威语
8 。俄罗斯
9 。西班牙语
qoe我收到的安全发出的信号... (名称和/或呼号)
qof的质量您的信号是商业1.not
2.marginally商业
3.commercial
qog我...磁带传送
qoh发送信号的逐步...秒
qoi发送您的磁带
qoj听我的...千赫( or. ..兆赫)的紧急信号
位置指示radiobeacons
qok我收到的信号的紧急位置指示
无线上...千赫( or. ..兆赫)
质量是我的船装有接收的选择性呼叫。我国
选择性呼叫namber或信号...
库姆我的船只可以通过有选择的呼吁以下
频率/台... (一段时间内将会加上如果需要的话)
qoo我可以向任何工作频率
qot我听说你要求的approzimate拖延分钟...
离线深圳上尉
只看该作者 5楼 发表于: 2008-12-24
我是用google翻译的,可能有不对之处,,,,,,
离线hp-lhw
只看该作者 6楼 发表于: 2008-12-24
很好 学习
离线BG6QCG
只看该作者 7楼 发表于: 2008-12-25
[quote=深圳上尉]我是用google翻译的,可能有不对之处,,,,,,[/quote]
难怪 乱糟糟的
离线BH7LDQ
只看该作者 8楼 发表于: 2008-12-25
药这东西真好!吃了过后看这个也不头晕!
