  • 3842阅读
  • 13回复
3830上关于2008 CQWW SSB的成绩报告 [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2008-10-31
以下内容选自3830,看看老大们是怎么玩的......
离线BA7NQ
只看该作者 1楼 发表于: 2008-10-31
LX7I,只有27岁的contester,连续60小时没有睡觉......
to: 3830@contesting.com, lx2a@gmx.net
subject: [3830] cqww ssb lx7i(lx2a) soab(a) hp
reply-to: lx2a@gmx.net
date: thu, 30 oct 2008 0423 -0700
list-post: <3830@contesting.com">mailto:3830@contesting.com>
            cq worldwide dx contest, ssb
call: lx7i
operator(s): lx2a
station: lx2a
class: soab(a) hp
qth: eschdorf
operating time (hrs): 47
radios: so2r
summary:
band qsos zones countries
160: 598   14     68
  80: 818   20     95
  40: 1077   31     126
  20: 1722   38     148
  15: 721   32     118
  10: 163   9     40
total: 5099   144     595 total score = 7,661,952
club: rhein ruhr dx association
comments:
what a contest!!!!
i was preparing this contest for one year and spend hours and hours on puting
up new antennas, coax cables, beverages and ......
everything was just ready in time (3 hours before the contest). that is why i
did not get any sleep before the contest.
my goal at the beginning was to increase my score from last year, but
everything worked even better than expected.
i tryed to make as much 3-point qsos as possible even if the rate was somtimes
going down (52% qsos outside of eu).
i missed some multipliers on the low bands and i need to improve my antennas.
on 160m i heard many dx-stations i could not reach.( i have alredy some ideas
on how to improve my signal for low bands, .!!!)
still now i am very suprised about my score but i know that i even could do it
better.
i want to thank everybody who called in, especially all the multipliers.
also congratulation to my friends from wwyc cu2x, oh8x and nn3w for their great
score.
this was a real nice experience even if the last 3 hours were very hard as i
was very tyred after 60 hours without sleep and signals.
i am still a young contester with 27 and have still a lot to learn.
cu in the cqwwcw as m/? and in other contests
i will update my homepage in the next days and upload my log to lotw
www.lx2a.com
73s and good dx from
philippe lx2a / lx7i
my setup :
run: ic-765pro3 + amp
multi: ic-756 (10years old with no filters) + amp
mk2r+
160m: dp / inverted v
80m : 4-square / loop
40m : xm240 @29m / gp
20m : xm520 @19m(new antenne which outperforms the old antenna by far) /4el
@26m / kt36xa @18m
15m : xm515 @22m on the same tower as xm520/ kt36xa @18m
10m : xm510 @17m /kt36xa @18m
2 beverages usa / ja
posted using 3830 score submittal forms at: http://www.hornucopia.com/3830score/
离线BA7NQ
只看该作者 2楼 发表于: 2008-10-31
ES5RV,天线很牛....48小时没有睡觉
subject: [3830] cqww ssb es5tv soab hp
reply-to: tonno.vahk@gildbankers.com
date: wed, 29 oct 2008 1345 -0700
call: es5tv
operator(s): es5tv
station: es5tv
class: soab hp
qth: jogeva
operating time (hrs): 48
radios: so2r
summary:
160: 602   20     77
  80: 1038   31     109
  40: 1015   32     111
  20: 2471   38     137
  15: 407   35     94
  10:   93   6     28
total: 5626   162     556 total score = 7,106,764
club: tartu contest team
comments:
great contest, i guess i managed to realize almost maximum potential of myself
and station. no technical problems and did not even get sleepy for 48 hours.
only lost my voice by the end and had to talk real quiet because it was so
painful. i made exactly 600 2nd radio qsos. they are s&p and qsys as i do
almost all the cqing on the 1st radio. the antenna set up with 4 rotating
towers (45, 45, 42 and 35 meters) in my station now is:
160m: full size 4 square with 60 ground mounted 1/4wl radials per vertical,
wire vertical from 45m tower with 3 radials.
80m: full size 4 square with 60 ground mounted 1/4wl passive radials per
vertical and active elevated 1 radial per vertical, 3 el yagi at 36m height,
low dipole inverted v
40m: full size 3 over 3 yagis at 42/22, coil loaded 3 over 3 at 42/22,
optibeam
17-4 (3 elements on 40) at 42m, dipole
20m: 4xjp2000 tribanders at 45/36/27/18, 3xjp2000 tribanders at 34/25/16, 5
over 5 full size at 42/22, optibeam 17-4 (4 elements on 20) at 42m, jp2000
tribander at 15m
15m: 4xjp2000 tribanders at 45/36/27/18, 3xjp2000 tribanders at 34/25/16, 5
over 5 at 28/16, optibeam 17-4 (4 elements on 15) at 42m, jp2000 tribander at
15m
10m: 4xjp2000 tribanders at 45/36/27/18, 3xjp2000 tribanders at 34/25/16, 6
over 6 at 25/19, optibeam 17-4 (6 elements on 10) at 42m, jp2000 tribander at
15m.
