  • 4321阅读
  • 21回复
我国第一颗业余卫星将于明年六月发射 [复制链接]
离线BG4CZX
只看楼主 倒序阅读 0楼 发表于: 2008-10-06
来源:http://forums.qrz.com/showthread.php?t=178169
june 2009 launch for first chinese amateur radio satellite
michael chen bd5rv reports that the first chinese amateur radio satellite has been renamed from cas-1 to xw-1 and is planned to launch next june.
我国第一颗业余卫星已被命名为希望1号(xw-1),计划于明年六月发射升空。
on the amsat bulletin board michael writes:
i just came back from a hamvention and met alan, ba1du there. the 1st chinese amateur satellite is now going smoothly. this satellite was formerly named cas-1 and is now xw-1. it takes a beacon and three cross band transponders: fm, linear, and digital.
希望1号将携带一个信标以及3个跨段中继。
the satellite is planned to be launched in june 2009 by a cz-2c rocket in taiyuan satellite launch center in north china.
希望1号计划于明年6月通过长征2c火箭发射升空,发射地点在太原卫星发射中心。
here are some details about upcoming chinese xw-1:
orbit: sun synchronous orbit
altitude: 499km
inclination: 98 degrees
period: 94 minutes
weight: 35kg
size: 550mm * 350mm
temperature: -20 to +45c
power: li ion battery: 16ah
long-term maximum power: 8w
short-term maximum power: 18w
payload:
amateur radio payload: 5.2kg
youngster's experiment payload: 1.6kg
cmos camera: 0.2kg
about amateur radio payload:
beacon: 435mhz, cw 20dbm
linear transponder: rx: 145mhz, tx: 435mhz, 40khz, 30dbm
fm transponder: rx: 145mhz, tx: 435mhz, 16khz, 30dbm
digital store and forward transponder: rx: 145mhz, tx: 435mhz, 16khz, 30dbm
145mhz rx antenna: 2dbi, 135 degree, lhcp, unpacked by remote control after entering the orbit.
435mhz tx antenna: 2dbi, 135 degree, rhcp, unpacked by remote control after entering the orbit.
离线bd4jp
只看该作者 1楼 发表于: 2008-10-06
tmd!国产的还要用英文详细介绍,偏偏不用国语介绍给国内弟兄们看,纯粹垃圾!!!!
离线BG4IQU
只看该作者 2楼 发表于: 2008-10-06
神七怎么没发业余卫星。
离线qswc
只看该作者 3楼 发表于: 2008-10-06
自打我开始玩无线电就听说了,现在对它已经不抱希望了
离线BA2Bi
只看该作者 4楼 发表于: 2008-10-06
秋水望川
离线bv2ac
只看该作者 5楼 发表于: 2008-10-06
神七怎么没发业余卫星。
神七軌道太低, 衛星運作幾個月就被大氣拖曳掉下來了, xw-1 只有500 公里高, 運作兩年就該掉下來了, 一般具有通信轉接的衛星還是在 600-800 公里可以維持 5-10 年最好.
离线BD6AAF
只看该作者 6楼 发表于: 2008-10-06
期待中!
离线BD6CS
只看该作者 7楼 发表于: 2008-10-06
据了解希望一号设计使用寿命3年,计划留空试验1年。总之我们有了自己的业余卫星。
离线bd5rv
只看该作者 8楼 发表于: 2008-10-07
素质,素质。本来就是转发国外的消息。已经很好心翻译了几行。
离线bd5rv
只看该作者 9楼 发表于: 2008-10-07
所谓好事多磨
离线VR2UNA
只看该作者 10楼 发表于: 2008-10-07
为什么要先让外国人知道,而不是我们自己人?
离线bg3nui
只看该作者 11楼 发表于: 2008-10-07
是啊?为什么要先让外国人知道,而不是我们自己人?
离线bd5rv
只看该作者 12楼 发表于: 2008-10-07
那是因为有人没有参加黄山业余无线电节:)
离线BD6AAF
只看该作者 13楼 发表于: 2008-10-08
离线bd6bw
只看该作者 14楼 发表于: 2008-10-10
哎!!
尊重别人,就是尊重自己。既是同好,更要注意礼貌!
离线秋枫
只看该作者 15楼 发表于: 2008-10-10
目的和意义并不是让我们用的。
离线BD2VBB
只看该作者 16楼 发表于: 2008-10-10
火腿新闻要进口哦!
离线bd5rv
只看该作者 17楼 发表于: 2008-10-10
[quote=秋枫]目的和意义并不是让我们用的。[/quote]
不给我们用给谁用?
只看该作者 18楼 发表于: 2008-10-10
已经做好了,在等跟主星一起发射。
离线bd7oi
只看该作者 19楼 发表于: 2008-10-10
啥叫业余卫星?那卫星也像业余无线电那样,可以给我们耍的吖?
