  • 7704阅读
  • 12回复
谁知道这个GP328机子的参数和写频软件 [复制链接]
离线yzk376
只看楼主 倒序阅读 0楼 发表于: 2008-09-09
谁知道这个gp328机子的参数和写频软件,用摩托的(专业无线对讲机 —— 用户编程软件(中文版)r06.06.07
)软件提示不支持。
离线yzk376
只看该作者 1楼 发表于: 2008-09-11
已经解决
已经解决
professional radio - customer programming software r06.09.06
enhancements in this release:
- added support for india model which channel space is limited in 12.5khz only.
- added password verification when writing to radio which is cps password protected.
- added the ability to active the feature that prevent selected channel from being added into scan list or deleted fom scan list from radio.
- added support for the data operation(trident) feature.
- filter the emergency active command from option board while radio is in emergency mode;filter the alert tone(alert1 and alert2) request command from option board while radio is in tx/rx cycle.
system requirements:
operating systems: windows 95, windows 98, window nt 4.0,
            windows me, windows 2000 professional,
            windows xp (home and office)
hardware requirements:
processor     pentium ii 333 or higher
memory       64 mb ram recommended
hard disk space 16 mb minimum free space
peripherals   microsoft windows supported mouse or trackball
          microsoft windows supported serial port for radio communication
          microsoft windows supported printer port for report printing
          1.44 mb 3 1/2 inch floppy disk drive
          cd-rom for software installation
known cps issues:
1) if your pc is running the first release of microsoft windows 95
  and internet explorer has not been installed, you may experience
  problems in installing and running the cps due to certain
  components of the operating system being out of date.
  to eliminate this problem two microsoft patches have been included
  on the cps cd. if you experience any problems under windows 95,
  please go to the cd and run:
  /win95patches/40comupd.exe
  /win95patches/dcom95.exe
  and then re-install the cps.
2) on some pcs, the cps may abnormally terminate if print preview
  is attempted on the print custom screen. this problem only occurs
  when print all is selected. this problem has been observed on
  compaq windows 98 computers with the following programs running:
    * easy access internet program (cpqeasyacc.exe)
    * compaq internet watchdog program (watchdog.exe)
  if this cps function is to be used, it is recommended that these
  programs be removed from the pc startup.
3) when the tree view is printed some nodes may overlap on the
  printout and an extra blank page may be printed. this issue
  is more likely to occur on large codeplug configurations.
4) on some printers, the columns in some printed tables might be
  slightly wider than they should be, causing the table to spread
  horizontally onto a second page.
5) emergency revert personalities assigned on the signaling configuration page
  will not be tracked if the personality being referenced is moved in the tree
  view.
6) on certain hp laserjet printers the print summary option will only print
  one page. if you experience this problem, it is recommended that you first
  save the information to a file and then use any editor (word, wordpad, etc..)
  to open the file and print the summary information.
7) when in windows me and windows xp, sometimes an extra set of scroll bars get
  displayed when viewing certain screens.
programming hints:
1) it should be noted that a new/added conventional personality
  must be assigned to a zone/channel position. to add a zone to
  a radio click the "+" in a personality assignment to zone
  window. to add a conventional personality to the radio, click
  the "+" on a conventional personality window. to add an
  additional conventional personality to a zone go to the
  personality assignment to zone:channel window for the
  desired zone. click the right mouse key within the channel
  table to add a conventional personality entry. please read
  the cps help for additional information.
2) speed dial buttons should not be programmed to the p1, p2, and
  p3 buttons on radios, which overlay these buttons with the menu
  navigation keys. the speed dial buttons will not operate
  in this configuration because the buttons function as the menu
  navigation keys when phone mode is entered.
3) when adding a new conventional personality, verify that the
  bandwidth selected on the conventional personality basic screen is
  correct. incorrect selections will lead to poor radio
  performance.
离线cgp135
只看该作者 2楼 发表于: 2008-09-12
楼主不是说要换吗?
离线yzk376
只看该作者 3楼 发表于: 2008-09-14
楼主不是说要换吗?
已经换了
离线火星刺客
只看该作者 4楼 发表于: 2008-10-21
能告诉怎么解决的吗?
离线BG6BKL
只看该作者 5楼 发表于: 2009-01-24
同问怎么解决的?希望楼主和大家分享一下呀?
离线~{G`V]~}
只看该作者 6楼 发表于: 2009-01-27
鄙视保守   。
离线BH7KQK
只看该作者 7楼 发表于: 2009-01-27
我怎么看着它像换过底板和外壳的呢???????
离线暖风
只看该作者 8楼 发表于: 2009-01-28
专业机,不知道.
离线jack1314twh
只看该作者 9楼 发表于: 2009-01-29
这个机器原先用的写频版本比较高!如果楼主用低版本就不能识别,所以只能换高版本的就能解决问题
离线bg7oo
只看该作者 10楼 发表于: 2009-01-31
我来解答
把cps 换了04版就行了
离线mzmx163
只看该作者 11楼 发表于: 2009-02-06
都是牛人,呵呵,我可以写
离线yzk376
只看该作者 12楼 发表于: 2009-04-16
[quote='~{g`v]~}']鄙视保守   。[/quote]
都一年了,刚看见,不过现在也忘了咋解决的了。