with 4 squares i have seen no need for beverages so they are broken:)
i would not have imagined being able to match ben and ranko. really pity that
ranko dropped out this way. we are very close with ben and look forward to see
the other scores that are still unknown. toni has its own planet for sure, one
hell of a job indeed and great write up! and i see that i was sort of lucky
that andy, m6t, had to do the contest in a bad shape without any sleep and i
can only imagine how badly you would have beaten me if you had the luxury of
having station ready friday noon and take a 4 hour nap before the contest like
me:)
i was trying to maximize dx contacts and zones this year. quite happy with low
band mults. 160 was awesome! i was very lucky to go there first night already
at 02.30 as i did qsy with d4c and as i got the frequency just did some cqs
just in case. well after having west coast coming back sure i could not leave.
k7rl and others had simply miraculous signals, better than 20m. absolutely
unbelievable and indeed that might have been the 160 cqww ssb us west coast
propagation of a lifetime for me. some very nice qsys to 160m worked with
ba4rf, hc8a and zs9x. carribians were coming very well and it was wonderful to
have vp2ec calling in with outstanding signal and doing quick and easy qsys to
80 and 40 immidiately for 3 mults. 9m2ax called in on the last hour for double
mult.
80m was also great. very good na signals and also zl/vk/ybs coming very well.
spent the last hour on 80m and really happy to have zone 2 calling in in the
last 10 minutes and then kp4ke for last mult at 23.59! first day i was very
glad to find vk9dwx cqing on 3797 with no one answering. i deliberately went to
cq to 80m last day hoping to get zone 19 that i was missing on all low bands.
what a joy to have rw0ll calling in and doing beautiful qsys to 40m and 160!
just perfect!
40m was lousy as always. tremendous qrm and bad conditions. spent a lot of time
there but did not get much going. it was great working nl7z more than an hour
after my sunrise for double mult, unfortunately qsy to 80 did not work. but 30
minutes later olli, oa4ww called in and we made a great qsy to 80m 1.5h after
my sunrise! thanks!
20m was the money band as always. us propagation was fairly short. from 10.30
to 16.30 utc both days and did not manage to make even 1000 na. still had a lot
of mults coming in. wonderful to work 43 vks and 35 bys. time to make bets when
bys will overcome jas in contests:) nice qsys to 15m with tr8ca (2 double mults
from z36!), 3da0dj, c6apr and others. i was really hoping for 40 zones on 20m
but failed miserably to get 31 (!) and 37. i just don't know why no kh6 guys
ever showed up and i also did not find any:( also did not succeed to qsy j28ja
from 15m or 5h3ee from 40m.
15m was lousy with fairly short propagation but still could have been much
worse. east was coming quite well and 60 jas is not so bad those days. it
closed early and usually the only station i could hear after sunset was 59+
cu2x working absolutely inaudible pile up. the same on 20m of course a bit
later:) best moments were finding su1km with second radio in big pile up at
08.30 utc the second day (my noon) and he agreed to do quick and successful
qsys to 20 and 40m. boy, i was happy for those 6 mults! thank you marko! agreed
sceds for 40 and 80m with 9m8z and vk6dxi, both worked just great in the
evening. but one of the most exiting moments of the contest was on 15m at 07.26
utc the first day when i got a call on a southern antenna and it was kh7u! lp! 3
hours past his sunset! i did not even remember that path like that existed! wow!
i was almost speechless, with those band conditions!
and now 10m. well, almost the only stations i could hear with 2nd radio were
e77a (the strongest) and df0hq. it did not seem to work so i decided to try cq
07.30 on sunday. luckily with 1 hour run i worked most of the mults then that
were accessible. the big guys still pushed through with brutal force!:) i was
very surpised to have vr2c and two bys call in! also 3 ua9 stations and all
from zone 18. no zone 17 was ever heard.
thanks for all the qsos and cu in cw part!
73
tonno
es5tv
离线BA7NO
只看该作者 3楼 发表于: 2008-10-31
铁 人 三 项
离线BA7JS
只看该作者 4楼 发表于: 2008-10-31
很牛很强大!多次提到by。
离线BA7NQ
只看该作者 5楼 发表于: 2008-10-31
很牛很强大!多次提到by。
es5tv在比赛中很强,到处都听到他的声音,我还以为他是在做多人的项目,他提到...........
1)20米上,by的数量比ja多!
2)10米上通到唯一两个by,xixi... 其中一个是我,不知道另外一位是谁呢?
离线BG1DRJ
只看该作者 6楼 发表于: 2008-10-31
20米上,by的数量比ja多!
是啊!这次好像ja出来的很少啊!是不是被股票搞得没心思了?
离线bd3af
只看该作者 7楼 发表于: 2008-10-31
貌似bys20米的双系数比jas多。
离线BG4AHF
只看该作者 8楼 发表于: 2008-10-31
1)20米上,by的数量比ja多! [表情]
2)10米上通到唯一两个by,xixi... 其中一个是我,不知道另外一位是谁呢? [表情]
如果我没搞错,应该是我
离线BA7JS
只看该作者 9楼 发表于: 2008-10-31
报告:不是俺!
但by确实来势凶了一点... ...
离线BG7LDM
只看该作者 10楼 发表于: 2008-10-31
15m上俺与es5tv有个记录,呵呵。他确实很强大。
离线BG1PDP
只看该作者 11楼 发表于: 2008-10-31
俺以为48小时不眠已经够牛了,居然还有60小时的...这到底是什么牛呀?
离线BA7IO
只看该作者 12楼 发表于: 2008-10-31
160米SSB,某位大佬很强!
离线BA7JS
只看该作者 13楼 发表于: 2008-10-31
不是什么牛,是牛bravo。
