  • 2796阅读
  • 2回复
收到2008IOTACONTEST UBN [复制链接]
离线bg2rje
只看楼主 倒序阅读 0楼 发表于: 2008-10-20
http://iotacontest.com/contest/iota/2008/ubn/61bbf87c52b498dc9af4e41d44eb2905.html
total qsos submitted (incl 0 dupes): 122
the robot/human team has adjudicated 40 qsos (32.8%)
your log contains 20 (16.39%) uniques (you have not lost any credit for these qsos).
you also had 0 qsos in non-recommended frequency sections (ie 3560 - 3600, 3650 - 3700, 14060 - 14125 and 14300 - 14350khz):
see rule 3 (you have not lost any credit for these qsos).
you have lost 1 multiplier credit(s) and 4 qso credit(s) as follows:time band mode yourserial call serial rcvd iotaref reason for loss of credit multiplier lost
1400 20 ph 13 ja3dij 10 as007 bad copy [badcopy] should be ja6dij
1626 20 ph 32 jr2pmt 37   bad copy [bad iota] iota of jr2pmt was as007
1643 20 ph 33 je6hur 6   bad copy station is an island but no iota reference was received
2223 20 ph 44 6m0hz/2 222 as015 bad copy [bad iota] iota of 6m0hz/2 was as105 -mult 20ph
离线BA5FB
只看该作者 1楼 发表于: 2008-10-20
那个6m俺也抄成as015了,陪楼主一起晕。
离线BG2RST
只看该作者 2楼 发表于: 2008-10-20
我的也出来了,呵呵~~
0313 15 ph 6 ja1ii 4   bad copy station is an island but no iota reference was received
0318 15 ph 10 je9wjt 4   bad copy station is an island but no iota reference was received
0425 15 ph 14 jm4wuz 29   bad copy [bad iota] iota of jm4wuz was as007
0441 15 ph 18 jh1fve 172   bad copy station is an island but no iota reference was received
0523 15 ph 25 bg3euk 28   bad copy [bad copy] bg3eke
0537 15 ph 27 jr2aan 1   bad copy [bad iota] iota of jr2aan was as007
0734 20 ph 35 jm4wuz 1 as007 noqso [bad serial] serial given by jm4wuz was 41
